Go to Post everyone in FIRST has to do the cha cha slide at least once per season to get it out of their system. Now I can go back to doing it in the privacy of my own car (if you see a red Jeep in CT swerving back and forth don't worry, it's just me doing the slide...)! - KathieK [more]
Unread 11-01-2004, 20:36
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Re: How Does a Winch Work?
Originally Posted by Frank(Aflak)
The van door motor has a worm gear built onto it. The thing about worm gears is that they cannot be backdriven, so it will accomplish the same thing that a ratchet would . . . except you can reverse direction with it, which you could not do with a ratchet unless you had a servo-powered release mechanism.
I don't know the specs for the van door, but I would assume that it has enough torque after the worm gear transmission to directly power a winch that can lift 130lbs . . if the spool diameter is small enough, anyway.
I'll look into that.
The van door motor can be back driven unless the bearing screw (at the end of the worm gear) is tightened quite a bit. The problems with doing this are:
1) You lose power output by tightening it
2) It wears out and you have to keep tightening it to keep it from backdriving
Plus it might still back drive if it sees excessive force.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Problems of the mind... effecting work Gadget470 Chit-Chat 20 18-11-2003 11:56
Edit doesn't work on original title posts??? Elgin Clock CD Forum Support 6 12-03-2003 17:30
Who knows how the motors [I]really[/I] work? Wetzel Chit-Chat 5 13-02-2002 21:50
Back up your work! Maddie N Chairman's Award 3 13-02-2002 06:16
Does anyone on this board work at home depot? mnkysp6353 General Forum 2 30-12-2001 13:27
