Go to Post It’s not that we don’t have the time to teach first principals; it’s more that we (FIRST) don’t need to. - Jack Jones [more]
Unread 12-01-2004, 15:41
M. Hicken's Avatar
M. Hicken M. Hicken is offline
Where am I?
AKA: I AM PACO
#0219 (Team Impact)
Team Role: Driver
M. Hicken is a jewel in the roughM. Hicken is a jewel in the roughM. Hicken is a jewel in the rough
Send a message via AIM to M. Hicken
Re: If you would "pull-up"...
i agree with Ken, all you have to do is get the large ~14"throw cylinder and hook cable up to it, its more than strong enough. but a globe motor or 2 would surfice
If duct tape isnt the answer you're looking for, you're asking the wrong question
There is no such thing as a stupid question, there are just a lot of inquisitive idiots
Personal rookie year: 2002
Team Impact 219: 1998
Unread 12-01-2004, 15:45
Joe3's Avatar
Joe3 Joe3 is offline
Joe3 has a spectacular aura aboutJoe3 has a spectacular aura aboutJoe3 has a spectacular aura about
Send a message via AIM to Joe3
Actually...whether a worm gear can be backdriven or not is dependent on the pitch of the teeth. If you give yourself a decent lever arm, such as a wrench, on the end of the van door shaft, it is backdriven quite easily.
Unread 12-01-2004, 16:12
I thought the van door motor has an internal clutch mechanism, adjustable with the allen screw - so the motor would slip when pushed against a hard stop.
maybe thats what is 'backdriving' - is the motor really turning or is the output shaft slipping internally?
I could be mistaken on this
(I could be mistaken about everything really :^)
Unread 12-01-2004, 17:23
maxgebhardt's Avatar
maxgebhardt maxgebhardt is offline
resident insomniac
#0555 (we dont have a team name, and what are you gonna do about it!)
Team Role: Student
maxgebhardt is on a distinguished road
Send a message via AIM to maxgebhardt
Exclamation Re: If you would "pull-up"...
I dont think it will start slipping! last year we used it to winch up our forklift, and when it got stuck (on two occations), rather than stop, it ripped through some fairly thick plastic, and another time ripped a 6 inch nail sideways, clean through about 2" of pine, it darn near split the nail in half.
Always remember... "with sufficient thrust pigs fly just well thank you."
team motto:
Trust, Love and Magic 2003
AFLAC 2002
Will stop for broken speed controlers 2001
{CPA}Maxzilla UT 2004
Unread 12-01-2004, 17:37
Mr. Ivey's Avatar
Mr. Ivey Mr. Ivey is offline
Mark Ivey
AKA: Mark
Mr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of light
Send a message via AIM to Mr. Ivey
O.K. So far you guys have listed using the window motors, a pnumatic piston, and two globe motors. Now yes you could use any motor out of the box, as long as you gear it correctly, but besides the window motors, globe motors, and pnumatic motors. What is a quick way to move these bots upward. I'm almost thinking something like a track that the bot can run up that doesn't actually pull, but pushes against the track.
Ivey
When you tell a student not to do it, you shouldn't do it. Or else you will wind up with a 3/8" drill bit in your finger... Like I did...
Unread 12-01-2004, 18:57
other ways? dont forget we are allowed to use springs - you could come up with a mechasim that is spring loaded - once you hook on the enegry is release and up we go!
or how about retractable wheels! dont lift your bot, raise your feet :c)
Unread 13-01-2004, 20:08
robo-gordo's Avatar
robo-gordo robo-gordo is offline
robo-gordo is an unknown quantity at this point
About the Van Door Motors:
They can be back-driven. It has nothing to do with internal clutches, or anything else. (The drill motors, however have anti-backlash pins).
You can open the vand-door motors covers up by prying off about 6 or 7 plastic tabs. Inside you will see a big plastic gear connected to a work gear. Take a large (>8") vise-grip, and attach it to the output shaft. If you turn the wrench, you will see the plastic gear inside backdrive the work gear. The fact that the gear is plastic and liberally coated with grease may have something to do with it.
For those of you who have had the van-door motor stay: perhaps you had your victor's in brake mode, which prevents a motor from spinning when a neutral signal is received.
Also, believe it or not, the Fisher-Price motors are more powerful than the van door's. Check the specs.
All I need is WD-40 to make things go, and duct tape to make them stop. (That and an infinite supply of 7/16 wrenches.)
Unread 13-01-2004, 20:23
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Ivey
You could use the Window Motor with a tape drive to push yourself up, but IIRC, the pushing force of the tape is only around 100lbs, so you would need a light robot. On the other hand, using the Window Motor with a tape to pull yourself up might not be a bad idea...
Zan Hecht
Unread 13-01-2004, 22:10
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
Ivey
I bet pneumatics would be fastest.
We will probably use a van door/winch setup this year, though, as we have a design that makes getting the hook on the bar quite easy.
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
Unread 15-01-2004, 21:57
srjjs's Avatar
srjjs srjjs is offline
Slightly Rehabilitated
AKA: Larry Wang
#0840 (Aragon Robotics Team)
srjjs will become famous soon enough
Send a message via AIM to srjjs
Tape measures ought to do nicely.
SVR Imagery Award
SVR Semifinalists with 473 and 687
RIP Andrew Dang
3/22/2004
Unread 15-01-2004, 22:15
generalbrando's Avatar
generalbrando generalbrando is offline
Build, Break, Repeat
AKA: Brandon Mensing
FRC #0246 (Overclocked)
generalbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to behold
Send a message via AIM to generalbrando
I don't want to reiterate the idea of pneumatics too much, but it seems like some are talking just about the new motor we have available this year and the rest aren't clear.
My thought with pneumatics is that you can easily put up a stiff arm 9' tall (10 from the floor, 9 from the platform) and then on the end of it have a nice wide pneumatic piston with a clasp/hook/whatever on it. You can activate the raising with a telescope or some simple lighter pneumatics - then you can lift up in an instant with the other one on the end. I think this might be a good approach for rookies since my experince is that pneumatics tend not to go wrong as often as the rest of the stuff.
Lead Mentor of Team #246, Boston University Academy and Boston University, Overclocked
www.burobotics.org
Unread 16-01-2004, 21:24
Gui Cavalcanti's Avatar
Gui Cavalcanti Gui Cavalcanti is offline
Robogeek
Gui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to all
Send a message via AIM to Gui Cavalcanti
We've trusted the CIMs for two years straight as drive motors, and they haven't let us down yet.
We're using a drill for getting ourselves off the ground, but that's all I'm saying right now
Gui Cavalcanti
All-Purpose College Mentor with a Mechanical Specialty
Franklin W. Olin College of Engineering, Class of 2008
Balancing archiver 2001 15 23-06-2002 23:51
