Go to Post I would argue that you are not overdosed if you don't know the correct name of this year's game - KarenH [more]
Unread 10-01-2004, 23:16
nzj1's Avatar
nzj1 nzj1 is offline
#0547 (F.E.A.R.)
nzj1 is an unknown quantity at this point
InfraRed = gps ?
one of the biggest things for your robot to do during the autonomous period is know where it is on the field and so if it gets off course it can make corrections to its path. I was wondering if you could use the
InfraRed as if it were a gps and triangulate its position on the field
Unread 10-01-2004, 23:34
Scooter's Avatar
Scooter Scooter is offline
Galactic Doughnut!!
#0418 (Purple Haze)
Scooter will become famous soon enoughScooter will become famous soon enough
Send a message via AIM to Scooter
Re: InfraRed = gps ?
Absolutely....If you have a little steroscopic tracker like they had, you can calculate a vector to the emitter and a distance. This right here is enough to be able to tell your postition, but the farther away you are, the less accurate your distance mesaurements are. If you add a third detecor on top of one of the other two and have it slaved to the other emitter, then you can get pretty accurate location data. If you use some trig, you can derive a set of coordinates, and a location on the field.
Bill
"Those who think that they know everything are especially annoying to those of us who do."
Unread 11-01-2004, 00:02
mightywombat's Avatar
mightywombat mightywombat is offline
bins? stacking?? NOOOOO!
AKA: Bill Rosemurgy
#0857 (Superior Roboworks)
mightywombat is on a distinguished road
how will you tell which emitter it is tracking though? they won't emit the same signals?
Bill Rosemurgy - Aspiring Programmer and Human Player (stack of 8 in <10 seconds...oh yeah... but I can't shoot for crap.)
www.team857.com
Unread 11-01-2004, 00:06
Michael Auchter Michael Auchter is offline
#0068 (Truck Town Thunder)
Michael Auchter is on a distinguished road
well, they both operate at 40kHz, but each one of the emitters has a different pulse width.
Unread 11-01-2004, 00:12
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
I'm pretty sure you will have to know the angle to both points to get your position on the field. Knowing the angle to one emitter will just give you your relative position to that emitter.
I attatched a image (after an hour of fighting with inventor). See if it helps you understand the geometry.
Greg
Geometry is definitally not one of my strong points, let me know if I'm wrong.
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 11-01-2004, 00:18
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Also, if you can't place the detectors far apart, you could have each detector track one of the two beacons.
Zan Hecht
Unread 11-01-2004, 01:01
Scooter's Avatar
Galactic Doughnut!!
#0418 (Purple Haze)
But if you know the position of that emitter, and your position relative to that, then it is easy to deduce your position relative to the field.
Bill
Unread 11-01-2004, 02:33
PhatalEphekt PhatalEphekt is offline
#0935 (RaileRobotics)
PhatalEphekt is on a distinguished road
yes, but it would be easier to judge direction with two sensors
Unread 11-01-2004, 11:12
jneumiller jneumiller is offline
#0647 (CyberWolves)
jneumiller is on a distinguished road
I need to talk to my smart guys, but think that knowing just two points is going to be problematic. There are going to be issues with tolerances in distance measuring (provided I can do that with the sensors).
Check the sketch...see if this makes any sense.
Jim
Name:	US FIRST IR Sketch.gif
Unread 11-01-2004, 11:39
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
If you were only tracking one beacon, couldent your robot be anwhere on a circle scribed about that beacon with the radius of the 2 sides of the triangle formed from the sensors? IE you know how far away from the beacon, but unless you are using crab, or omni drive and can keep the orentation of your robot square in relation to the sides of the field... you cant really tell your exact feild position.... or is there something that im missing
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 11-01-2004, 12:40
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Both emitters are sending out a 40KHz carrier frequency. The difference is that a "type-0" beacon has a 1ms envelope, while the "type-1" beacon has a 2ms envelope. The duration of the envelope is what determines the type of beacon.
-Kevin
Kevin Watson
http://kevin.org
Unread 11-01-2004, 12:44
AKA: Bill Rosemurgy
ok. So you'd have one beacon tracking each of the different types by how often they recieve envelopes? How exactly are you going to figure out the distance from the emitter? Will the signal be recognizeably weaker the farther you get from it?
www.team857.com
Unread 11-01-2004, 12:52
Stephanie Stephanie is offline
Stew da Baker
AKA: AKA: Steppie86
Stephanie has a spectacular aura aboutStephanie has a spectacular aura aboutStephanie has a spectacular aura about
Send a message via AIM to Stephanie
your angular position wrt the other beacon will change.
Trig.
2002-2003~ team leader of The Apes of Wrath (668)
2004- ~ The Seadawgs (258)
Unread 11-01-2004, 12:55
AKA: Bill Rosemurgy
Ohhh. Boooo..... I don't like trig.
www.team857.com
Unread 11-01-2004, 13:03
FRC #2429
The setup used at the kick-off demo allows you to calculate a heading and distance to the beacon. If you think of the beacon as the origin of a polar coordinate system, and you know the distance and angle to the origin, you should be able to figure out your position within the coordinate system. With a little trigonometry, you should be able to calculate a cartesian x,y solution too.
-Kevin
Kevin Watson
http://kevin.org
InfraRed autonomous code ... mtrawls Programming 1 11-01-2004 00:25
just wondering..(sensors) JasonStern Electrical 14 08-05-2003 00:16
Autonomous Mode Strategy Brian48216 Programming 27 23-01-2003 14:47
sensors George Technical Discussion 15 08-01-2003 14:39
GPS Robot K. Skontrianos General Forum 3 11-05-2002 00:32
