Go to Post Actually, please don't put any limits on your ideas or creativity at this point. Brainstorm, innovate, and contemplate whatever ideas you might like to consider. - dlavery [more]
Unread 11-01-2004, 13:31
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
#1257 (Parallel Universe)
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
Maximum Score
Has anyone figured out the maximum score that an alliance can score in a single match?
Sorry if this question has already been presented. I searched the term 'maximum score' and found nothing relevant.
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
Unread 11-01-2004, 13:48
HolyMasamune's Avatar
HolyMasamune HolyMasamune is offline
41246017 O-('_'Q)
AKA: Y C
None #0840 (Aragon Robotics Team)
HolyMasamune is on a distinguished road
Send a message via AIM to HolyMasamune
Re: Maximum Score
the highest plausible score a team could get is 410, with 10x5 balls and 2x10 balls with a 2x multiplier in the mobile goal, 13x5 balls, 2x10 balls (stolen from the other team), and a 2x multiplier in the stationary goal and then 2 robots hanging on the bar at the end
that is unless some team can manage to balance the 2x ball on one pvc
Fear the Blade...
Unread 11-01-2004, 13:50
Damian Manda's Avatar
Damian Manda Damian Manda is offline
The Damian
Damian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud of
Send a message via AIM to Damian Manda
Re: Maximum Score
The maximum score is dependant on the number of balls that can fit in the movable and stationary goals. If you figure that out, use a scoring program like this to figure the max score out. Also, there is a difference between the max score that is possible for one team, and winning while getting the maximum ranking points (losers score). In that case, it would be:
(maxscore / 2) + 10 for your score and
(maxscore / 2) - 5 for their score
If I am thinking correctly, with you having a 2x multiplier for the one ball difference and them not.
--Damian Manda
Unread 11-01-2004, 13:51
Jake Lewis's Avatar
Jake Lewis Jake Lewis is offline
Co-Team Lead
FRC #0537 (Charger Robotics)
Jake Lewis is an unknown quantity at this point
Send a message via AIM to Jake Lewis
Re: Maximum Score
what if you could put two 2X balls on top of a goal?? would that multiply by four? it is possible to do...since the pvc bends, you could get one ball into the goal and balance another on top...
Jake Lewis
Co-Lead, Team 537
jakisnaki@hotmail.com
Unread 11-01-2004, 13:54
matt111 matt111 is offline
#1024 (McKenzie Kilabytes)
matt111 will become famous soon enough
Re: Maximum Score
well i assume u dont mean ur QPs which would be ur oppenents score. if u win that is all the matters
Aignam's Avatar
This Space For Sale
AKA: Anthony Mangia
Team Role: Scout
Re: Maximum Score
Let's avoid this particular discussion here.
Unread 11-01-2004, 13:55
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Maximum Score
560 If you can fit an infinite amount of balls into your two goals. If you score 2, 10pt balls. And 12 starting human player balls right?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 11-01-2004, 13:58
Re: Maximum Score
theres 18*5 in the ball release = 90
theres 6 starter balls per side * 5 = 30
theres 2 release balls per side * 10 = 20
thats 140 in small balls
double them all, that 280
hang both bots, that 380 points for 'your side' of the field
assuming you want you opponent to score high and leave them alone
if not, you cant get all 52 small balls in play into your two goals (the two goals can hold approx 35 balls) - so the absolute max score depends on that limtation.
Unread 11-01-2004, 14:00
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Re: Maximum Score
The 10 ball doesn't get doubled?
Kevin Li
596 - Sciclones
Unread 11-01-2004, 14:21
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
Re: Maximum Score
12 balls will fit in a mobile goal?!
Unread 11-01-2004, 14:44
Re: Maximum Score
sure it does!
Unread 11-01-2004, 14:45
Re: Maximum Score
the mobile goal will hold around 12 or 13
the big one, 23 to 25 (rough estimate without trying it yet)
Unread 11-01-2004, 14:53
IMDWalrus's Avatar
IMDWalrus IMDWalrus is offline
This is a line...
AKA: Paul
FRC #0818 (Genesis '02)
IMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to behold
Send a message via AIM to IMDWalrus
Re: Maximum Score
Why wouldn't it?
Unread 11-01-2004, 14:59
Thulium's Avatar
Thulium Thulium is offline
AKA: Michael C. Boudreau
#1068 (Operation Trojan)
Thulium is an unknown quantity at this point
Send a message via AIM to Thulium Send a message via Yahoo to Thulium
Re: Maximum Score
It seems as though most of you are missing something. You want to win to advance and the points you get are the losers. So you would need to figure not the max amount of points you can accumulate during a match, but the max amount of points you can get to beat your opponent by only 20 points assuming all balls are scored and multiplied and all robots are hanging.
This would work out as:
Your alliance - (19 x 5 + 20(bonus balls)) x 2(multiplier) + 2 hanging = 330 pts
Their alliance - (17 x 5 + 20(bonus balls)) x 2(multiplier) + 2 hanging = 310 pts
your max points = 310 pts and the win of course
Crab Drive? Hamsters are illegal but crabs are OK?
Unread 11-01-2004, 15:05
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Re: Maximum Score
Originally Posted by KenWittlief
sure it does!
Yes, well I wasn't sure since you didn't double the 2, 10pt balls in your totals.
Kevin Li
596 - Sciclones
disablity score Ryan Albright Regional Competitions 23 24-03-2003 20:35
To Maximum Oz and Two Train Joe Matt Thanks and/or Congrats 1 09-03-2003 13:03
Will There Ever Be Negative Scores? Joe Matt General Forum 30 18-01-2003 17:15
visual aids for score keeping??? cam-man General Forum 3 24-03-2002 21:37
Will your team behave badly this year? Kris Verdeyen General Forum 19 07-02-2002 08:42
