#12
Re: Make the bar lower to get on?
Actually, thinking about it a little more, it might be quite easy. As long as you know how big the hole is, where it is located, and the type of bit required. You place you bit the exact height it needs to be for the hole. You can then push your robot against the platform and slide along it until the bit falls into te hole. With a little turning, the bit should drop into the spot to be able to lower the bar.
| Raising the bar...or lowering it? | Ben Mitchell | General Forum | 29 | 13-01-2004 03:30 |
| Official Forum frustration. | Madison | General Forum | 9 | 01-02-2003 19:42 |
| Please help make the Nationals in Houston AWESOME ... You be the Tournament Director | Natchez | General Forum | 42 | 13-12-2002 18:50 |
| Grab bar on bottom of goals | archiver | 2001 | 0 | 24-06-2002 00:49 |
| Ruler of the Ramp Q & A | archiver | 2000 | 0 | 23-06-2002 22:40 |
