Go to Post Chit Chat is frivilous but CD would be a colder place without it. - Koko Ed [more]
Unread 20-12-2003, 20:21
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Keying a shaft
I am trying to create a keyed shaft, but I am not sure how you would go about doing it. I figured the easiest way would be to look at the face of the shaft and then draw the outline of the keyway, then cut it out, but it will not let me do that, or I am trying to do it wrong. I al also trying to do the same thing with gears, but I assume that would be the same process. Any help you guys have would be greatly appreciated.
Thanks,
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 20-12-2003, 20:30
Re: Keying a shaft
oops! my mistake - I just noticed you are in the CAD forum - I thought you were trying to cut metal with a tool in the shop
never mind!
Unread 20-12-2003, 21:06
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Re: Keying a shaft--BIG PICTURES
Thanks,
Cory
Basically, you should do what you said.
Purdue Alumni
Cummins, Inc.
Unread 08-01-2004, 16:11
matt111 matt111 is offline
#1024 (McKenzie Kilabytes)
matt111 will become famous soon enough
that should work for the keyed shaft.
for the gear, draw a circle and then one tooth then circle pattern it around and extude. however, if ur doing something complicated like an assembly, i would STRONGLY advise not to use teeth. this will make ur inventor go so slow and maybe even crash...not to mention those constaints what i did was make a simple circle with the dimensions. much easier on the machine and me
Unread 08-01-2004, 16:15
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
Re: Keying a shaft
I believe there is an i-keyed shaft part for Inventor on the FIRST CAD Library. The site is currently down it seems, but if you PM Ed he could probably send you to file.
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Can you stop a pneumatic pump at half shaft mjt902 Pneumatics 16 06-02-2003 11:58
Motor coupling archiver 2001 19 23-06-2002 23:35
shaft drive Joseph F Technical Discussion 5 03-02-2002 17:51
Connecting new gear to shaft? mnkysp6353 Technical Discussion 10 29-01-2002 05:12
Big Shaft to Little Shaft? Anton Abaya Technical Discussion 7 21-01-2002 19:27
