Go to Post The JVN/Karthik segment should have more than enough spontaneity for everyone - Matt Krass [more]
Unread 10-01-2004, 17:41
Mike Rush's Avatar
Mike Rush Mike Rush is offline
Somewhat Insightful
FRC #4154 (Perpetual Recursion)
Mike Rush is just really niceMike Rush is just really niceMike Rush is just really niceMike Rush is just really niceMike Rush is just really nice
Question *4 multiplier? *8!??!?
in 4.3.1 Definitions
CAPPING – A LARGE ball is considered to be CAPPING a goal if it is SUPPORTED by the goal poles and/or SCORED SMALL Balls.
in 4.4.1 Scoring
<G02> a LARGE ball CAPPING a goal doubles the SMALL balls SCORED within that goal.
Does this meaan if you can support the three large yellow balls on one goal only supported by the goal poles and/or the scored small balls that it would be a 8 multiplier??
Mike Rush - Engineer/Mentor
Perpetual Recursion (4154)
Arizona Community Team (1492)
2004 AZ Regional Woody Flower's Award
Basha High School & Intel (1456)
Gila Monsters (64)
Awards!?! Too many to list...
Unread 10-01-2004, 17:44
Trinora's Avatar
Trinora Trinora is offline
Strategery Captain
#0237 (See-ho-bots)
Team Role: Scout
Trinora will become famous soon enough
Send a message via AIM to Trinora Send a message via MSN to Trinora Send a message via Yahoo to Trinora
Re: *4 multiplier? *8!??!?
...Yes.
Unread 10-01-2004, 17:45
GregTheGreat's Avatar
GregTheGreat GregTheGreat is offline
GregTheGreat has a spectacular aura aboutGregTheGreat has a spectacular aura aboutGregTheGreat has a spectacular aura about
in 4.4.1 Scoring
I think that as of now the rule states that this can be done (I haven't looked at the manual throughly enough to make a full judgement).
HOWEVER...
FIRST will probabally state that the maximum multiplier can be 2X.... If not I think that every team will be trying to stuff all the "big balls" in the goals.
-Greg The Great
Unread 10-01-2004, 17:57
353Pobots 353Pobots is offline
#0353 (Pobots)
353Pobots is on a distinguished road
I do not believe the goals are large enough to hold a larege ball inside of them. During kickoff they showed a goal with little balls but still covered with the large ball. Also in the manual section 3(the arena) it has a picture of the goals toped with the large balls. The goals are empty so i figure the goals must be around 25 inches in diameter. So you are not able to have more than 2x multiplier in one goal. Also I believe the 2x multiplier only works once in multiplying the small balls.
Unread 10-01-2004, 17:58
BandChick's Avatar
BandChick BandChick is offline
Superpower: Knows Everyone
AKA: Sara Reffler
FRC #1089 (Team Mercury)
BandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond repute
Send a message via AIM to BandChick
i think if this were allowed then, yes, it would be possible, but not propable. from the video feed it's pretty obvious that once a few smaller balls are in the goals it's hard or near impossible to fit more than one BIG ball in the goal.
2016 Championship userbars are here!
1089 Mentor & Alum | 2016 MAR Championship Finalists, Innovation in Control Award Winners
2015 Archimedes Champions | 2015 Einstein Semi-Finalists
2014 MAR Championship Finalists | 2014 Bridgewater District Finalists | 2013 Lenape District Finalists | 2011 NJ Regional Finalists
2014 & 2015 Excellence in Engineering Award | 2014 Xerox Creativity Award
2009, 2011, 2013 KCP&B Entrepreneurship Award Winners | 2012 Gracious Professionalism Award Winners | 2009 NJ Regional Chairman's Award Winners
"Success in life is a matter not so much of talent or opportunity as of concentration and perseverance." C.W. Wendte
Unread 10-01-2004, 18:05
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
I interpreted it as that if you have small balls in the stationary goal with a 2x ball on top the points in that goal get doubled, and if u have a 2x ball on top of the movable goal the points in there will be doubled.
Penn Class 08
Unread 10-01-2004, 18:08
#0353 (Pobots)
If you have a 2X multiplier on 2 different goals...then the points in one goal is doubled, and the points in the other is doubled. Not both of them added then quadrupled. Still the large ball doesn't fit inside of the goal, even the stationary ones with the lowered front.
Unread 10-01-2004, 18:13
Squeaky Squeaky is offline
AKA: Travis VanSchoyck
FRC #0401 (Hokie GUARD)
Squeaky is an unknown quantity at this point
Send a message via AIM to Squeaky
Im pretty sure that this isn't possible. I've read the manual and the goals have a diameter of 28" whereas the 2x ball has a diameter of 30". Yes the pvc is a little bit flexible but you aren't going to be able to balance a second 2x ball on top of the first without touching it (which it wouldn't count anyway). I don't think there will be a rule that says anything about it being considered a 4x or 8x goal, but i don't think it's possible.
Unread 10-01-2004, 18:15
Munkaboo's Avatar
Munkaboo Munkaboo is offline
#0975 (Synergy)
Munkaboo is an unknown quantity at this point
Send a message via AIM to Munkaboo
^Speaks the truth. A 2x ball in a goal doesn't double the overall score, it only doubles the score in that goal.
Unread 10-01-2004, 18:18
#0353 (Pobots)
If you did hold it so it balances ontop of the first 2x multiplier, the one you are touching becomes a part of your robot, for the time being. If I'm not mistaken this would in turn make the other 2x multiplier a part as well, and if this is the case, both 2x multipliers become non-countable. Also, the pvc is only flexable at the top, you cant flex it where it is held in place, so the pvc is only flexable for about a quater of it. It isn't even flexable enough for the ball to go in.
Unread 10-01-2004, 18:21
Here might be a way... I have not checked the exact demensions yet so if it is "measurably impossible" just ignore this.
Note: I did it in paint in less then 2 minutes.... no time for photoshop in this fast paced day of ChiefDelphi.
Name:	goal dealie.JPG
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
My team had a discussion about this earlier today, and we came to the conclusion that it isnt possible. The yellow bals must be supported by the goal and SCORING purple balls. In order to be scoring it must be supported by the goal or other scoring purple balls. So you couldnt have purple balls on top of a yellow ball then other yellow balls on them. Plus Yellow Balls can only be supported by 1 goal, so you cant "bridge" them to double 2 goals. In order for the yellow balls to be counted as capping it can only be supported by 1 goal and scoring purple balls, so therefore you cant get a 4,6, or 8x mult.
Note:FIRST will probably release a rules change that clarifies this.
Unread 10-01-2004, 18:23
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Also the yellow balls do NOT fit into the goals without causing them to flex outwards. Anyway, i think even if it were possible the wording would mean it would be 6x mult not an 8. It doubles the balls scored not the points of the balls scored.
Unread 10-01-2004, 18:26
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
4.3.1 Definitions
SCORED – A SMALL ball is SCORED when it is contained within a goal or SUPPORTED only by the goal and/or other SCORED SMALL balls. A ball is not considered SCORED if it is touching a ROBOT of that alliance or is SUPPORTED by a structural part of the field other than the goal.
CAPPING – A LARGE ball is considered to be CAPPING a goal if it is SUPPORTED by the goal poles and/or SCORED SMALL Balls. A LARGE ball is not considered to be CAPPING a goal if it is touching an alliance ROBOT (of that goal’s color) or is SUPPORTED by more than one goal or a structural part of the field.
Unread 10-01-2004, 18:27
iCHiMaHoCV iCHiMaHoCV is offline
iCHiMaHoCV is an unknown quantity at this point
I think that you wouldn't be able to put the 2x multiplier ball in any of the goals because if you noticed in the kick-off video the 2x multiplier ball stuck out a LOT when it was capping the two goals. Unless you can find a way to squash it with a lot of force into the larger goal then it might be possible, but that would probably be more trouble then its worth.
Bringing Rules Back Andy Grady General Forum 39 06-01-2004 10:00
*** Improtant Rule from FIRST *** ttedrow Rules/Strategy 0 28-01-2003 15:15
Team Update #1 is out Bill Gold General Forum 32 08-01-2003 07:55
Bottom line analysis from KSC archiver 2001 17 24-06-2002 01:41
???Bridge??? archiver 2001 3 23-06-2002 22:35
