Go to Post As a real pig farmer*, I definitely endorse team 1902. - Andy Baker [more]
Unread 11-01-2004, 18:05
me9342 me9342 is offline
me9342 is an unknown quantity at this point
Hanging vs. Manipulating 2x balls
Say you can pick one of the above - your robot will be able to either hang from the bar or be able to place the 2x multipliers on a container. (As much as I'd like both, I think that it would be both impracticle given the time limit, and impossible due to the weight constaints.) Which would you pick? I myself would go with a 2x ball manipulator, as it has the higher potentional for total points (if you have 11 balls or more in one container, you would get more points for having it capped than you would for leaving it uncapped and hanging). I realize that if you dont get many balls, or have a really bad human player, you won't get many points for capping, so I can see some reason in just taking a flat 50. I wanted the opinions of others, though.
Unread 11-01-2004, 18:07
animater31405's Avatar
animater31405 animater31405 is offline
AKA: ~Ka$h~
#0314 (Megatron Oracles)
Team Role: Animator
animater31405 is an unknown quantity at this point
Send a message via AIM to animater31405 Send a message via Yahoo to animater31405
Re: Hanging vs. Manipulating 2x balls
Nothing's impossible. If you have arm that has the ability grab ahold of the high bar using the SAME arm pieces to grab the 2x ball it is extremely possible to do both. That is the way we are talking about going.
~Ka$h~
Unread 11-01-2004, 18:14
ok, its not impossible, (we came up with the beginning of an idea that could do both), but for this purpose, assume you could only do one.
Unread 11-01-2004, 18:16
AKA: ~Ka$h~
Team Role: Animator
I would probably go for hanging because there's a better chance that someone else will want to go for the ball and if they don't they can get your alliance to score 100 easy points.
~Ka$h~
Unread 11-01-2004, 18:20
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Wouldn't they only be able to score 50 points?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 11-01-2004, 18:28
andy's Avatar
andy andy is offline
Alumni
FRC #1139 (Gear Grinders)
Team Role: Student
andy is a jewel in the roughandy is a jewel in the roughandy is a jewel in the rough
Send a message via AIM to andy
us too
Unread 11-01-2004, 18:39
Mercutio Mercutio is offline
Atticus Finch Wannabe
#1213 (The Grobots)
Mercutio is on a distinguished road
The thing about the multiplier balls is that it seems pretty easy to push them off, while if you got a good grip on the bar you would be practically immovable. You'd get knocked around a lot, of course, but you'd stay on.
If you could make a multiplier manipulator that could grab the bar too, like animater31405 said, you might do *very* well. I think the key in this competition will be doing a lot of things with the same part. If you try to make a separate mechanism for everything, you'll end up hitting the size/weight limit about a third of the way in. If you try to specialize, you'll come up against an opponent who can defend against your particular strength.
~Aaron
P.S. I know someone will show up at regionals with a robot that whacks hanging bots with a baseball bat. LOL, piñata time! Send pictures!
"If we knew what we were doing, it wouldn't be called research, would it?"
—Albert Einstein
<X3 What can I do? You broke the tie wraps that were holding together my heart. ^_^
Unread 11-01-2004, 18:42
yangotang's Avatar
yangotang yangotang is offline
#0253 (MRT)
yangotang is on a distinguished road
Send a message via AIM to yangotang
Don't forget that hanging is really two challenges at once:
1)being able to get up to the bar
2) latching onto the bar
While these two challenges may seem easy to you, i feel that creating a method to get up to the platform below the bar is tough; i'm convinced that a 2x ball remover is the easiest strategy.
Unread 11-01-2004, 18:46
#1213 (The Grobots)
No argument there. But removing the things is a *lot* eaiser than putting them back on...
If we actually get ours working, I'll show you how it's done.
~Aaron
—Albert Einstein
Unread 11-01-2004, 21:27
westfalia's Avatar
westfalia westfalia is offline
Custom User Title
AKA: Doug
FRC #2234
westfalia is on a distinguished road
Send a message via AIM to westfalia
the problem with the 2x ball is that it can't be your only objective. I agree that you've got to use one thing on the robot for many functions. but it is hard enough deciding upon a good idea to get to the top of the bar!
~Doug
Former 341 team member... Now attending Drexel University and mentoring team 2234!
Unread 11-01-2004, 21:40
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
#1257 (Parallel Universe)
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
By far not impossible. A slightly modified version of Team 25's 2000 robot, Cradle Robber, could more than likely do that.
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
Unread 11-01-2004, 21:52
Double your pleasure
Double your fun!
Unread 12-01-2004, 01:42
Greg Powers Greg Powers is offline
#0814 (MegaForce Squadron)
Greg Powers is on a distinguished road
As a member previously on Team 232 I actually still have the video footage of that bot in action in the 2000 finals and we are seriously considering doing just that. (moding that design)
It would be difficult, but fairly ideal for this years game if executed well.
Sincerely,
ME
Unread 12-01-2004, 06:00
Aignam's Avatar
This Space For Sale
AKA: Anthony Mangia
Team Role: Scout
It is a good design, and might be quite applicable for this year's game. The only problem that I see is that in 2000, we cherry-picked balls from our opponent's goal and put them in our goal or moved balls from our goal to theirs, controlling the score. In this game, that would be quite illegal. Beyond controlling the 2x Ball and hanging on the bar at the end of the match, the robot would be pretty useless. Unless, of course, you build it with a robust drivetrain, such that it could plow balls into the human player corral with ease. But is it safe to build a robot that can do more or less everything?
Unread 12-01-2004, 08:52
Mikey229's Avatar
Mikey229 Mikey229 is offline
Give It To Mikey He'll Eat It!
#0229
Mikey229 is an unknown quantity at this point
I think doing BOTH is a very good idea as yes you can do them both with the SAME arm...
Small balls in 2001 competition archiver 2001 10 24-06-2002 03:59
Team 188 Pictures - four big balls anyone? archiver 2001 6 24-06-2002 01:03
Numbers for thought: Are 10 black balls worth 30 seconds? archiver 2001 6 23-06-2002 22:42
Will ANYONE mess with the black balls? archiver 2001 0 23-06-2002 22:35
Just curious, how many robots could shoot or toss balls into the goal? Alan Ing General Forum 7 13-05-2002 19:09
