Go to Post a determined team can accomplish miracles. - Wayne C. [more]
Unread 02-02-2002, 17:29
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
Diode Question
For using the diode setup for the 2 way solenoids as described on page 11 in the robot section of the handbook what are some specs for a diode we should use? Wat are you using?
Andrew
Unread 02-02-2002, 18:43
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Take a look at the Additional Hardware List and that's what it reads:
Diode for Double Solenoid Valves
P/N: 1N4001, 1A Max, up to 4
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 02-02-2002, 18:45
Git 'em!
Thanks!!
Unread 14-02-2002, 14:11
CJMJ CJMJ is offline
#0446 (Robodogs)
CJMJ is an unknown quantity at this point
Does anyone having any suggestions on the best way to wire these up? I'm using a small terminal block right now but I'm not sure if this is legal.
Unread 14-02-2002, 22:42
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
What team #311 has done in the past is to just solder the diodes in line with the positive and negative wires between the relay and the solenoid. We then cover it all up nice and neat with heat shrink and tie it back into the wire bundle. If you can get the type of heat shrnk that hardens when it cools that will help to add reinforcement and protect the diode from breaking. Just don't forget to watch the polarity when you solder them in.
Good Luck!
Unread 18-02-2002, 07:39
junkyarddawg junkyarddawg is offline
junkyarddawg is an unknown quantity at this point
I may be incorrect, but I believe that you do not need diodes with the BLUE Spike relays. They are an "H" bridge device that when in the off position, places both output terminals at negative (ground) potential. If your loads are both connected to the negative return you don't need diodes to control current direction because one load will be between positive and negative and the other will be between negative and negative (no difference in potential, no current).
my idea of a question forum... Ken Leung General Forum 12 30-11-2002 12:17
A question from the Ford teams archiver 2000 0 23-06-2002 23:10
MnM EASY Question of the Day Winners! Mike Bonham General Forum 22 03-05-2002 21:21
Chief Delphi Site Question Mike Bonham General Forum 1 16-02-2002 22:18
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
