Go to Post It really is up to us to stand up for these principles so when we sell it to the general public we're not just feeding them some line because if we don't believe it, why should they? - Koko Ed [more]
Unread 09-01-2004, 19:37
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Carbide / Hardening / Casting
I've got a few questions about metallurgy.
1. How hot do you need to heat steel to harden it? It melts at 1370 C, so I’m gonna guess about 1000. But could you use a welding torch set on a low flame to harden it a little? Like some sort of home-made hardened steel. Would there be any way to harden steel parts without having it professionally done?
2. Carbide is made by heating Si02 (sand) and carbon together at about 3000 C. Carbide is only a little heavier than aluminum. My question is, if you had that kind of heating capabilities, what would be the problem with making your own carbide and casting your robot frame? It would be interesting to have a robot made of carbide. By the way, is carbide restricted on the robots? I’m not 100% sure.
3. Does anyone know how hot a normal metal-working furnace gets? I’ve heard of one team that cast their gearboxes using sand-casting. It would be interesting to look into if my team can afford doing it.
I know it’s a little far fetched, but imagine it. You melt together sand and carbon, making liquid carbide. Pour it into castings, making bars. Use those bars to make your robot frame. Also, if you could harden your transmission gears and parts, like shifting dogs, your gearboxes would live longer. Just some wild ideas…
Good luck to all teams, ‘cause kickoff is in 13 hours!!!
Unread 09-01-2004, 20:20
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Re: Carbide / Hardening / Casting
http://www.mini-lathe.com/Anodizing/...g_aluminum.htm
Unread 09-01-2004, 21:37
jrgrim12 jrgrim12 is offline
Let's have fun!
#1022 (ArcherGEeks)
jrgrim12 will become famous soon enough
Send a message via AIM to jrgrim12
Hardening Steel:
How you harden steel depends on what kind of steel you have. If you want to harden the steel yourself then you would probably want to use o-1. O-1 is an oil hardening steel. Don't use any oil use something like this (http://library.cbest.chevron.com/lub...5?OpenDocument)
Some oils have low flash points and can bust into flames, or explode. But if you have the right oil then you heat the steel up with a torch until it starts to turn red. The brighter the red/orange the harder the steel will become. Once you have it heated then you quickly dunk it into the oil and quench it. It's a cheap and dirty way to do it. Remember usually the harder you make the steel the more brittle it will become.
I would suggest picking up a Machinery's handbook. It has a lot of useful information in it.
James Grim
www.youthbotin.org
www.ztspeedandfab.com
Unread 10-01-2004, 13:45
I doubt that Carbide would fit into the allowed matierials list. Although it was one of the hardest matierials it is also very brittle and ungiving. It is not the choice for a robot frame that is going to get beat about and it is extremely hard to machine. Hardened matierials are not needed under normal robot building, although they are useful in bearing surfaces and guides.
Unread 22-01-2004, 16:53
157#1Driver's Avatar
157#1Driver 157#1Driver is offline
Pro E King
#0157 (AZTECHS 157)
157#1Driver is an unknown quantity at this point
Send a message via AIM to 157#1Driver
Hate to break it to ya, but if you even could make a frame out of carbide, it probably would shatter the first hit you took, plus it weights a crap ton more than steel does. I know cause I use carbide cutting tools at work and it they flex anymore than .002 of an inch, they shatter.
157 The Aztechs
Luck of the Irish
157 - 12 years and still going
Gingery Lathe - Metal Sand Casting sanddrag General Forum 13 14-08-2003 21:41
The nerds go casting one by one... John Bono Chit-Chat 1 06-03-2003 22:12
