Go to Post It's not very graciously professional to point out the un-gracious professionalism in others. - Taylor [more]
Unread 12-01-2004, 10:16
Dr.Bot
Posts: n/a
Re: Hanging vs. Manipulating 2x balls
If you want to control the game, get one or two of the Big Balls, Hang High, and then decide if you need to score them for both you or the opposing alliance (Stationary goals). You can then easily add points to the opposition. (You also might be able to uncap the oppositions stationary goal.)
This was the winning strategy in 2000 by team 255. Get the balls, Hang on the Bar, and then score them.
Is this mechanically feasible - I don't know. A team that does this needs to rely on its partner to score the small balls. A perfect robot would be able to hang, score big balls, herd little balls - and this is pretty challenging.
Just buildng a robot that can climb the big steps and hang is a challenge.
A smart development plan would be to design by objective:
1. Build moving platform cable of herding, releasing
2. Add Arm for big ball manipulation
3. Add stair climber
4. Add hang ability
6 weeks, 5, 4, 3, 2, 1 ship.......
Unread 12-01-2004, 12:48
animater31405's Avatar
animater31405 animater31405 is offline
AKA: ~Ka$h~
#0314 (Megatron Oracles)
Team Role: Animator
animater31405 is an unknown quantity at this point
Send a message via AIM to animater31405 Send a message via Yahoo to animater31405
Originally Posted by yangotang
Don't forget that hanging is really two challenges at once:
1)being able to get up to the bar
2) latching onto the bar
While these two challenges may seem easy to you, i feel that creating a method to get up to the platform below the bar is tough; i'm convinced that a 2x ball remover is the easiest strategy.
alright i also think that if you create a good arm you could actually pull yourself over the platform from the ground floor and lift yourself up.
~Ka$h~
Unread 12-01-2004, 12:56
I think doing BOTH is a very good idea as yes you can do them both with the SAME arm...
it will be interesting to see how many teams try this
because having one mechanism that performs two functions violates one of the Golden Rules Of Engineering (GROE)
"a subsytem should have ONE function, and be optimized to perform that function"
when you increase the number of functions a subsystem has (N), you increase its complexity N^N
so the complexity of a subsystem with one function is 1
the complexity of a subsystem with two (different) funcitons is 2^2 = 4
the complexity of a subsystem with 3 functions is 9...
it gets out of control REALLY quick!
Unread 12-01-2004, 13:01
AKA: ~Ka$h~
Team Role: Animator
Our team has already drawn out a device that can do both the ball and the arm.
~Ka$h~
Unread 12-01-2004, 13:09
Dr.Bot
Posts: n/a
The mechanism that extends the arm, if powerful enough, whe reversed can lift the robot (1 motor, two functions) Once you latch the bar, you only have to lift a little to hang. I don't think a lot of teams will try to win by
messing with robots trying to hang. You want to score points, not try to prevent your opponents from scoring points.
A simple way to do this is a chain drive elevator using the door motor.
--- 2000 robot using chain elevator to lift scoring mechanism, hanging from bar.
lips lips is offline
AKA: Matt Lipschutz
FRC #1405 (Finney Falcons)
lips is on a distinguished road
Send a message via AIM to lips
there is also the possibility of creating a small hanging device (schematics forthcoming, plan already designed) and then having a large manipulator arm. this would allow a team to both hang, and while hanging knock off a ball from one (or either) side if stragegists deemed necessary.
Just a thought
Unread 12-01-2004, 13:11
good start - now draw out what it takes to do each one separately
if you need incentive - if your 2X ball arm is damaged while playing, you have lost your 50 point hanging function too
thats called a single point failure - if one device does both functions, then one single failure in the arm cost you BOTH functionalities (another reason for the Golden Rule)
think about what it will take to do each function separately. You will find the complexity of the two devices is much lower than the single dual purpose one.
Unread 12-01-2004, 13:37
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Otherwise, build robust and prepare to fix parts on that major component.
Unread 12-01-2004, 17:28
IrisLab's Avatar
IrisLab IrisLab is offline
AKA: Dave Page
#1466 (Webb School)
IrisLab will become famous soon enough
[OMIT]...[/OMIT]
The key word is FUNCTION and not necessarily ONE. A ramp in the sidewalk has one function, but it has many uses. The function is---simply---a ramp, but folks with wheelchairs use it, as do Coke delivery men with dollys, as do Segway's that must cross the road.
My intent here is that if you define your one function properly, it can have multiple applications. Function does not necessarily have to be defined as hanging or ball removal. That could be the application.
To continue with the analogy, if the function of a ramp in the side of the road was to allow Coke delivery men to move their cokes from a truck to the machines in a building, the ramp would only need to be wide enough for a typical dolly. Unfortunately, a wheel chair or Segway wouldn't fit up such a narrow ramp.
I know this analogy is simplicistic, but I hope it highlights my point.
David Page
Unread 12-01-2004, 17:35
AKA: ~Ka$h~
Team Role: Animator
That's my point exaclty!
~Ka$h~
Unread 12-01-2004, 17:42
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I would chose the 2x mult because it can do a lot more than just score points for your alliance. My team ran some "stubot"(student robot) games and discovered how efectivley it could keep the opponent from scoring in thier goals because their is no way in them. By capping the goals when they have no balls in them, they lose a significant amount of time to score. If you can defend the capped goals then remove the caps so you can use them near the end of the game, your opponent will have little to no points from the balls. Also the bar this year is far less accessable than before because of the platform and the narrow room beside the goals. Thus, you dont only need the abbility to lift and hang yourself from it, but either a narrow robot that can maneuver well and climb the stair, or one that can get over the larger ledge to the section of the platform the bar sits on and still be able to get under the bar. The bar is far more trouble than its worth, because 5 5-point balls and a cap can match its points. And needless to say the goals can hold many more than 5 balls, and their are the 4 10-pointers as well. I beleive that the bar takes up to much game and build season time for what it is worth and that the 2x balls are possibly the most pivotal objects in the game.
Unread 12-01-2004, 17:45
dragonpaulz's Avatar
dragonpaulz dragonpaulz is offline
4 P3r$0n
AKA: Paul Shapiro
#0555 (Team 555)
dragonpaulz is an unknown quantity at this point
Send a message via AIM to dragonpaulz
Do the 2X balls have to be inflated? Maybe you can pop the ball and put them in the goal.
Team 555 - Montclair High School
Trust, Love, and Magic
WebMaster of MontclairRobotics.org
Unread 12-01-2004, 17:55
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Your not allowed to intentionally damage the field, so yes they have to be inflated.
4 P3r$0n
AKA: Paul Shapiro
#0555 (Team 555)
OK, thanks.
Unread 12-01-2004, 18:25
I dont see how you can define the function of controlling the large 2X balls:
-acquiring ~2' dia, 3 lb ball from a goal, from the center platform, or from the floor
-placing them on the 4 foot or 6/8 foot goals
- removing them from the goals
-holding them securly during the match to retain possesion
the same as climbing the bar:
-reaching straight up 10 feet
-latching onto a 3" dia pipe
-lifting a 130 lb machine straight up
this is what I was talking about with complexity going 4X when you try to combine the two - the degrees of motion required are different - the end effector is different - the amount of weight to be moved is different - the direction of motion is different
combining the two will make the resulting mechanism much more complicated than it needs to be. I can picture a very simple spring loaded mechanism that can be released once to extend up 10', and capture the bar - and pull the bot up - it only needs strength in the downward direction
but to move the balls you need something like a robot arm - making that strong enought to lift the bot with instead of only moving a 5 lb ball around is a whole nuther ball of wax.
and again, if your multi function arm breaks - you lose big time - you lose BOTH functions on your machine in that match - sure you can fix it later, but you cant get those points back.
Small balls in 2001 competition archiver 2001 10 24-06-2002 03:59
Team 188 Pictures - four big balls anyone? archiver 2001 6 24-06-2002 01:03
Numbers for thought: Are 10 black balls worth 30 seconds? archiver 2001 6 23-06-2002 22:42
Will ANYONE mess with the black balls? archiver 2001 0 23-06-2002 22:35
Just curious, how many robots could shoot or toss balls into the goal? Alan Ing General Forum 7 13-05-2002 19:09
