Go to Post FIRST is not a "buy it and build it kit robot" competition. - sanddrag [more]
Unread 11-01-2004, 20:06
Jack21 Jack21 is offline
Jack21 is an unknown quantity at this point
Question Help! My 2003 Bot compressor won't shut off
Ok, I know the game for 2004 is on, but we need our old Bot operable for fund raising etc.
The Bot was working fine unti (I think) somebody tinkered with the default program. Now all systems still work, but the compressor won't shut off at 120 psi. I have swapped out the spike, the 3 wire cable, the fuses etc.. checked the cut off switch cable for breaks.( repaired this cable with almost all broken strands at connector end of cable). When pressure hits 120 psi the switch shows the circuit opens.( when checked with an ohm meter at the connector that attaches to the Robot controller).
Now I'm not even sure where the cut off switch is supposed to be connected to the Robot controller. What pins should I be connected to on the controller. any other help would sure be appreciated. Hadn't counted on wasting time on this old Bot when we need to devote energy to this years machine.
Unread 11-01-2004, 20:09
Umm Errr...
Re: Help! My 2003 Bot compressor won't shut off
Well since the code is prolly the problem, could you post that, along with which inputs the pressure switch is connected to and which output the compressor is hooked to.
1139 Alumni
Unread 11-01-2004, 20:13
Noah's Avatar
Noah Noah is offline
Code Monkey
#0861 (The Gondobots)
Noah has a spectacular aura aboutNoah has a spectacular aura about
Send a message via AIM to Noah
well, it depends on your code. This might help:
rc_sw1		VAR rc_swA.bit0		'Pin 1
rc_sw2		VAR rc_swA.bit1		'Pin 2
rc_sw3		VAR rc_swA.bit2		'Pin 15
rc_sw4		VAR rc_swA.bit3		'Pin 16
rc_sw5		VAR rc_swA.bit4		'Pin 4
rc_sw6		VAR rc_swA.bit5		'Pin 5
rc_sw7		VAR rc_swA.bit6		'Pin 18
rc_sw8		VAR rc_swA.bit7		'Pin 19
rc_sw9		VAR rc_swB.bit0		'Pin 7
rc_sw10		VAR rc_swB.bit1		'Pin 8
rc_sw11		VAR rc_swB.bit2		'Pin 21
rc_sw12		VAR rc_swB.bit3		'Pin 22
rc_sw13		VAR rc_swB.bit4		'Pin 10
rc_sw14		VAR rc_swB.bit5		'Pin 11
rc_sw15		VAR rc_swB.bit6		'Pin 24
rc_sw16		VAR rc_swB.bit7		'Pin 25
All other pins are ground.
If you can post the code that controls the compressor, I can tell you how to fix it if you know which pin you are plugged into now. (You also have to give me the alias deifinitions of any aliases used in the code)
"It's broken? NOOAAHH!!! This is your doing, isn't it!"
"We can fix it in the software!"
"It's a BROKEN GEAR!"
Unread 11-01-2004, 20:33
Talking Re: Help! My 2003 Bot compressor won't shut off
Ok, I'm speaking from memory here. but the out put cable is connected to the #3 set of pins. the input pins are connected to the top row of pins at position 2 and 3.
Is there a way to download the default code from the net directly to the Bots program port.
thanks, Jack
Unread 11-01-2004, 21:02
Unhappy Re: Help! My 2003 Bot compressor won't shut off
Well... this is like a foreign language to me.. I have no idea what code is in the controller. I know the cut off switch is wired to the top row of pins 2and on the digital input and the 3 wire cable is attached to the #3 set of pins from on the relay outputs. Is there a way to connect this thing to the computer and reset the default code?
appreciate you help.
Unread 11-01-2004, 21:08
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
Although it is not the most elegant solution, you can still run without the shutoff for presentations. If you can't get it fixed before a presentation, the overload valve should keep the pressure below 135psi. Note: you can not do this in the competion and should really try to fix it, but hey, if your team needs money...
Unread 11-01-2004, 21:49
RoboCoder RoboCoder is offline
#1002 (Circuit Runner)
RoboCoder is on a distinguished road
Send a message via AIM to RoboCoder Send a message via Yahoo to RoboCoder
since you're talking about last year's bot, I am assuming you are using last year's control system, and last years programming language (PBASIC). if this is the case, then add these lines to your code, just before the serout command:
select rc_sw2
case 1
relay3_fwd = 1
relay3_rev = 0
case 0
relay3_fwd = 0
relay3_rev = 1
endselect
this is assuming that the pressure switch is normally closed (when 120 psi has NOT been reached). If the compressor doesnt turn on at all, swap the lines "case 1" and "case 0". hope this helps!
You might be an Engineering Major....
if you'll assume that a "horse" is a "sphere" in order to make the math easier
if you know vector calculus but you cant remember how to do long division
if it is sunny and 70 degrees outside, and you are working on a computer
Unread 10-02-2004, 20:03
Greg's Avatar
Greg Greg is offline
FRC #1075 (Sinclair Sprockets)
Greg is on a distinguished road
Send a message via ICQ to Greg Send a message via MSN to Greg
If you really have no idea what pins the pressure switch was connected to, and you dont have access to the source code from last year, all you have to do is remove the spike, and wire the compressor directly to the fuse through the pressure switch. While illegal at a competition, this will most definitely work. In fact, we showed up to a regional like this last year and had to change it to pass inspection (we didnt know this was illegal).
Unread 10-02-2004, 20:14
Do you understand why it is illegal or just that it is?
The Switch is rated for .5 amps (IIRC) while the pump can draw 10 amps. You may get away with it for a while, but it certainly isn't a good practice.
Unread 10-02-2004, 22:31
Originally Posted by RoboCoder
select rc_sw2
  case 1
    relay3_fwd = 1
    relay3_rev = 0
  case 0
    relay3_fwd = 0
    relay3_rev = 1
endselect
I don't think applying reverse polarity to a compressor will shut it off. The last line before the endselect should probably say relay3_rev = 0, setting both wires to the compressor to ground.
Unread 11-02-2004, 12:24
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
Yeah, I believe this is your problem. You want the output of the spike to be zero, rather than -12 volts
The Science Channel to broadcast FIRST documentary Andy Baker General Forum 49 01-03-2004 14:03
The Autodesk Design Awards 2003 – Call for Entries Brandon Martus 3D Animation and Competition 1 26-12-2003 18:40
Image Discuss: Rookie Team 1108 w/ 2003 Bot HYO CD47-Bot Robot Showcase 2 07-04-2003 23:37
Rules on making spare parts fyi DougHogg General Forum 0 02-04-2003 16:18
pic: RAGE Bot 2003 in action CD47-Bot Extra Discussion 8 30-03-2003 00:29
