Go to Post If your goal is to win matches... Pick the most capable candidate. If your goal is to change lives... Sometimes you pick those that need the most change. - IKE [more]
Unread 18-02-2002, 08:52
Dreistul Dreistul is offline
#0440 (Huskies)
Dreistul is an unknown quantity at this point
Send a message via AIM to Dreistul
Zone Arm damage
Here's a question about the zone arms that other threads are discussing:
If a opponent robot has a zone arm extended and it's blocking the movement of your robot or the goal (not entangled in either), if you move your robot through their arm and damage their arm, would you be disqualified for damaging the other robot, or will the judge overlook it as a bad design on their part? The robot (ALL of the robot) is supposed to be designed to take some abuse; standard pushing and shoving doesn't seem like a malicious act, even if it's done a flimsily designed zone arm.
Other thoughts?
Unread 18-02-2002, 14:37
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
It's all going to depend on how the robot intersects with the arm. If you repeatedly ram the arm, that's probably not poor construction. If you run into it and it falls off or it can survive a pushing match, it's probably poor construction. A lot of it is going to come down to the opinion of the judges.
Matt
Unread 18-02-2002, 16:11
Monkey's Avatar
Monkey Monkey is offline
Monkey is an unknown quantity at this point
The first strategy/robot type our team thought of doing was a one that would extend itself to block-off the playing field.
"I hear it’s amazing when the famous purple stuffed worm in flap-jaw space with
the tuning fork does a raw-blink on Hari-Kari Rock. I need scissors! 61!"
Unread 18-02-2002, 23:35
Matt Ryan Matt Ryan is offline
#0069 (Team HYPER)
Matt Ryan is an unknown quantity at this point
Send a message via ICQ to Matt Ryan Send a message via AIM to Matt Ryan
Accidental damage if you are merely trying to move across the playing field.
If repeatedly rammed, still not malicious--you're trying to get to the other side.
If broken, and then repeatedly rammed, then thats malicious.
Picture of robot starting zone? Jeff Rodriguez General Forum 2 06-01-2003 22:37
Reflected Inertia? archiver 2001 9 24-06-2002 03:50
anyone use an arm to help balance archiver 2001 8 24-06-2002 02:46
Controlling Arm travel - Limit Switch or Mechanical Stop? archiver 2001 8 23-06-2002 23:55
telescoping arm & ten second rule Ben Mitchell Rules/Strategy 4 18-02-2002 21:37
