Go to Post Is it bad when are you just sitting at home wishing KICKOFF was here. - JulieB [more]
Unread 10-01-2004, 13:38
Genome17 Genome17 is offline
#0589 (Falcons)
Genome17 is an unknown quantity at this point
Send a message via AIM to Genome17
Human Players Only?
What would happen if in Autonomous Mode OR ANY mode for that matter, you managed to get the robot to drag the goal to where the ball pile is ( high off the ground with the purple balls) and let all the balls drop into the goal?? Is that allowed? I know the robots can't drop in the balls, but essentially gravity is, it's just that the Robot is positioning the Goal under the Balls to get points in.
Do those points count?
Is there a rule??
-Alex Jordan
Team 589
Unread 10-01-2004, 14:02
Trinora's Avatar
Trinora Trinora is offline
Strategery Captain
#0237 (See-ho-bots)
Team Role: Scout
Trinora will become famous soon enough
Send a message via AIM to Trinora Send a message via MSN to Trinora Send a message via Yahoo to Trinora
Re: Human Players Only?
Is there a rule??
I was trying to think of the same thing.
The goals don't have any way for the robot to find it with a sensor.
You'd have to grab it by the metal, not poles.
Plus, the goals have caps.
Unread 10-01-2004, 14:17
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
But if part of your auton was to knock the ball off, can you do it? It's not the robot scoring directly. If I'm not mistaken, the robot cannot score, not that the human player can only score.
Unread 10-01-2004, 14:21
Trinora's Avatar
Strategery Captain
#0237 (See-ho-bots)
Team Role: Scout
Your robot can only touch the yellow balls, so I say you're safe.
Unread 10-01-2004, 14:23
Lisa Rodriguez Lisa Rodriguez is offline
Biology Grad Student.....
AKA: Lisa Rodriguez
FRC #0173 (RAGE)
Lisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant future
Send a message via AIM to Lisa Rodriguez Send a message via MSN to Lisa Rodriguez
I was thinking the exact same thing, the only problem, if another team knocks you ball off before you can get the goal there, but, hey its a new strategy, i really want to know, it could change a lot of strategies
This thing still works?
it's never over unless you let it be over
Unread 10-01-2004, 14:26
Mr. Ivey's Avatar
Mr. Ivey Mr. Ivey is offline
Mark Ivey
AKA: Mark
Mr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of light
Send a message via AIM to Mr. Ivey
I think the same. You can't drag the goal under the drop so that when you knock the activator ball off you drop the balls into the goal. Because the human player is not involved in the act of scoring. So, you probably can not do this.
ivey
When you tell a student not to do it, you shouldn't do it. Or else you will wind up with a 3/8" drill bit in your finger... Like I did...
#0589 (Falcons)
Everyone, look at G20 and G19 and G17. What do you think? it's on same topic.
-Alex Jordan
Team 589
Unread 10-01-2004, 14:34
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
I think it's totally legal to move the goal under the falling area of the small balls, remove the covering ball, then go and knock the bonus ball off causing a lot of the balls to fall into the scoring cylinder.
I think what they are are to get away from with the "No robot can assist a ball from entering the goal" is a robot that opens up a huge back stop or something behind the goals and "funnel" any throw balls into the goals.
Again, everyone is going down the path of very literal meanings of the rules, which is what Dean asked us to get away from. It's just like if your robot grabs the goal and moves it closer to the human player making it easier and quicker to get the balls in. The robot assisted by moving the goal closer, but didn't actually asist in putting the ball in.
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Trinora's Avatar
Strategery Captain
#0237 (See-ho-bots)
Team Role: Scout
Everyone, look at G20 and G19. What do you think? it's on same topic.
Bah humbug.
It only looks good if you want to throw the match, or get the other team points...
It was a good try.
Unread 10-01-2004, 14:46
gsensel gsensel is offline
AKA: Geoff Sensel
gsensel will become famous soon enough
Send a message via AIM to gsensel Send a message via Yahoo to gsensel
This is not possible if done in auton becsaue as soon as the ball is moved the balls are released so the bot would have to be in 2 places at once.
This should not be a penalty becasuse like is stated above the bot is not asiting the balls in the are going there
Geoff Sensel
Andy Baker used me as a positve example at nationals in 2004!!!!!(Now who is the role model DJ????)
I was looking to start a team for my college for next year, but they got hooked up with a local JR High school doing BEST Robotics competition. Has anyone heard of this?
I was previously on the Technokats from 1998- 2002.
Unread 10-01-2004, 15:18
sevisehda's Avatar
sevisehda sevisehda is offline
sevisehda is an unknown quantity at this point
Send a message via AIM to sevisehda
A robot could easily drag the goal under the chute. However there are 2 catches. 1, You'd either have to have a teammate who could activate the bonus, or you'd have to wait 45 seconds for the auto release. 2, The goal is a relatively small target in comparison to the width of the chute. Before any kind of test I'd say that maybe 4 balls would actually end up in the goal.
Could someone clarify if the 45 second wait is from the start of the match or from the end of autonmous?
Unread 10-01-2004, 15:24
Ashley Weed Ashley Weed is offline
Rookie Year: 1995
Ashley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond repute
I don't think it would be that strong of a strategy to follow for two reasons -
1. you wouldn't get that many
2. chances are your opponent or partner would activate your side before you got the goal back.
Unread 10-01-2004, 15:26
Joe Matt's Avatar
1.) You would have more than if you didn't do it
2.) Not really, add in a delay in the auton
Unread 10-01-2004, 16:15
Stephen P's Avatar
Stephen P Stephen P is offline
Stephen P has a spectacular aura aboutStephen P has a spectacular aura about
Here's another autonomous idea: the robot reaches up from the starting point and grabs purble balls from the big tray. Just an idea, but is it legal? Maybe first didn't think of it.
You know you are an electrical engineer when you can determine voltage relative to pain with a 5% error.
Unread 10-01-2004, 16:23
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Is there a rule??
we were thinking about it till we found out that we are not allowed to do it... i might be wrong... but read the rules...
Illegal human player bin placement Mike Soukup General Forum 29 01-04-2003 21:17
What do your human players and mentors do? jonathan lall General Forum 4 30-03-2003 22:34
How can human players stack the bins? Jacqui Sutton Rules/Strategy 1 07-01-2003 00:51
How are your Drivers and Human players doing????????? archiver 2001 2 24-06-2002 00:33
How about a Drivers/Operators page and a Human Players page Anthony S. CD Forum Support 4 02-06-2001 22:47
