Go to Post They really should put warning signs at all entrances: "WARNING! FIRST IS CONTAGIOUS!" - KenWittlief [more]
Unread 11-01-2004, 19:12
AsimC AsimC is offline
#0871 (West Islip Robotechs)
AsimC will become famous soon enough
Problem with FRC Default code
i know there are other threads about ADC channels... but im having a problem with compiling the code. When I compile... it returns a message saying that file "adc.h" cannot be found...and the file isnt in the folder provided by Innovation FIRST. Any suggestions on what to do?
WEST ISLIP ROBOTECHS - Team 871
-2004 SBPLI REGIONAL CHAIRMANS AWARD WINNERS!
-2003 SBPLI Regional Finalists with 545 and 566
-2002 SBPLI Rookie All-Star
-Former Student Team Leader and Programming Head
Unread 11-01-2004, 19:17
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
Re: Problem with FRC Default code
Goto Project -> Build Options... -> Project.
Make sure the include path points to the folder with the compiler header files. So if your mcc18 folder is at C:\mcc18, then the header folder would be c:\mcc18\h.
Unread 11-01-2004, 19:22
It worked...Thank you so much!
How long does it take you to load the default code? vegasmcse Robotics Education and Curriculum 10 03-11-2003 21:41
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
2003 PBasic default code from Innovation First ttedrow Programming 0 06-01-2003 11:18
default code archiver 2001 2 23-06-2002 22:53
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
