Go to Post We build because we can. - Danaca [more]
Unread 11-01-2004, 20:33
Jack21 Jack21 is offline
Jack21 is an unknown quantity at this point
Talking Re: Help! My 2003 Bot compressor won't shut off
Originally Posted by Rickertsen2
Well since the code is prolly the problem, could you post that, along with which inputs the pressure switch is connected to and which output the compressor is hooked to.
Ok, I'm speaking from memory here. but the out put cable is connected to the #3 set of pins. the input pins are connected to the top row of pins at position 2 and 3.
Is there a way to download the default code from the net directly to the Bots program port.
thanks, Jack
The Science Channel to broadcast FIRST documentary Andy Baker General Forum 49 01-03-2004 14:03
The Autodesk Design Awards 2003 – Call for Entries Brandon Martus 3D Animation and Competition 1 26-12-2003 18:40
Image Discuss: Rookie Team 1108 w/ 2003 Bot HYO CD47-Bot Robot Showcase 2 07-04-2003 23:37
Rules on making spare parts fyi DougHogg General Forum 0 02-04-2003 16:18
pic: RAGE Bot 2003 in action CD47-Bot Extra Discussion 8 30-03-2003 00:29
