Go to Post Don't over analyze every possibility. Studying a problem too much doesn't help any more than not studying it enough. - dlavery [more]
Unread 11-01-2004, 12:36
echos's Avatar
echos echos is offline
Jack of all trades
#1125
echos will become famous soon enough
Send a message via ICQ to echos Send a message via AIM to echos Send a message via MSN to echos Send a message via Yahoo to echos
Multiple-Motors
I was reading through the rules last night and was wondering if it would be possiable to use like for of the CIM or drill motors for a drive system. I don't know if I missed it or not in the rule book weather this is allowed. Under the section of the kit of part it says that addtional parts maybe used but are not counted as the kit of parts. I also could not find the list of parts that may or may not be used in greater quantitys.
Unread 11-01-2004, 12:40
mightywombat's Avatar
mightywombat mightywombat is offline
bins? stacking?? NOOOOO!
AKA: Bill Rosemurgy
#0857 (Superior Roboworks)
mightywombat is on a distinguished road
Re: Multiple-Motors
You were wondering if you could use 4 of the CIM or Drill motors. Right?
Bill Rosemurgy - Aspiring Programmer and Human Player (stack of 8 in <10 seconds...oh yeah... but I can't shoot for crap.)
www.team857.com
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Multiple-Motors
You may not use more or different motors than what is provided in the Kit. There last time we saw the additional parts list was in 2002. Unless it's restricted and/or does not comply with the spending limits and/or breaks any rules, you may use it. Use the part usage flow chart if you have a specific thing in mind.
Unread 11-01-2004, 13:36
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
Re: Multiple-Motors
In the manual I couldn't find that it said we can't use more than the motors provided for in the kit.. is that true?
I've asked some other people they thought that was the case.
FOr example.. they give us 9.. say I want to use 10.. is that legal?
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 11-01-2004, 13:42
Stephen P's Avatar
Stephen P Stephen P is offline
Stephen P has a spectacular aura aboutStephen P has a spectacular aura about
Re: Multiple-Motors
What are the stats for the CIM motors and the drill motors? Torque, etc. Cant find them in the manual.
You know you are an electrical engineer when you can determine voltage relative to pain with a 5% error.
Unread 11-01-2004, 13:48
Re: Multiple-Motors
Stats for the 2002 motors are here: www.team696.org/motorspecs.html The Chias, globes, and FPs, and seat, should be the same, van door, and window should be similar, drills will be different.
Unread 11-01-2004, 13:51
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Multiple-Motors
Actually Sanddrag, I believe the free-speed of the CIM motor changed from 02-03. I believe its the same as the 03' motors though. If you do a quick search, you can find the specs.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 11-01-2004, 14:11
Dave... Dave... is offline
#0005 (Robocards)
Dave... will become famous soon enough
Re: Multiple-Motors
When considering what you can use on the robot, please pay close attention to the Flowchart and the Section 5 (The Robot) of the manual.
Rule <R70> clearly states:
"Specific Items NOT allowed include:
Electric motors different from or in addition to those in the Kit.
So, no, you may not use 4 of the CIM motors. Power sources may only include the battery, compressed air, and springs, rubber bands, etc. Likewise, motors, cylinders and other devices which transmit energy are limited. This helps to keep a fair playing field for everyone.
Maybe next year Dean will include some of those special high power-to-weight ratio Segway motors in the kit!!
"...don't worry about that mechanical problem, Dave can fix it in the programming..."
Unread 11-01-2004, 17:34
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
Re: Multiple-Motors
Cory
The motor free speed did not change from 02 to 03. The only change was the output shaft.
http://www.usfirst.org/robotics/2003/specsheets.htm
Contains all the last year spec sheets, no motors have changed but the Seat motor came back, so you can find it in the older documentation.
Follow me on twitter @roboticsrob and my FTC team @griffins10092
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
Suppose you want seat motors... archiver 2000 0 23-06-2002 22:50
