Go to Post Only time will tell for sure, but it seems that the current software providers are hatching up a pretty good solution to the problem. - dlavery [more]
Unread 08-01-2004, 23:14
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: EDU Demo Code: Encoder Interfacing Using Interrupts
Originally Posted by roknjohn
Kevin,
Thank you for all of the great interrupt examples for the EDU controller. They have been extremely educational. I've been racking my brain all year to figure out a simple way to use an encoder that had a useful resolution. This looks like an elegant solution with the new hardware.
Thank you. I'm glad you're making use of the code.
My question is this: How does this translate to the full-size controller? I didn't see any interrupt pins on it.
Would we have to use a timer?
Yes, we'll have interrupts on the new FRC controller. The port b interrupts on the EDU-RC directly map to the first six digital inputs on the new controller (i.e., Interrupt 1 = digital I/O 1, interrupt 2 = digital I/O 2,... interrupt 6 = digital I/O 6).
-Kevin
Kevin Watson
http://kevin.org
