Go to Post I understand that Dean Kaymen has now invented a super "sniffer" that can scout-out anyone within hearing distance that is remotely-involved with FIRST. - dhitchco [more]
Unread 11-01-2004, 21:20
Jeremy's Avatar
Jeremy Jeremy is offline
AKA: Jeremy Medendorp
FRC #0968 (RAWC Robotics Alliance of West Covina)
Jeremy is on a distinguished road
Send a message via AIM to Jeremy Send a message via MSN to Jeremy
How many Pneumatics pistons can we use?
Does any one know how many Pneumatics pistons we are aloud to use
Jeremy Medendorp
College Mentor
______________________________
2003- Arizona Regional Winners
2003- Southern California Regional Finalist
2004- Southern California Regional Semi-Finalist
2004- National Quarter-Finalist Newton Division
2005- Southern California Regional Finalist
Unread 11-01-2004, 21:22
M. Hicken's Avatar
M. Hicken M. Hicken is offline
Where am I?
AKA: I AM PACO
#0219 (Team Impact)
Team Role: Driver
M. Hicken is a jewel in the roughM. Hicken is a jewel in the roughM. Hicken is a jewel in the rough
Send a message via AIM to M. Hicken
Re: How many Pneumatics pistons can we use?
in years past, it was 3 @ 60psi
i believe this year we can use up to 4 running @ 120psi
someone correct me if im wrong
If duct tape isnt the answer you're looking for, you're asking the wrong question
There is no such thing as a stupid question, there are just a lot of inquisitive idiots
Personal rookie year: 2002
Team Impact 219: 1998
Unread 11-01-2004, 21:29
RoboCoder RoboCoder is offline
#1002 (Circuit Runner)
RoboCoder is on a distinguished road
Send a message via AIM to RoboCoder Send a message via Yahoo to RoboCoder
from the "robot" section of the rules manual, section 5.2.9, Pneumatics System Requirements, rule R54, bullet #3:
There is no limit to the number of solenoid valves, air cylinders, and connecting fittings you may
use on your robot. They must, however, be “off the shelf” pneumatic devices rated by their
manufacturers for pressure of at least 125psi. Besides the “free” pneumatic components listed on
the Pneumatic Components Order form, you may use additional air cylinders or rotary actuators,
however, they must be identical to those listed on the Pneumatic Components Order form, and
obtained from a Bimba or Parker Hannifan distributor.
So, you can use as many as you like it appears
As for pressure, you can have 125 psi in the tanks, but still only 60 psi working pressure.
“Working” air pressure on the robot must be no greater than 60psi. All working air must come
from the Norgen adjustable pressure regulator, and all other pneumatic components must be
downstream from this regulator. A pressure gauge must be placed adjacent to the pressure
regulator and display the downstream pressure.
(same rule, 2nd bullet)
You might be an Engineering Major....
if you'll assume that a "horse" is a "sphere" in order to make the math easier
if you know vector calculus but you cant remember how to do long division
if it is sunny and 70 degrees outside, and you are working on a computer
Last edited by RoboCoder : 11-01-2004 at 21:30. Reason: wanted to answer both questions in 1 post instead of 2
Unread 11-01-2004, 23:10
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
You can only have 120 PSI in your accumulators, to clarify. What the rule really says is that all components must withstand 120 PSI of pressure.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 12-01-2004, 06:58
Actually, the cylinders can only be run at 60 psi, (after the air has gone through the regulator). When buying components, FIRST wants all teams to buy equipment that CAN take 120 psi, as a safety issue in case of a failure. That is why they say "off the shelf" pneumatic devices must be "rated for" at least 125 psi, but "working pressure" is a maximum of 60psi. So, if your equipment is designed to handle 125 psi, and you're only using 60 psi (according to the rules), then the chance of having a failure of the equipment itself is significantly decreased. So, 120 psi in the tanks, then the regulator which knocks it down to 60, then your solenoids and cylenders that use the 60 psi. Hope this clarifies.
Unread 12-01-2004, 08:37
generalbrando's Avatar
generalbrando generalbrando is offline
Build, Break, Repeat
AKA: Brandon Mensing
FRC #0246 (Overclocked)
generalbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to behold
Send a message via AIM to generalbrando
Those last two posts seem to conflict with each other. I think I can clarify. Storage tanks which connect to the pump upstream of the Norgen regulator (the one set to 60 psi) can have 120 psi. This is not "working" pressure, it is the storage. The rest of the system downstream in the working section is 60 psi. I am referring to the pressure used, not the capability of the products used.
As always, if I'm horribly wrong, forgive me and correct me. Hope this helps. Good luck to all!
Lead Mentor of Team #246, Boston University Academy and Boston University, Overclocked
www.burobotics.org
pneumatics adamoneDB04 General Forum 1 28-01-2003 11:59
Pneumatics hose Brett W Kit & Additional Hardware 10 09-01-2003 15:35
What are pneumatics? Aignam Pneumatics 23 16-10-2002 21:17
pneumatics tank archiver 2000 2 23-06-2002 22:43
Should all three pneumatics pistons have been received? Jordan A. General Forum 6 08-01-2002 13:48
