Go to Post "Defense wins qualifying rounds, offense wins championships." - Paul Copioli [more]
Unread 12-01-2004, 09:26
Mr. Ivey's Avatar
Mr. Ivey Mr. Ivey is offline
Mark Ivey
AKA: Mark
Mr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of light
Send a message via AIM to Mr. Ivey
If you would "pull-up"...
I was just wondering if what motors people would use in order to raise their bot up on the pull-up bar in compeititon. I know you need a good drive motor, so let's leave out the Bosh Drill motors, for doing a pull up. I'm just thinking that this will help not only me in my design work, but other teams, especially rookies, to find out what kind of power they need in order to lift the 130 bot off the ground.
Thanks everyone!
Ivey
When you tell a student not to do it, you shouldn't do it. Or else you will wind up with a 3/8" drill bit in your finger... Like I did...
Unread 12-01-2004, 09:31
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
Re: If you would "pull-up"...
in 2000, 312 "pulled up" every match using two globe motors....it worked very well.
Electrical Engineer
Rookie Year: 1995
With the proper gear ratio, any motor will work... It just may take a little longer.
Mike Betts
As easy as 355/113...
Unread 12-01-2004, 09:43
Mr. Ivey's Avatar
Mark Ivey
AKA: Mark
Very true, but you want to get up their quickly. So what motors would you use to get up quickly? Also it costs money to build a gear box, money some teams may not have to spend.
Ivey
Unread 12-01-2004, 09:47
in 2000, 330 used 2 fischer price motors with the included gear boxes. The diameter of the winch we used was about 3". Teams constantly commented on how fast we got our arm up there, and how fast we pulled up. we used a detent mechanism to clamp once we were up there, since the fisher price motors would slowly backdrive otherwise.
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
It really depends how you're going to lift yourself. If you were making a winch of some sort, Id say the easiest would be the Van door, sinceit already has a decent amount of torque, which you could reduce with sprockets and chains. Im not going to go into anything else, because I dont want to give any of my ideas away
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 12-01-2004, 11:35
patrickrd's Avatar
patrickrd patrickrd is offline
AKA: Patrick Dingle
patrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to behold
Send a message via AIM to patrickrd
I think this would be a good example of where a worm gear would be useful. It will provide a large gear ratio and will not slip unless powered.
- Patrick
Systems Engineer - Kiva Systems, Woburn MA
Alumni, Former Mechanical Team Leader - Cornell University Robocup - 1999, 2000, 2002, 2003 World Champions
Founder - Team 639 - Ithaca High School / Cornell University
Alumni - Team 190 - Mass Academy / WPI
Unread 12-01-2004, 12:08
I would use the compressor motor
connected to a 2" diameter cylinder with pnuematic tubing
a 2" diameter cylinder driven with 60 psi produces 180 lbs of force directly
on a 130 lb bot it would lift you within a second
and I would be sure to have it latch (mechanically) in the up postion
remember, you dont have to be doing a chin-up - you only need to be off the floor.
1/10th of an inch is 'off' the floor!
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
You need to be a little careful with worm gears, they CAN be back driven. The van door motor for instance can be back driven. Some sort of a ratcheting mechanism might be a better choice, since it's a firm mechanical stop.
2 cents...
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 12-01-2004, 14:52
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
2 cents...
Matt
Perhaps I'm mistaken, but I was under the impression that a fundemental aspect of the worm gear was that it was impossible for it to be back driven. I've never seen the van door motors backdriven so it may be something else you've seen. Worm gears can break however as the stress of resisting back driving can be great.
Matt
Unread 12-01-2004, 15:41
M. Hicken's Avatar
M. Hicken M. Hicken is offline
Where am I?
AKA: I AM PACO
#0219 (Team Impact)
Team Role: Driver
M. Hicken is a jewel in the roughM. Hicken is a jewel in the roughM. Hicken is a jewel in the rough
Send a message via AIM to M. Hicken
i agree with Ken, all you have to do is get the large ~14"throw cylinder and hook cable up to it, its more than strong enough. but a globe motor or 2 would surfice
If duct tape isnt the answer you're looking for, you're asking the wrong question
There is no such thing as a stupid question, there are just a lot of inquisitive idiots
Personal rookie year: 2002
Team Impact 219: 1998
Unread 12-01-2004, 15:45
Joe3's Avatar
Joe3 Joe3 is offline
Joe3 has a spectacular aura aboutJoe3 has a spectacular aura aboutJoe3 has a spectacular aura about
Send a message via AIM to Joe3
Actually...whether a worm gear can be backdriven or not is dependent on the pitch of the teeth. If you give yourself a decent lever arm, such as a wrench, on the end of the van door shaft, it is backdriven quite easily.
Unread 12-01-2004, 16:12
I thought the van door motor has an internal clutch mechanism, adjustable with the allen screw - so the motor would slip when pushed against a hard stop.
maybe thats what is 'backdriving' - is the motor really turning or is the output shaft slipping internally?
I could be mistaken on this
(I could be mistaken about everything really :^)
Unread 12-01-2004, 17:23
maxgebhardt's Avatar
maxgebhardt maxgebhardt is offline
resident insomniac
#0555 (we dont have a team name, and what are you gonna do about it!)
Team Role: Student
maxgebhardt is on a distinguished road
Send a message via AIM to maxgebhardt
Exclamation Re: If you would "pull-up"...
I dont think it will start slipping! last year we used it to winch up our forklift, and when it got stuck (on two occations), rather than stop, it ripped through some fairly thick plastic, and another time ripped a 6 inch nail sideways, clean through about 2" of pine, it darn near split the nail in half.
Always remember... "with sufficient thrust pigs fly just well thank you."
team motto:
Trust, Love and Magic 2003
AFLAC 2002
Will stop for broken speed controlers 2001
{CPA}Maxzilla UT 2004
Unread 12-01-2004, 17:37
Mr. Ivey's Avatar
Mark Ivey
AKA: Mark
O.K. So far you guys have listed using the window motors, a pnumatic piston, and two globe motors. Now yes you could use any motor out of the box, as long as you gear it correctly, but besides the window motors, globe motors, and pnumatic motors. What is a quick way to move these bots upward. I'm almost thinking something like a track that the bot can run up that doesn't actually pull, but pushes against the track.
Ivey
Balancing archiver 2001 15 23-06-2002 23:51
