If there's already a topic about this, somebody please point me to it...if not, lemme know here.
![]() I had to leave during the kickoff to go to work, so I don't know if Dean or Woody mentioned this.. When another bot is hanging on the bar, and you're under them on the ramp, and for some reason they fall...then a 130lb robot is going to smash down on you, right? I wasn't sure if Dean or Woody said anything, I didn't have much of a chance to see a whole lot of info about the bar. Thanks! ![]() |
Re: Falling off the bar... :\
they haven't said anything, but all that can be hoped for is that you don't end up with one BIG mess of robot accidents from hanging bots falling onto bots on the platform
i guess weel have to get out the zip ties, Zach
I really hope that we don't end up on the bottom of a bot pileup. This is definitely a great case for making your bot durable. What I'd be most worried about would be any manipulations (arms, etc.) on top of the robot. I guess we'll see later on... |
Well that was/is why the bar was/is adjustable. On the other hand, any mock up a team can make wont be...
![]() EDIT: Nope, the bar is adjustable so that at the end, when the bots are hanging, the people can safely lower the bots.. right? Last edited by Swampmonkey : 10-01-2004 at 20:44. |
#7
Wasn't there something in the video about preparing for impact?
Make her sturdy, boys 'n girls! ![]() |
#9
I have a feeling there will be a lot of bot accidents...all it takes is one hit from above, and one or more elctronic components will be damaged :\ We got hit a lot last year (if yall remember the huge Swamp Thing robot that took up the entire ramp), and so we mounted a system of shocks for on our electronic component boards--we're going to need something much more advanced this year :\
I wonder if Dean meant for this to be something we'd have to work around...the threat of being crushed like this, to make it more of a challenge--or was it something he just didn't think of?? ![]() |
#10
Im kinda' curious what it will be like in march, i mean last year we though when someone fell forward on the ramp it was bad, if someone's bot is flattened, that will royally suck. Also, if you have a hook or winch(or whatever) holding you up on the bar, what happens once the power is cut at the end of the match? BAM, best put some industrial shocks on the chassis this year ;-)
#11
It'll be very easy for bots to fall too...if there are two robots with hooks, and the two hooks so much as slide into eachother, chances are one or both robots will become unhooked and fall ![]() Imagine the carnage as two robots smash into two other robots as well as each other from several feet in the air...I'm bringing my camera ![]() |
#12
From what I remember in '00 there was some issues, but not much. I'm not worried about many robots falling off the bar.
< j/k > The key word this year...starts with an "R"...and ends with an "obust"... </ j/k >Good luck, folks! Last edited by Jessica Boucher : 10-01-2004 at 21:54. |
#13
Do you really think that a 130lb robot can do any possible damage to another 130lb robot??? hmmm... lets think about this one really really hard....
#14
![]() It doesn't matter how strong the top of your robot is...the sheer impact from the other bot falling on you from several feet in the air is enough to destroy you, at least on the inside :\ Unless they add some rule where you can't lift more than a certain height off the ground, which I dubt they will ![]() |
| Vertical bar interaction | Madison | Rules/Strategy | 5 | 10-01-2004 16:22 |
| Raising the bar? | Sachiel7 | 3D Animation and Competition | 15 | 23-12-2003 02:21 |
| 14 inch bar? | hi_im_sean | Rules/Strategy | 2 | 29-01-2003 15:35 |
| Grab bar on bottom of goals | archiver | 2001 | 0 | 24-06-2002 00:49 |
| how effective do you think robots going under the bar | archiver | 2001 | 4 | 24-06-2002 00:36 |
