Go to Post Did you NOT see the last caption contest???? - Tom Schindler [more]
Unread 12-01-2004, 00:05
Celestial Rain Celestial Rain is offline
Celestial Rain is an unknown quantity at this point
Re: Good strategy?
Hey guys! I have just been reading this and I came up with an idea, which im not sure if its illegal. U know how u can cover your side with a net or pole? Well have u thought about doing the same exact thing on the other side of the field (with a telescopic pole). I mean the rules state that you cannot goal tend. Or block a ball on its fall. But wat about doing it to the ball slots on the other side. =P Its just a thought
Unread 12-01-2004, 00:07
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Re: Good strategy?
That has been debated here:
http://www.chiefdelphi.com/forums/sh...threadid=23651
Unread 12-01-2004, 00:08
tkwetzel's Avatar
Good Luck Teams!
AKA: Tyler Wetzel
Re: Good strategy?
That last post of mine was referring to blocking the ball chutes.
Unread 12-01-2004, 00:15
Re: Good strategy?
ok well i read the post and understood it. My next question is it good to grab the 10 pt ball in the autonomous mode or hit it
Is it illegal to smack the pvc bars underneath the ball and try to get it inside the arena?
Also i noticed that the upper deck is a foot high. With torques involved, is there a good way to get up there?
Unread 12-01-2004, 00:31
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
Re: Good strategy?
Its a foot high off the ground, so if you are on the first platform(which is 6" off the floor) then you only have to go up another 6" to get to the top platform
Penn Class 08
Unread 12-01-2004, 12:29
stuy694 stuy694 is offline
#0694 (Stuy Pulse)
stuy694 is an unknown quantity at this point
Re: Good strategy?
I like the idea, I also mentioned it in a post http://www.chiefdelphi.com/forums/sh...ad.php?t=23680.
But I'd also like to ask, how often as robots gonna hit/knock down both trigger balls in autonomous mode as there is like a foot of space between the two. Cuz if its likely that your opponent will trigger both ball releases then this design has a much better chance of winning even if your partner can't trigger the ball release.
Unread 12-01-2004, 12:45
animater31405's Avatar
animater31405 animater31405 is offline
AKA: ~Ka$h~
#0314 (Megatron Oracles)
Team Role: Animator
animater31405 is an unknown quantity at this point
Send a message via AIM to animater31405 Send a message via Yahoo to animater31405
Re: Good strategy?
Ok. Now I have to make you look at the flip side. The cost, weight, power, and size of the robot are HUGE factors if you want to make a device like this especially the height issue. Not to mention how easy it is to break that. And, you may have a problem if you want to get the 50 points there for the taking. It's a good startegy if your robot is not able to do anything else for about a minute in the match.
~Ka$h~
Unread 12-01-2004, 18:42
tkwetzel's Avatar
Good Luck Teams!
AKA: Tyler Wetzel
Re: Good strategy?
It is easy to design a catch system with enough power, strength, and size to accomplish this. And it should not be that exspensive either. And it still a good strategy, even if you still want to do other stuff.
Unread 12-01-2004, 18:52
Re: Good strategy?
now you are jumping from the big WHAT (should our robot do) to the big HOW (will the robot do that)
funny thing about engineering - the biggest mistakes are often not going after the best WHAT - taking on the best concept and finding a way.
I promise you - there will be bots at the events that find a way to catch every ball before it touches the floor - because they will focus on that, they will keep at it till an elegant solution pops into their mind at 3AM - and when you see it your jaw will hit the floor and you will spontainously say "Why didnt we think of that!"
Why - cause you gave up on it too soon - the solution didnt come to you in 30 minutes or less, so you thought it was too: hard, complicated, expensive...
Once you have the best answer to WHAT your robot should do, its time to start kissing frogs - keep thinking up possible solutions - most of them will be frogs - but sooner or later you will kiss one and it will turn into a beautiful thing.
Anything worthwhile takes a little time!
Unread 13-01-2004, 01:00
Jedi Padawan's Avatar
Jedi Padawan Jedi Padawan is offline
Electrical Expert Student
AKA: Dan Howell
Jedi Padawan is on a distinguished road
Send a message via AIM to Jedi Padawan
Re: Good strategy?
We thought about that too in conjunction with a few other doo dads we could attatch and then realized how expensive in time for us it would be to produce that so we canned it. (Despite the fact I still think it's a relatively good strategy)
It's all fun and games till the bosh motor breaks.....
Unread 13-01-2004, 01:06
Re: Good strategy?
what do you mean by a 'runner'?
a tethered bot? there is an entanglement rule this year - having a detachable baby bot on a wire probabally wont be allowed.
Teams that build 2 robots PHIL358 General Forum 22 09-04-2005 11:45
"Collusion" and De-Scoring JAlpert General Forum 20 04-04-2003 14:13
A good driver makes his own strategy. What do you think? archiver 2001 26 24-06-2002 02:21
What's the best qualifying rounds strategy? Ken Leung General Forum 24 24-03-2002 18:25
Battle Cry At WPI CMC Off-Season Events 14 14-06-2001 22:49
