Go to Post As a real pig farmer*, I definitely endorse team 1902. - Andy Baker [more]
Unread 18-02-2002, 00:11
CharlieWilken CharlieWilken is offline
#0634 (Robowolves)
CharlieWilken is an unknown quantity at this point
making speed controller digital
Is it possible to wire a speed controller to a digital output. I want to put one of my motors on one of the the digital switches of the joystick and don't need to control speed. Thanks in advance
Unread 18-02-2002, 06:17
Adam Krajewski's Avatar
Adam Krajewski Adam Krajewski is offline
AKA: Jewski
None #0857 (Superior Roboworks) / Team #0068 (Truck Town Thunder)
Adam Krajewski is on a distinguished road
It's not possible to wire a speed controller to a digital output, but it is possible to create 'digital control' of a speed controller.
For a very nice explaination and complete software, go here at innovationfirst.com.
Unread 18-02-2002, 08:05
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
Yeah, if you don't want the motor going full power when you press the button, you can also just say
if p1_sw_trig = 1 then PWM12 = 150
or something like that. Otherwise just use a spike.
Unread 01-03-2002, 18:01
GhettoTech GhettoTech is offline
#0300 (Ghetto Techs)
GhettoTech is an unknown quantity at this point
Send a message via AIM to GhettoTech
Just a little note. That won't work in PBasic. PBasic's If/Then statemtents include an automatic "Goto."
If p1_sw_trig = 1 then (Goto) is implied
If p1_sw_trig = 0 then skip:
PWM12 = 150
skip:
that would be one way to work around that problem. (Similar to how the PWM limit switches are programed)
Unread 01-03-2002, 20:15
Don's Avatar
Don Don is offline
#0288 (the RoboDawgs)
Don is an unknown quantity at this point
Send a message via AIM to Don
If I'm not mistaken, most of the motors are not allowed to be hooked up to a spike. I think you can for one or two of them, but not all.
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
How do you connect the speed controller fans? Iain Electrical 7 31-01-2003 07:05
Speed controller fan replacement Rickertsen2 Electrical 11 16-01-2003 08:46
Speed Controller Limits yaman Technical Discussion 11 15-01-2003 18:40
Ugh...PWM pin vs. Speed Controller archiver 2001 1 24-06-2002 00:27
