Go to Post Every match they would leave blue and red skid marks all over the carpet. It was like someone roadkilled a Smurf. - Koko Ed [more]
Unread 10-01-2004, 14:22
Jack's Avatar
Jack Jack is offline
FIRST Scouting Network
AKA: Andrew Schenk
FRC #0201 (The FEDS)
Jack is a jewel in the roughJack is a jewel in the roughJack is a jewel in the rough
Send a message via AIM to Jack
Rule <R06>
In intresting new rule poped out when i was browsing through the manual.
The the robot manual, look at <R06>
You will notice how it says that all possible components of the robot must be weighed in and be under the 130lbs limit.
Now, let's say we looked at 111 from last year. The rules say "A team has decided to design its robot such that, before any given match, it may quickly change the configuration of the robot based on perceived strengths or weaknesses of an opponent team's robot." Now, the changeable(sp?) wings they had last year did not configure the robot differently. Therefore, only one pair of wings would have to be counted in the weigh in using this years rules? correct?
Just found this as something way new and wanted to point it out.
Jack
Team 201 - 2003 Great Lakes Semifinalists & 2003 Archimedes Division Finalists :|: Webmaster of www.feds201.com -> FBI Scouting
Winner of The 2003 ChiefDelphi Web Award for: User That Started The Most Non Chit Chat Threads
Winner of: 2003 FIRST Ventures with 5451.68 End Points
All about me: http://knehcsa.vze.com
**Check out the New FIRST Scouting Network**
Unread 10-01-2004, 14:26
gsensel gsensel is offline
AKA: Geoff Sensel
gsensel will become famous soon enough
Send a message via AIM to gsensel Send a message via Yahoo to gsensel
Re: Rule <R06>
As I understand it, and I think some one might have answered it already. Both wings can be used as long as the total of all part is under 130 lbs part may be removed before a match.
Geoff Sensel
Andy Baker used me as a positve example at nationals in 2004!!!!!(Now who is the role model DJ????)
I was looking to start a team for my college for next year, but they got hooked up with a local JR High school doing BEST Robotics competition. Has anyone heard of this?
I was previously on the Technokats from 1998- 2002.
Trinora's Avatar
Trinora Trinora is offline
Strategery Captain
#0237 (See-ho-bots)
Team Role: Scout
Trinora will become famous soon enough
Send a message via AIM to Trinora Send a message via MSN to Trinora Send a message via Yahoo to Trinora
Re: Rule <R06>
Jack
If you change something, you do re-configure, even if it is a small amount or different type. For this, they you two types of ball grippers, which is similar to the idea of changable wings.
Unread 10-01-2004, 14:27
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
Re: Rule <R06>
Jack
No, I think that if 111 had 2 or 3 sets of wings that could be used on the robot during the competition, for whatever reason, they would all be weighed at the same time.
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Unread 10-01-2004, 15:38
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Re: Rule <R06>
I believe this rule has come under question in previous years. Before, the rule has always been that any possible configuration must be weighed-in and inspected before you can use it on the field. If you had interchangeable mechanisms, those would each be weighed in on the robot as they would be set up in competition i.e. if you have 3 different arms on your robot, you have to weigh it in with arm 1, arm 2, and arm 3 separately.
Now, let's look at the rule:
<R06> The maximum allowed weight of all robot configuration components combined is 130.0 pounds (58.97
kg). At the time of weigh in, the basic robot platform and any additional items that might be used in
different configurations of the robot must be weighed together. Weight limit includes (one) 12V battery,
control system, decorations, bumpers, and any other attached parts.
So... this year's rule seems like it may be different. From this wording, it appears that all interchangeable mechanisms must be weighed all at once. Meaning... you can't have 3 different swappable mechanisms that each bring the robot up to 130 lbs. You can have removable end effectors, but they must all together weigh no more than 130 lbs.
Now, taking the example of Wildstang's wings from last year, those would be considered spare parts, as they were identical to the wings used. Thus, I believe they would not need to be weighed, so long as they were just identical spares, and not modified versions.
Jeff Waegelin
Unread 10-01-2004, 15:59
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Re: Rule <R06>
We (111) did have a different set of wings that we rarely used. So, those would not be considered spares and would not be eligible per this year's rules.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 10-01-2004, 21:36
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Re: Rule <R06>
I agree with Rauls intpretation. If it is an optional configuration, it has to be weighed in. Spare parts would not if they were identical.
This probably avoids the issue of a team having an "optional configuration" that might end up as "all inclusive".
This new rule will force a team to select a configuration and go. It would be really tough to have two configurations that could stay under 130#.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 10-01-2004, 21:57
Re: Rule <R06>
Im looking at the rules from last year, and it says:
M5 at the time of robot inspection,you must present ALL mechanisms that you will use on the robot during the entire competition event... Only mechanisms that were present during the inspection may be added, removed or reconfigured...
I took that to mean all mechanisms must be presented "on the robot" - in previous years they spelled it out more explicity - last year this could be taken two ways
From what Raul said a few posts up, it sounds like they had their robot inspected with different attachments added OR removed - was it clear to the judges that this is what you were doing?
On our bot last year we had 4 wheel drive and we also had castors for the front if we wanted to take the front wheels off - we had it inspected with the 4 wheels AND the castors on at the same time, but when we played each match we were free to attach the front wheels OR the castors - this sounds like what is required this year
maybe I was mistaken about last years rules? either way, its clear for this year - everything you use must be on the robot at the same time for the whole inspection process - then if you choose, you can leave things off or put them back on.
Unread 10-01-2004, 22:37
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: Rule <R06>
I don't want to spend too much time rehashing last year's rules, but if you look at the inspection checklist, it states that when weighing the robot, it must be < 130 lbs in the "heaviest configuration."
As for this year, I'm a little curious as to why they changed this rule. Did they suspect that people weren't being honest, and were actually competing overweight? Hopefully not, as a good percentage of the rules rely on teams being honest. It's been mentioned before, but if someone's really interested in cheating at this competition, it wouldn't be too hard.
Unread 10-01-2004, 22:44
RoboCoder RoboCoder is offline
#1002 (Circuit Runner)
RoboCoder is on a distinguished road
Send a message via AIM to RoboCoder Send a message via Yahoo to RoboCoder
Re: Rule <R06>
I think its another way to put a challenge into the game. This year there are so many things that the robot could possibly do, that it would be pretty easy (remember: everything's relative) to make your robot perform any given function as its primary function and do it well (one module for manipulating the multiplier balls, one for the pull-up bar, one etc etc etc), and swap them out to complement the capabilities of your alliance partner. By changin the rule, a limit is placed on teams who choose a modular interchangable design, and thus teams are encouraged to build one robot that can do multiple goals in a single match, which CAN DEFINATELY be a tougher task. Just another challenge FIRST wants to give us
You might be an Engineering Major....
if you'll assume that a "horse" is a "sphere" in order to make the math easier
if you know vector calculus but you cant remember how to do long division
if it is sunny and 70 degrees outside, and you are working on a computer
Unread 10-01-2004, 22:59
Re: Rule <R06>
ah AH! so the Klingon verison of the manual WAS correct!
"Seven ways to score all day
one bot to rule them all
one bot to find them..." :c)
Unread 10-01-2004, 23:56
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Rule <R06>
I don't think cheating had anything do to with this rule. I think it has more to do with the whole issue of "what is the robot and what is the module" type discussions we all got into last year.
I think it is cleaner this way.
But... ...then again, it isn't my ox getting gored. We've never used the module rule so we didn't really loose anything.
Joe J.
Unread 11-01-2004, 00:18
Re: Rule <R06>
Ken,
I am not offended by your questioning the legality of our robot last year - you have the right to do that if you are not familiar with the rules.
So, let me make it perfectly clear for you - the rule is different this year. Last year we were allowed to interchange different modules as long as each different configuration weighed less than 130 lbs.
Unread 11-01-2004, 00:27
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
Re: Rule <R06>
Although this rule change doesn't bother me at all, I don't think it will do anything to prevent cheating. The teams that want to cheat (hopefully there are none!) can still simply weigh in with certain modules missing and then add them back in the next day.
Unread 11-01-2004, 00:41
Re: Rule <R06>
At first I did not particularly like the rule, but now I do not care that much.
It just forces us to implement additive instead of substituitive (did I just make up a word?) modularity.
My Favorite rule. :) Useless member Rules/Strategy 15 01-03-2003 00:44
Proposed New Rule M11 Joe Johnson Rules/Strategy 14 04-02-2003 14:41
Rule C1 Justin Stiltner Rules/Strategy 9 05-01-2003 22:59
Do away with the 2-minute rule! archiver 2000 3 23-06-2002 23:17
1 coach rule Mike Soukup Rules/Strategy 14 07-01-2002 22:27
