Go to Post You can build bridges, or you can burn them. The choice is yours. - dlavery [more]
Unread 11-01-2004, 21:13
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Yaw Rate Sensor
Looking at the Kit of parts, I do not see a yaw rate sensor this year. Is this correct?
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 11-01-2004, 23:23
Re: Yaw Rate Sensor
you can buy yaw rate sensors from one of the electrical suppliers though - they are not too expensive.
Unread 12-01-2004, 00:21
bobtheblob bobtheblob is offline
bobtheblob is an unknown quantity at this point
Re: Yaw Rate Sensor
Why are things so expensive on newarkinone.com? The Angular rate sensors sold on that site all exceed 150 dollars. I even saw some pushbutton switches for 20 dollars each.
Maybe I'm mistaken about the price, but that is ridiculous.
Unread 12-01-2004, 00:38
Anthony Kesich's Avatar
Anthony Kesich Anthony Kesich is offline
Programmer Turned Engineer
AKA: SonKenshin
#1097 (Site 3 Engineernig)
Anthony Kesich has a spectacular aura aboutAnthony Kesich has a spectacular aura about
Send a message via AIM to Anthony Kesich
Re: Yaw Rate Sensor
the manual was slightly decieving. It gave the wiring for a yaw rate sensor, but it wasn't on the parts list. Here's to FIRST recycling its manuals!
-Kesich
C is screwing up my English--I'm ending all my sentences in semi-colons;
Horray for most things! -George Carlin
"Sure, I'll play rugby. Besides, I have a lot of experience running from really big guys who want to cream me." -Me, Freshman year
Unread 13-01-2004, 17:41
Adam Krajewski's Avatar
Adam Krajewski Adam Krajewski is offline
AKA: Jewski
None #0857 (Superior Roboworks) / Team #0068 (Truck Town Thunder)
Adam Krajewski is on a distinguished road
Re: Yaw Rate Sensor
Newark is expensive, but they have everything. Just the nature of the beast, I suppose.
To compare prices between different distributors, try http://www.findchips.com/. It is an EE's bestfriend.
"My favorite programming language is solder."
- R A Pease
Unread 13-01-2004, 22:35
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Yaw Rate Sensor
Future electronics sells an Analog Devices angular rate chip. Search the fori for ADXRS300 & ADXRS150.
Others have used these with good success.
Joe J.
P.S.
My mind had them at $30 or so, but looking on the Future website they are more like $50 (and that is in a "tray" where you may have to buy 20 - ouch!). The ones pre-mounted on a PCB are almost $100. Pretty tough to use them at that price!
I KNOW Newark has them in my catalog, but I can't find them on their website (man their part number search could use some cleverness built into it -- dumb as a post, it is). If I find it in a old catalog and they sell it to me at that listed price, do you suppose I could still use it legally? -- I suppose not. Why does FIRST even HAVE that $200 electronic limit? Why not have a limit on what you can spend on bushings? It makes about as much sense.
Looks like Digi-key has the chips too. $50 is the going rate for the sensor in a surface mount package. I hope I can afford one or two.
Unread 13-01-2004, 23:12
Skabana159's Avatar
Skabana159 Skabana159 is offline
Robotics and Field Hockey
AKA: Jesse C. Owens
#0159 (Alpine Robotics)
Skabana159 is on a distinguished road
Send a message via AIM to Skabana159
Re: Yaw Rate Sensor
It makes sense, because they do not want you to have a complex component that will give you a terrible advantage. Why not buy another IFI controller? You could double your PWM outputs and inputs.
A $300 bushing is not going to give you a ridiculous advantage, or at least in the scope that a $300 electronic component might.
Plus, there is a limit on bushings--- $3500.
"What most people do not understand is that the Buddha, the Godhead, resides just as comfortably in gears and circuits as in hills and trees. To believe otherwise is to dilute the Godhead."
-Robert Pirsig, Zen and the Art of Motorcycle Maintenance
Unread 13-01-2004, 23:20
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Re: Yaw Rate Sensor
I don't want to get into a philosophical debate about the custom circuit spending limit, but it wouldn't technically be legal to do what you suggest. The rules state that a custom circuit may not directly generate the PWM signals for the motor controllers.
Unread 14-01-2004, 01:27
WizardOfAz's Avatar
WizardOfAz WizardOfAz is offline
Lead Mentor
AKA: Bill Bennett
FRC #1011 (CRUSH)
WizardOfAz will become famous soon enough
Send a message via AIM to WizardOfAz
Re: Yaw Rate Sensor
I bet there are lots of teams that have one from last year and never used it. Maybe you can make a deal.
Unread 14-01-2004, 14:53
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
Re: Yaw Rate Sensor
Go to the manufactures web site and see if they will send you an engineering sample for free. A lot of companys have this service. This may keep your spare parts cost down.
Tim Tedrow
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 14-01-2004, 17:16
AKA: Dr. Joe
FRC #0088 (TJ2)
Donatations don't make 'em legal!
The cost accounting rules in the kit require that you account for the catalog value of the parts even if you had them donated.
<R61>
A FIRST robot may be built using only
Items provided in the FIRST supplied Kit of Parts (or their exact replacement part)
Allowed Additional Parts and Materials as defined in this section in quantities consistent with the Cost Accounting requirements
<R71>
Additional electronic components for use on the robot must be currently available from Newark InOne (http://www.newarkinone.com), Future Active(http://www.future-active.com) or Digi-Key Corporation(http://www.digikey.com). The total catalogue value of dditional electronic components must not exceed $200.00 USD. This cost is counted as part of the $ 3,500 limit. No single electronic component shall have a catalog value of over $100.00 USD.
Note the references to "currently available" & "total catalogue value." How you actually obtained something is immaterial.
The way I read the rules, they have to be in the current catalogs and you have to meet the cost accounting limits with the listed prices.
Joe J.
Unread 14-01-2004, 17:37
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: Donatations don't make 'em legal!
Can we use the gyro from our previous year robot? It's just sitting on there looking pretty after all.
Matt Krass
Unread 14-01-2004, 20:39
rishi224 rishi224 is offline
rishi224 is an unknown quantity at this point
Re: Yaw Rate Sensor
Joe J.
P.S.
the ones u wrote about r just chips. how do u plan to put them up on the robot??
if u have any info plz post it.
Unread 14-01-2004, 21:55
Re: Yaw Rate Sensor
FIRST nicely provided us with a big chunk of protoboard. The chips to which Dr. Johnson referred come in either BGA (ball grid array, terrible for us) or DIP (dual inline pin, very good for us) packages. I assume he plans to put them in some sort of enclosure and attach them to the robot using any of a number of available methods (nuts and bolts, epoxy, zip ties, it doesn't really matter).
Unread 15-01-2004, 00:47
Caleb Fulton's Avatar
Caleb Fulton Caleb Fulton is offline
Z = Z^2 + C ......WHEEEE!
AKA: aXvXiA
#0461 (West Side Boiler Invasion)
Caleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura about
Send a message via AIM to Caleb Fulton
Yes, you should be able to, as the gyro's output is just an analog voltage between 0 and 5v.
Anyone know where to buy a spare yaw rate sensor? Jim Meyer Technical Discussion 11 30-03-2003 21:18
Yaw rate sensor pin-out GregT Electrical 8 18-02-2003 00:07
Yaw Rate Sensor to 90 degrees? Bruce C. Programming 4 11-02-2003 00:36
Yaw rate sensor (gyro for the layperson) Kris Verdeyen Rules/Strategy 4 14-01-2002 00:41
Yaw Rate Sensor ImmacGirl_03 Technical Discussion 2 10-12-2001 15:15
