Go to Post That's co-oper-tastic. - anyheck [more]
Unread 10-01-2004, 21:02
andy's Avatar
andy andy is offline
Alumni
FRC #1139 (Gear Grinders)
Team Role: Student
andy is a jewel in the roughandy is a jewel in the roughandy is a jewel in the rough
Send a message via AIM to andy
Re: Horizontal Bar: Vertical Velocity
sorry i couldn't resist
V^2=Vo^2+2aX
btw all numbers in metric. metric system rules!
where
V= final velocity
Vo=initial velocity
a=acceleration
X=Delta X (change in position)
V^2=0+2aX
Vo=0 m/s because the projectile starts at rest
V^2=2*9.8*X
a=9.8 m/s^2 acceleration of gravity
3.048^2=2*9.8*X
V=3.048 m/s = 10ft/sec metric rules! remember!
solve for X
X= 0.473995102 meters
X= 1.555102 feet
Remember METRIC RULES!
Good luck this year!
-Andy
Unread 10-01-2004, 21:45
mtrawls's Avatar
Happy Birthday! mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
Originally Posted by tkwetzel
This is interesting, because this maximum velocity is relative to the robot. They did not think this through, because technically, whatever is being sent over the bar is part of the robot.
Technically, thou sayest? What dost thou mean with this "technically"? Really, I seemed to get a slight perception that FIRST wanted us to exercise common sense (something in there was vaguely about safety I think), and there was some statement degrading lawyers (alas! my future profession). Really, though, Dean explicitly said not to over-interpret the rules -- he said that he uses words to "mean what they mean" (stradling is stradling, for crying out loud). I for one like the idea of a minimalist rules book. I mean, 3 rules for scoring! 3! I could barely believe it.
I feel your pain. I as well cannot resist (my physics teacher must have done something right ... or would that be wrong )
Anyway, let's see some accuracy. Why assume that U=mgy is "good enough" afterall! So,
dU = GMm/r - GMm/(r+y) = 1/2 mv^2
(dU means delta U, G is gravitation const., M is mass of earth, r is radius of earth, ..)
Upon solving, y = 5.10! Considerably less than 5.55. I used the values,
G = 6.67 * 10^-11
M = 5.98 * 10^+24
r = 6.38 * 10^6
(something I'm not remembering right from all the physics lectures I slept through?)
Unread 10-01-2004, 22:06
Skabana159's Avatar
Skabana159 Skabana159 is offline
Robotics and Field Hockey
AKA: Jesse C. Owens
#0159 (Alpine Robotics)
Skabana159 is on a distinguished road
Send a message via AIM to Skabana159
Of course, you are all assuming that the object, let's call it "projectile," is decellerating at the gravitational constant! If you were to give it the initial velocity of 10 ft/s, as well as give it an acceleration in midair somehow (get to that pneumatics drawing board), you would be able to send it wherever you wanted to! Particularly if you were to give it an acceleration of, oh say 9.81 m/s/s.
"What most people do not understand is that the Buddha, the Godhead, resides just as comfortably in gears and circuits as in hills and trees. To believe otherwise is to dilute the Godhead."
-Robert Pirsig, Zen and the Art of Motorcycle Maintenance
Unread 10-01-2004, 22:09
Greg's Avatar
Greg Greg is offline
FRC #1075 (Sinclair Sprockets)
Greg is on a distinguished road
Send a message via ICQ to Greg Send a message via MSN to Greg
Yes, I found this suggestion about a camcorder too. Still, it does not explain what the velocity is relative to. In the test with the camera the bot would be standing still, and in the game it might be moving. As well, testing would be needed to see how far you can actually throw something with that velocity It may sound like a lot but there is really no way to tell...
Well, anyway, Dean did talk about generalizations in the rules and how we should not read them the way lawyers do So Im guessing my team will just figure it out eventually
Unread 11-01-2004, 02:07
Kevin Kolodziej's Avatar
Kevin Kolodziej Kevin Kolodziej is offline
Operator in 100+ matches
AKA: Yngwie Kamen's roadie
Kevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond repute
Send a message via AIM to Kevin Kolodziej
Rule <G08> states: Mechanisms which interact with the Pull-Up Bar are limited to a maximum tip velocity (relative to the ROBOT) of 10 feet per second.
Two questions:
1) Does tip mean the tip of a projectile or does tip mean tipping as in falling velocity?
2) If it is the latter, wouldn't that eliminate the possibility for all bar interaction? Your robot has to extend to 9' to get to the top of the bar and if you are tipped, the top part of your robot is certainly coming down at a velocity greater than 10 ft/s.
I'm really trying to simply interpret the rules, but tip is a bad word to use.
Kev
Team 71: 1999, 2000 (Driver), 2001-2002 (Driver, Animator) // Team 1064: 2003 (Co-founder, Coach), 2004 (Coach) // Team 1714: 2006-2007 (Mentor, Coach)
Team 1675: 2005-2007 (Mentor, Coach), 2008 (Mentor), 2009-2017 (Mentor, Coach)
FLL: '04 (Judge), '05 (Ref), '06 (Ref), '07 (Ref), '08 (Judge, Ref), '09 (Judge), '10 (Ref), '16 (Judge Advisor) // Ref: '05 (IN, IRI), '06 (IN, IRI), '07 (IN, IRI), '08 (WMR, Curie)
WI RPC: 2006 - 2016 // FRC Inspector: '07 (WI), '08 (WI, IL), '09 (WI, IL), '10 (WI, CMP), '11 (WI, IL, CMP), '12 (WI), '13 (Northern Lights)
2007 WI Woodie Flowers Award Finalist // 2011 Wisconsin Regional Outstanding Volunteer // 2011/2013 Midwest Regional Chairman's Award
Unread 11-01-2004, 02:11
George1902's Avatar
George1902 George1902 is offline
It's a SPAM thing...
AKA: George1083; George180
FRC #0180 (SPAM)
George1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond repute
They mean the tip as in the farthest part of your climbing device. It cannot extend or retract any faster than 10 ft/sec.
George
"Darkness cannot drive out darkness; only light can do that. Hate cannot drive out hate; only love can do that."
-- Martin Luther King, Jr.
Unread 11-01-2004, 10:30
Greg's Avatar
And one more question. I think in the video it was said that the "maximum vertical velocity cannot be greater than 10ft/sec". If so, what if the robot launches the projectile at an angle, and not straight up? Is only the vertical component counted? The suggested way of measuring velocity (with the camcorder) would probably do just that.
Unread 11-01-2004, 11:09
patTeam241 patTeam241 is offline
College Student
AKA: Pat Cleary
patTeam241 will become famous soon enoughpatTeam241 will become famous soon enough
Send a message via AIM to patTeam241
I'm still not real clear on this, you can move upward at 10 feet per second, which roughly translates to 1.5 ft/sec. I have two questions on this.
-First, if you extend an arm, this is not influanced tremendously by gravity (unless i'm mistaken), so that should rise closer to 10ft/sec.
-Second everyone is mentioning it going 1.5 feet, on the same arm theory, you could move this for more than one second correct.
Just trying to get a little clarification.
Unread 11-01-2004, 11:21
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
It still can not excede 1.5 ft verticaly. Gravity is accerating all objects downward at a constant 9.8m/s^2. (mixed units work, right?) So anything only given the maximum velocity at the begining of the movement, like a ninja grapling hook, would only be able to travel 1.5 ft verticaly, no matter the angle.
Arms that swing up need to calculate the tip velocity and the end of the arm, and limit it to less the 10ft/s. Arms that move verticaly should take more then 1 second from the carpet to the bar, there abouts when moving from a starting height of 2-4 feet.
Wetzel
These equations are easy and you should learn them all in physics.
I've never taken physics.
Acutally, I'm going right now to see what physics classes are still open and maybe add it this semestor.
Unread 12-01-2004, 07:25
Gabe Salas Jr.'s Avatar
Gabe Salas Jr. Gabe Salas Jr. is offline
Ri3D 1.0
AKA: CrazyBear
FRC #0233
Gabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant future
The Vertical Velocity Limit is implemented so that teams do not design a robot that may attempt to launch a teathered artillery grappling hook to the bar from a long distance off the field. Although it would be nicely done by triangulating your distance using the IR sensors, and making a program that automatically adjusts angle and power to the artillery cannon on your robot. So if for some reason you missed, it was the programmers fault. Just kidding.
...and it would not be a good idea if the robot went insane during the match, and aimed the cannon to the audience...
But really, it is just for the safety of the drivers/human player, the refs/judges, and more importantly, the audience.
"Confidence, not arrogance."
Does your robot use its powers for good, or for awesome?
Unread 12-01-2004, 08:07
Nick R.'s Avatar
Nick R. Nick R. is offline
Team 1009 - Engineer
AKA: Jedi Master Talyn
None #1009 (Vikings)
Nick R. is on a distinguished road
Send a message via MSN to Nick R.
i dont think they would allow us to jump ONLY 1.5 feet if the bar is about 10 feet high and there is a restriction on the hight (60 inch) as usual..
what i suppose they mean -with regards to relative velocity is that we should use our robot base as the reference point though this would only affect the horizontal and not the vertical velocity of whatever it i being shot up(unless the robot is jumping up and down... )
i think we're going to try and go about it with a spring.. use the energy conservation concept to make sure that the release velocity is not going to be over 10 ft/s which is quite reasonable since its about 2.5-3.0 m/s
and we have to account basicaly only gravity and the tension created by the wire or cable(that will be used to pull it up) to analyze the 2 dimenional projectile motion of the hook/grabber
"simple, but not ordinary" Mr Keeting - "Dead Poets Society"
Nick .R. (Team 1009)
Unread 12-01-2004, 10:58
sevisehda's Avatar
sevisehda sevisehda is offline
sevisehda is an unknown quantity at this point
Send a message via AIM to sevisehda
The restriction on hieght only applies to the start of the match. So if your robot could double in height during the match, it could grab the bar without having to use a grapling hook.
Keep in mind the vMax only applies to a grapling hook or arm. If your entire robot were to jump then you could jump any height you wanted.
Unread 12-01-2004, 11:29
Generator of Entropy
FRC #2973 (The Mad Rockers)
I'm thinking we'll need to wait for clarification from FIRST on this one. If it's really just maximum vertical velocity (as they mentioned in the video), I could lift a cannon 10 feet and shoot a projectile at the bar for zero vertical velocity. If it's tip velocity (as in the safety concern they discussed), then the maximum distance you can shoot it up is 1.55 feet times the sin of the angle at release (straight vertical being 90 degrees and the farthest distance).
Unread 12-01-2004, 11:42
Electrical Engineer
Rookie Year: 1995
Nick,
I would imagine that this would (and should) be disqualified. The spring may be dangerous (in the view of the inspectors) if it goes off in your face...
I do not think that they want projectiles. Period.
However, they are allowing a "small" projectile that would not cause great concern to spectators, players or referees...
As a member of a team who, in 1994, made a catapult capable of launching a 7 pound ball 30-40 feet, I can testify to the incredible power which could be stored and then released by these robots.
That particular robot was a crowd pleaser but it scared the heck out of me (and the officials). The spring mechanism was made from the 10 feet of latex tubing in the kit and the bands broke under tension (a lot). Not to mention that sometimes the match would end before we fired (but the mechanism was armed) and the field team had to remove the robot and hope that it did not go off in their face.
Any engineer who can't design a "safe" thin arm to deliver a cable (attached to a winch) to the bar needs to go back to school.
Let's all stop being lawyers... When we design these systems ask " would I want my Mom (or daughter) standing next to this thing when it goes off?".
[/end soapbox]
Mike Betts
As easy as 355/113...
Unread 12-01-2004, 11:54
Wetzel's Avatar
DC Robotics
Originally Posted by Mike Betts
Nick,
FIRST dosn't need be concerned with what an engineer can or can not design safely, but what students can safely design. Teams have alot of different ways of design, from engineers and students working side by side, engineers watching and pointing things out, to no engineer support, to totaly engineer designed.
Nice play on the GP saying.
Wetzel
Vertical bar interaction Madison Rules/Strategy 5 10-01-2004 16:22
Team 68's REAL ROBOT!!! Alexander McGee Robot Showcase 137 25-02-2003 09:42
Grab bar on bottom of goals archiver 2001 0 24-06-2002 00:49
dimensions of horizontal bar archiver 2001 7 23-06-2002 23:32
How many robots on the bar in one match? archiver 2000 14 23-06-2002 22:39
