Go to Post If only every team had a Wildstang programmer! - Jeremiah Johnson [more]
Unread 11-01-2004, 17:52
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
#1257 (Parallel Universe)
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
Legality of Blocking Ball Chutes
Is it illegal to block the ball chutes that feed the human players?
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
Unread 11-01-2004, 17:55
animater31405's Avatar
animater31405 animater31405 is offline
AKA: ~Ka$h~
#0314 (Megatron Oracles)
Team Role: Animator
animater31405 is an unknown quantity at this point
Send a message via AIM to animater31405 Send a message via Yahoo to animater31405
Re: Legality of Blocking Ball Chutes
As far as I know, the goals are the only thing you can't block so i think that the ball chutes are all good.
~Ka$h~
Unread 11-01-2004, 18:27
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
yes the ball chutes can be blocked. But you might not want to do this becuase if you were to read the manual when it gets to how the qp and new this year RP's work you want your opposition to lose by as little as possible.
Unread 11-01-2004, 19:51
Todd Derbyshire's Avatar
Todd Derbyshire Todd Derbyshire is offline
Alumni
Todd Derbyshire will become famous soon enoughTodd Derbyshire will become famous soon enough
... U better make the most durable wings possible cuse ask 71, 365, or any other teams about this strategy parts will get broken every round. Your pit crew will have to become an ER team and try to pick up the pieces of your robot. This is also an expensive strategy and not one for the weak at heart. With that said yah its legal to do if you wanna go that route.
119=190 right?????
Unread 11-01-2004, 19:52
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Why all the robot needs to due is park it's rear-end in front of a gate and then the gate is blocked. If the robot can't handle a few hits then there is something wrong.
Unread 11-01-2004, 20:06
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
I think its gonna be worse than a "few hits"
I know if someone tried to block my ball shoot well I would ram them continuously and as hard as i could.
Penn Class 08
Unread 11-01-2004, 20:09
Trinora's Avatar
Trinora Trinora is offline
Strategery Captain
#0237 (See-ho-bots)
Team Role: Scout
Trinora will become famous soon enough
Send a message via AIM to Trinora Send a message via MSN to Trinora Send a message via Yahoo to Trinora
Unless they were moving or had a chance to be pushed away, I'd counter by herding their balls away from their shoots, moving goals, and genreally whining.
Unread 11-01-2004, 20:10
Damian Manda's Avatar
Damian Manda Damian Manda is offline
The Damian
Damian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud of
Send a message via AIM to Damian Manda
Remember though the there are two chutes in use during the match, so if you want to truly block all points for that alliance, you robot would have to cover both openings, which are about 15 feet apart. Then you would need a large extendable are, which could cause the problems with robustness.
Unread 11-01-2004, 20:16
Trinora's Avatar
Strategery Captain
#0237 (See-ho-bots)
Team Role: Scout
Or just use both alliance robots, or roll back and forth?
Unread 11-01-2004, 20:40
stuy694 stuy694 is offline
#0694 (Stuy Pulse)
stuy694 is an unknown quantity at this point
Or you could make the much talked about but never made two part robot that could break into two halves and block both ball chutes.
Unread 11-01-2004, 21:33
BlueOrion BlueOrion is offline
BlueOrion is infamous around these parts
Just drag your goal (or theirs) in front of the chute you want to block, depending on your strategy.
~BlueOrion~
Unread 11-01-2004, 21:34
If any bot tries to block our corral openings, our bot will drag them to the highest yard-arm and hang em by their wires
making sure they are touching the ground with one wheel :c0
while you are busy blocking a corral opening, the opponent bot can be busy stuffing balls in the other one, going after the 2x balls, dragging your small goal away from your team - capping your goal with a 2x ball so you cant score
why would you want to tell your own bot to go sit in the corner? Does it have a bad attitude?
Unread 11-01-2004, 21:39
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Couldn't agree more. Design to play the game, not controll it.
That's why we've damned Sparky 3.0 to the bowls of JR Tucker High.... muahahaha
Unread 11-01-2004, 21:40
Alumni
Ken I agree with you that blocking only one ball chute is not worth the time and effort. Now if you were to block both ball chutes what would you do???
May all of your balls and goals belong to us!!!!
119=190 right?????
Unread 11-01-2004, 21:58
anything that is wide enough to block both corral openings would have to be, what? 24 feet wide?
assuming your bot is in the center of those wings, thats a 12 foot lever
I dont care how much traction or weight your bot has, if I grab the end of the 12 foot lever I will drag your bot all over the field - turning the wings into pretzels in the process.
BTW - rules state nothing can detach from your bot. nothing can be tethered either
2004 Game BBFIRSTCHICK General Forum 112 19-04-2003 17:12
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
30" ball sits up there real pretty archiver 2001 18 23-06-2002 22:49
What was with the ball? purplehaze357 Championship Event 4 30-04-2002 23:15
ksc - ball bots ohm my katie86 Regional Competitions 8 10-03-2002 22:52
