Go to Post What is the coefficient of friction between butt and carpet? - JVN [more]
Unread 11-01-2004, 20:05
Drew Hopman's Avatar
Drew Hopman Drew Hopman is offline
Last Resort
FRC #0801 (HorsePower)
Drew Hopman is a jewel in the roughDrew Hopman is a jewel in the roughDrew Hopman is a jewel in the rough
Send a message via AIM to Drew Hopman Send a message via Yahoo to Drew Hopman
Re: How Does a Telescoping arm work?
Originally Posted by Frank(Aflak)
heh, you must have the same idea we do.
Ok, telescoping arms.
They are relatively simple, and this idea on making one is just something that hit me in the face while I was thinking about it. Call it intuition, or whatever. There are probably better methodes, but here goes:
You have the man (non moving) stage of you arm, right? you make the secondary (moving) stage of your arm capable of sliding up and down the main stage. Now, at the TOP of the main stage, attach a roller chain sprocket, a small nylon one with a built in bearing would probably be best on weight considerations. Now, run a chain (you can use really small chain for this) over the sprocket and anchor it at the BOTTOM of the secondary stage. Now, with the other end of the chain you can attach a motor, so the motor can real in the chain. As it does this, the secondary shaft is forced to slide up the main shaft, and you have a powered, telescoping arm. You can make the chain complete the loop if you want more control (I.E. you attach the secondary stage to one link in a continuos loop of chain . . that loop is your main stage.
You can expand this into a three stage arm if you add a sprocket at the top and bottom of the secondary shaft . . so the chain goes over the main shaft's top sprocket, under the secondary's bottom sprocket, over the secondary's top sprocket, and is anchored to the bottom of the third stage.
Another simple design I saw last year is using your elastic tubing to load your telescoping arm, and you could pull a locking pin out allowing the elastic tubing to extend the arm. You can't retract it, though.
Pneumatics could work for a short one, but I'm currently working on an inventor design of my chain one.
If you come up with something in inventor i would liket to see it. Thanks for the help.
Drew Hopman
Problems of the mind... effecting work Gadget470 Chit-Chat 20 18-11-2003 11:56
Edit doesn't work on original title posts??? Elgin Clock CD Forum Support 6 12-03-2003 17:30
Who knows how the motors [I]really[/I] work? Wetzel Chit-Chat 5 13-02-2002 21:50
Back up your work! Maddie N Chairman's Award 3 13-02-2002 06:16
Does anyone on this board work at home depot? mnkysp6353 General Forum 2 30-12-2001 13:27
