Go to Post For those of us in the north, a water game turns into an ice game, which becomes Lunacy. And I don't think any of us want that. - Kimmeh [more]
Unread 10-01-2004, 16:27
HolyMasamune's Avatar
HolyMasamune HolyMasamune is offline
41246017 O-('_'Q)
AKA: Y C
None #0840 (Aragon Robotics Team)
HolyMasamune is on a distinguished road
Send a message via AIM to HolyMasamune
Hanging question
If our team's robot is hanging from the top horizontal bar and off the ground, but another robot is touching our robot and also touching the ground, do we still get the 50 points since now we're part of their robot?
Fear the Blade...
Unread 10-01-2004, 17:00
Aaron Lussier's Avatar
Aaron Lussier Aaron Lussier is offline
Volunteer for hire
Aaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to behold
Re: Hanging question
It depends if there on your team or not, If they are on your team then it DOES NOT count. If it is another teams robot, it DOES count.
Team 151 Student/Mentor 2001-2004
US Navy 2005 -2009
Volunteer 2010 - ???
Field Reset Extraordinaire
Unread 10-01-2004, 17:06
Jeremy L's Avatar
Jeremy L Jeremy L is offline
Videographer, Team 177
AKA: The Basket Maker!
None #0177 (Bobcat Robotics)
Jeremy L is on a distinguished road
Send a message via AIM to Jeremy L
hehe...for a good case of this from last year, my team had an arm that reached over on top of another bot on top of the ramp, and straddled the bot. we weren't touching the ground at all, and the bot we were on was completely on the ramp. we both were awarded the 25 points, and we won as a result.
chances are the rules are no different.
"Why is your team so successful?" "Two words: Good decisions."
"How do you make those?" "One word: Experience."
"How do you get that?" "Two words: Bad decisions."
Unread 10-01-2004, 17:27
Meredith Rice's Avatar
Meredith Rice Meredith Rice is offline
None #0433 (Firebirds)
Meredith Rice has a spectacular aura aboutMeredith Rice has a spectacular aura aboutMeredith Rice has a spectacular aura about
Send a message via AIM to Meredith Rice
Another question about hanging I have is, what if we are hanging from the horizontal bar using it for support and not touching the ground, can we latch onto the vertical bars for additional support and still get the 50 points?
I'm proud to be a....
~*Looks like I've got FIRST fever again*~
Unread 10-01-2004, 18:16
Paul Marshall Paul Marshall is offline
Paul Marshall will become famous soon enough
Send a message via AIM to Paul Marshall
No, you cannot attach to the vertical support bars.
Ref. 7.6 <T04>
I don't know if you can use the bar to help climb up thought, as long as you let go at the end. I would assume that you can't use it to climb up or hang there, but I"m not sure.
-Paul
Unread 10-01-2004, 18:24
353Pobots 353Pobots is offline
#0353 (Pobots)
353Pobots is on a distinguished road
You can't use the vertical bars for anything. The rules say that you can not grab onto, or anything involving the verticle bars to help hold yourself up. If you do so, you won't get the 50 points.
Unread 10-01-2004, 18:25
BandChick's Avatar
BandChick BandChick is offline
Superpower: Knows Everyone
AKA: Sara Reffler
FRC #1089 (Team Mercury)
BandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond repute
Send a message via AIM to BandChick
that's to help HOLD you, but what about climbing? kind of like a (purple) monkey? that should be allowed...though i suppose we'll probably have to wait on a little bit of rule clarification
2016 Championship userbars are here!
1089 Mentor & Alum | 2016 MAR Championship Finalists, Innovation in Control Award Winners
2015 Archimedes Champions | 2015 Einstein Semi-Finalists
2014 MAR Championship Finalists | 2014 Bridgewater District Finalists | 2013 Lenape District Finalists | 2011 NJ Regional Finalists
2014 & 2015 Excellence in Engineering Award | 2014 Xerox Creativity Award
2009, 2011, 2013 KCP&B Entrepreneurship Award Winners | 2012 Gracious Professionalism Award Winners | 2009 NJ Regional Chairman's Award Winners
"Success in life is a matter not so much of talent or opportunity as of concentration and perseverance." C.W. Wendte
Unread 10-01-2004, 18:26
#0353 (Pobots)
As Paul said, 7.6 T04 says you can't attach yourself to the verticle bars. I'm assuming this means at no time during the match to do anything.
Unread 10-01-2004, 18:31
I wasn't sure what it meant by attach. I would guess that means you cannot have your robot react off it at any time during the match, but climbing it is a gray area for me. I wouldn't really call climbing it attaching to it, but I believe that the "intention" of the rule is that you cannot design your robot to react off of it.
-Paul
Unread 10-01-2004, 18:32
iCHiMaHoCV iCHiMaHoCV is offline
iCHiMaHoCV is an unknown quantity at this point
From my understanding of the kick-off broadcast you can only latch onto the the top of the base of the mobile goal and to the horizontal bar in the middle of the field and nothing else...but I may be wrong as i have not had a chance to thoroughly examine the rules yet...
Unread 10-01-2004, 18:35
#0353 (Pobots)
I believe in order to climb the sides, you must have to attach yourself to the vertical bar in some sort of way. I see no other way to climb.
Unread 10-01-2004, 19:33
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
Reminder :: Dean said not to be lawyers
To climb you must attach.. to support yourself in any fassion you must attach
Soo uh.. don't do it mayb I must imagine.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 10-01-2004, 19:40
BandChick's Avatar
AKA: Sara Reffler
(actually that was dave...and i like being a lawyer but thanks for the blunt truth anyway)
Unread 10-01-2004, 20:05
Rule G24 says that the robot "...may never grab or attach to the poles." but maybe they are just referring to the goals...I'm still pretty sure that in the kick-off broadcast they said that you cannot attach or climb using the vertical poles. But...I might be wrong..=P
Unread 10-01-2004, 20:11
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FIRST doesnt want anyone on the vertical supports, because thats exactly what they are. If you had 2 robots hanging off the horizontal bar, and a robot trying to hang off the vertical, bad things might happen. Pretty much all of FIRST's rules like this have to do with safety.
Cory
2001-2004: Team 100
2006-Present: Team 254
Starting position and hanging clarification Don Wright Rules/Strategy 2 10-01-2004 14:21
my idea of a question forum... Ken Leung General Forum 12 30-11-2002 12:17
MnM EASY Question of the Day Winners! Mike Bonham General Forum 22 03-05-2002 21:21
Chief Delphi Site Question Mike Bonham General Forum 1 16-02-2002 22:18
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
