Go to Post No, I've never done 3D programming before, but I'm young and naive, so I still think I can do it. ;) - Ryan M. [more]
Unread 11-01-2004, 09:25
slavik slavik is offline
slavik has a little shameless behaviour in the past
Send a message via AIM to slavik
the 50 point not touching the field rule
If one robot picks up another so that it is no longer touching the field, but also not touching the bar, would you get the 50 points?
-- slavik
Unread 11-01-2004, 09:34
MarcusF MarcusF is offline
#0157 (Aztechs)
MarcusF is an unknown quantity at this point
Send a message via AIM to MarcusF
Re: the 50 point not touching the field rule
HANGING – A ROBOT is considered HANGING from the Pull-Up Bar if it is directly SUPPORTED by the horizontal bar and is not touching the carpet, platforms, or goals.
SUPPORTED – If the “supporting object” is removed, the ball would not remain SCORED or CAPPED and/or the ROBOT would not remain HANGING.
i would say no.
Unread 11-01-2004, 14:58
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
right, so most of your weight has to be on the bar . . what if you are hanging from the bar, but your hook (or whatever) is in a postion that leaves you hanging from the bar, but leaning against the verticle pole that supports the bar? I as this because one idea we are kicking around involves performing the chinup from the carpet to the side of the bar. . .
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
Unread 11-01-2004, 15:21
IMDWalrus's Avatar
IMDWalrus IMDWalrus is offline
This is a line...
AKA: Paul
FRC #0818 (Genesis '02)
IMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to behold
Send a message via AIM to IMDWalrus
I don't think you'd get points for that. The robot has to get up to the bar without using the two poles that support the steel bar; using them for support is also against the rules.
Disclaimer: I've been wrong at least three times when trying to answer questions since yesterday. Don't take me too seriously.
Unread 11-01-2004, 16:36
mpking's Avatar
mpking mpking is offline
AKA: Mike
#0088 (TJ²)
mpking is an unknown quantity at this point
Send a message via AIM to mpking
i would say no.
Darn, there goes that Hovercraft Idea.
Edited because the swear filter made it seem like I said something I didn't
Mike King
Bridgewater Raynham Regional High School
Team 88 TJ²
The Home of Moe
Unread 11-01-2004, 17:11
Anthony Kesich's Avatar
Anthony Kesich Anthony Kesich is offline
Programmer Turned Engineer
AKA: SonKenshin
#1097 (Site 3 Engineernig)
Anthony Kesich has a spectacular aura aboutAnthony Kesich has a spectacular aura about
Send a message via AIM to Anthony Kesich
The robot must only be supported by the horizontal bar. No robot belieth it. No vertial bar to lean againt it. Basically, if all that was left was the horizontal bar floating macially in the air, would the robot stay in the same place, or would it drop a bit and/or fall? Don't abuse the freedom given to us in the rules this year, or we will end up with giant documents produced by lawyers; take things like they are ment to be taken.
-Kesich
C is screwing up my English--I'm ending all my sentences in semi-colons;
Horray for most things! -George Carlin
"Sure, I'll play rugby. Besides, I have a lot of experience running from really big guys who want to cream me." -Me, Freshman year
Unread 11-01-2004, 17:27
animater31405's Avatar
animater31405 animater31405 is offline
AKA: ~Ka$h~
#0314 (Megatron Oracles)
Team Role: Animator
animater31405 is an unknown quantity at this point
Send a message via AIM to animater31405 Send a message via Yahoo to animater31405
Let's also talk the common sense safety rule here. Do you think they would REALLY deem that legal? Probably not for the mere fact of instability after the match, and/or damaged robot and/or field pieces due to excess weight.
~Ka$h~
Unread 11-01-2004, 17:30
AKA: SonKenshin
To what are you referring, stacking robots. When commenting on something at the beginning of a thread, please quote or say something to clairify what you are refering to.
-Kesich
Unread 11-01-2004, 17:57
AKA: ~Ka$h~
Team Role: Animator
I apologize I was referring to stacking now i am referring to attaching yourselves to the vertical bars.
Look at the technical rule <T-(i think 4?)> it says you cannot attach yourselves to the vertical bars.
~Ka$h~
Unread 11-01-2004, 18:02
AKA: SonKenshin
Is alright, i do the same thing a lot.
not attacking to the verticle bar was either a safety issue, structural issue, or it would just be too easy.
-Kesich
Unread 11-01-2004, 21:25
ErichKeane ErichKeane is offline
FRC #3210
ErichKeane is just really niceErichKeane is just really niceErichKeane is just really niceErichKeane is just really niceErichKeane is just really nice
Send a message via AIM to ErichKeane
I was just kinda thinkin about this, if all of your wait has to be hanging from the bar, what stops a team from taking a sheet of whatever, and picking up the opponents who are attempting to be on the bar? If they convert all the weight of the other bots to their own bot, they ahve successfully negated the other team's score.
And further more, what is stopping a team from hanging from another bot? IE, bot 1 from red team hangs on the bar, and another one of the bots, whether a blue one parasitically, or another red one, hangs off of this one? that would make it really easy!
And one last point, the bar is "technically" not 10 feet up. the platform underneath it is 12", so its 9 feet. the bot can go as high as 60", or 5 feet. Thats only 4 feet above the bot in some cases, not too hard of a raise to hang!
Unread 11-01-2004, 21:32
Todd Derbyshire's Avatar
Todd Derbyshire Todd Derbyshire is offline
Alumni
Todd Derbyshire will become famous soon enoughTodd Derbyshire will become famous soon enough
Robots being knocked off bars.....I know nothing of this nothing i say muahahahahahahahahahhhahaha
119=190 right?????
Unread 11-01-2004, 21:46
#1067 (SLUH)
-Kesich
I know, but what if we winch ourselves up from the carpet to the side of the platform, and just get stuck on the other side of the verticle . .. but it is clear that we are capable of hanging from only the horizontal . . . ?
Unread 11-01-2004, 21:47
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
I believe this happened during the '99 game, and was considered legal
Zan Hecht
Unread 11-01-2004, 21:52
pauluffel's Avatar
pauluffel pauluffel is offline
AKA: Paul Luffel
FRC #1127 (Lotus Robotics)
pauluffel is a jewel in the roughpauluffel is a jewel in the roughpauluffel is a jewel in the rough
Send a message via AIM to pauluffel
I'd say that if you have to use "technically" to explain your interpretation, it's wrong. These rules have been written so that the most explicit rule is the right one.
The 50 points are to be awarded to a robot that successfully hangs from the bar in the center. These points are not for a team that successfully hangs from another robot that happens to be hanging from the bar. If another team is successfully hanging from the bar and you lift them up even higher to where they are entirely supported by your robot rather than the bar, they still get the points, because if you were not there, they would still be hanging from that bar. If you are hanging from the horizontal bar, but happen to be leaning up against the upright (like if you grabbed the central bar from the side rather than from on the rasied pedestral) they'll probably check by moving your robot around the upright to see if it would suspend itself if it were on the middle and away from the uprights.
But that's just my interpretation.
Mobile/immobile objects on field Steve782 Rumor Mill 12 08-01-2004 04:15
Could the field be ice? dez250 Rumor Mill 15 03-01-2004 18:54
Team Update #20/Scoring Examples ahecht General Forum 40 05-03-2003 23:07
What happens / why do motors stall? DanL Technical Discussion 19 21-11-2002 07:19
Lego field wanted--URGENT!!! David Kelly General Forum 0 19-11-2001 12:17
