Re: If you would "pull-up"...
Ivey |
in 2000, 330 used 2 fischer price motors with the included gear boxes. The diameter of the winch we used was about 3". Teams constantly commented on how fast we got our arm up there, and how fast we pulled up. we used a detent mechanism to clamp once we were up there, since the fisher price motors would slowly backdrive otherwise.
It really depends how you're going to lift yourself. If you were making a winch of some sort, Id say the easiest would be the Van door, sinceit already has a decent amount of torque, which you could reduce with sprockets and chains. Im not going to go into anything else, because I dont want to give any of my ideas away
![]() Cory |
I think this would be a good example of where a worm gear would be useful. It will provide a large gear ratio and will not slip unless powered.
- Patrick |
I would use the compressor motor
connected to a 2" diameter cylinder with pnuematic tubing a 2" diameter cylinder driven with 60 psi produces 180 lbs of force directly on a 130 lb bot it would lift you within a second and I would be sure to have it latch (mechanically) in the up postion remember, you dont have to be doing a chin-up - you only need to be off the floor. 1/10th of an inch is 'off' the floor! |
2 cents... Matt |
#7
Matt |
#8
i agree with Ken, all you have to do is get the large ~14"throw cylinder and hook cable up to it, its more than strong enough. but a globe motor or 2 would surfice
#9
Actually...whether a worm gear can be backdriven or not is dependent on the pitch of the teeth. If you give yourself a decent lever arm, such as a wrench, on the end of the van door shaft, it is backdriven quite easily.
#10
I thought the van door motor has an internal clutch mechanism, adjustable with the allen screw - so the motor would slip when pushed against a hard stop.
maybe thats what is 'backdriving' - is the motor really turning or is the output shaft slipping internally? I could be mistaken on this (I could be mistaken about everything really :^) |
#11
I dont think it will start slipping! last year we used it to winch up our forklift, and when it got stuck (on two occations), rather than stop, it ripped through some fairly thick plastic, and another time ripped a 6 inch nail sideways, clean through about 2" of pine, it darn near split the nail in half.
#12
O.K. So far you guys have listed using the window motors, a pnumatic piston, and two globe motors. Now yes you could use any motor out of the box, as long as you gear it correctly, but besides the window motors, globe motors, and pnumatic motors. What is a quick way to move these bots upward. I'm almost thinking something like a track that the bot can run up that doesn't actually pull, but pushes against the track.
Ivey |
#13
other ways? dont forget we are allowed to use springs - you could come up with a mechasim that is spring loaded - once you hook on the enegry is release and up we go!
or how about retractable wheels! dont lift your bot, raise your feet :c) |
#14
About the Van Door Motors:
They can be back-driven. It has nothing to do with internal clutches, or anything else. (The drill motors, however have anti-backlash pins). You can open the vand-door motors covers up by prying off about 6 or 7 plastic tabs. Inside you will see a big plastic gear connected to a work gear. Take a large (>8") vise-grip, and attach it to the output shaft. If you turn the wrench, you will see the plastic gear inside backdrive the work gear. The fact that the gear is plastic and liberally coated with grease may have something to do with it. For those of you who have had the van-door motor stay: perhaps you had your victor's in brake mode, which prevents a motor from spinning when a neutral signal is received. Also, believe it or not, the Fisher-Price motors are more powerful than the van door's. Check the specs. |
#15
| Balancing | archiver | 2001 | 15 | 23-06-2002 23:51 |
