Go to Post If Amanda is 'old', I am beginning to feel like a fossil.... - Chris Fultz [more]
Unread 10-01-2004, 18:32
353Pobots 353Pobots is offline
#0353 (Pobots)
353Pobots is on a distinguished road
Re: *4 multiplier? *8!??!?
The stationary goals are has a diameter of 28 inches. The pvc piping is 2 inches thick. The has the 28 inch diameter as well.(3.2.2.2 and 3.2.3). Now the large ball is inflated to 30 inch diameter. That doesn't fit in the goal.
Unread 10-01-2004, 18:35
iCHiMaHoCV iCHiMaHoCV is offline
iCHiMaHoCV is an unknown quantity at this point
Yes, but the back three or four pvc pipes are taller then the front three and they appeared to have been able to bend more easily, you could then have the robot "stuff" the 2x multiplier into the goal, thus causing the taller pvc piping to bend backwards, but it would require a lot of strength and it probably wouldn't work too well.
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
You could place two large balls on the stationary goals, because the pvc is of two different lengths. One ball in one of those goals will stick out, but not as far as the 8" tall pvc, so you could support a second and possibly third on the first tellow ball and the 8" tall pvc. However, a capping ball may not be supported by a large ball, so it would not count for extra points.
GregTheGreat's Avatar
GregTheGreat GregTheGreat is offline
GregTheGreat has a spectacular aura aboutGregTheGreat has a spectacular aura aboutGregTheGreat has a spectacular aura about
Originally Posted by iCHiMaHoCV
I think that you wouldn't be able to put the 2x multiplier ball in any of the goals because if you noticed in the kick-off video the 2x multiplier ball stuck out a LOT when it was capping the two goals. Unless you can find a way to squash it with a lot of force into the larger goal then it might be possible, but that would probably be more trouble then its worth.
I just try to analize every possibility.... the more knowelge the better.... You never know a magic ball stuffing machine might be seen at a regional... especally with how many teams there are this year.... and so so many aspects of the '04 game.
-Greg The Great
Unread 10-01-2004, 18:36
#0353 (Pobots)
I don't believe the piping will bend as much as you think. 2 inch pvc doesn't bend as easy as you think.
Unread 10-01-2004, 18:39
tkwetzel's Avatar
Good Luck Teams!
AKA: Tyler Wetzel
The PVC does not need to bend to support all three large balls. The rear PVC on the stationary goals appears to stick out about 3-4" above one large ball capping that goal. This means you could place the other large balls between this PVC and the first large ball capping that goal.
Unread 10-01-2004, 18:40
Maybe you're right, but I'm just going off of what I saw on the broadcast. Because when the human players were shooting at the stationary goal those 5 point balls were making the pvc pipes flop around quite a bit...who knows, maybe some teams will take this direction and we will see this at regional. It will be interesting if it works too! Except it would limit the amount of points the opposing team can get...
Unread 10-01-2004, 18:43
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
It doesnt matter if you can stuff it in there or not, it doesnt count as capping, therefor wont score you more points. Look at the definitions.
Unread 10-01-2004, 18:44
#0353 (Pobots)
The stationary goals have a 8 foot back and a 6 foot front. Now the ball is a 30 inch diameter(2 1/2 feet). If the ball is 6 inches more than the difference of heigh in the pvc, then the pvc can't stick out above the large ball, even if it bends a little.
Unread 10-01-2004, 18:48
Jake177's Avatar
Jake177 Jake177 is offline
AKA: JT, Jake Troiano
FRC #0177 (Bobcat Robotics)
Jake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to behold
Originally posted by 353Pobots
If you did hold it so it balances ontop of the first 2x multiplier, the one you are touching becomes a part of your robot, for the time being.
When I read this rule I couldn't help but think that it came out of something that happened to us at the New England Regional in 2001. Our bot was in the endzone, holding onto a large ball. We then fell over and the end of our arm crossed over the pipe on the perimeter of the field. Fortunately the ball supported the end of our arm so that we were not touching the floor outside of the field. After about 5 minutes of looking through the rules, the judges decided that we weren't out of bounds, since no part of the bot was touching outside of the field, and they awarded us the 10 points for being in the endzone. Of course, now the ball would be considered part of the bot and we wouldn't have received the points.
Once a Bobcat, always a Bobcat
2001-2004: Student
(I'm told the team had a couple good years in between here)
2012 - Present: Mentor
Unread 10-01-2004, 18:56
tkwetzel's Avatar
Good Luck Teams!
AKA: Tyler Wetzel
353Pobots, You have not accounted for the amount of the ball that sits inside the goal when placed on top.
Unread 10-01-2004, 21:49
IrisLab's Avatar
IrisLab IrisLab is offline
AKA: Dave Page
#1466 (Webb School)
IrisLab will become famous soon enough
At the Man. Kickoff today after the NASA telecast, a few mentors stuffed three yellow (30") balls into one scoring goal. Enough room at the bottom for about 4 small balls. If those at the bottom are yellow (4x10=40) and you have a (6x or 8x) multipler, the score would be 240 or 320 respectively.
We asked Woody about this situation and he was unable to clarify. Essentially, FIRST will need to issue a clarification on this issue.
The 30" balls will squeeze into the goals but they flex the tubing.
David Page
Unread 10-01-2004, 21:50
Ken Loyd Ken Loyd is offline
Who is John Galt?
FRC #0039 (The 39th Aerosquadron)
Ken Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to behold
Dear Readers,
I rank Mike Rush right behind Dean and Woodie and 1 step ahead of Dave. If it is made legal to get three yellow balls in a goal, Mike will find a way!
Ken Loyd
Team 64
Unread 10-01-2004, 21:51
Was there a lot of pressure when trying to push to balls down that deep? I would imagine there was...
Unread 10-01-2004, 22:00
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
Why would would you want to put all three of them in a single goal. 3 Large Balls = 90" into a 96" goal (assuming you could get them there). Then say you could even manage to get 4 13" 5pt balls in that 6" space. You would have a score of 160. It seems much easier to get 16 little balls in and put one large ball on top. It also seems like you would be more likely to do it (or come close) in the time frame given.
Bringing Rules Back Andy Grady General Forum 39 06-01-2004 10:00
*** Improtant Rule from FIRST *** ttedrow Rules/Strategy 0 28-01-2003 15:15
Team Update #1 is out Bill Gold General Forum 32 08-01-2003 07:55
Bottom line analysis from KSC archiver 2001 17 24-06-2002 01:41
???Bridge??? archiver 2001 3 23-06-2002 22:35
