Re: If you would "pull-up"...
Also, if you're using the Globe motors for anything, make absolutely sure there are NO SIDE LOADS on the Globes. They can't handle side loads, and will burn out very fast otherwise. We went through about 6 of them making a lock mechanism for our winch in 2000. |
The team I was on in 2000 (Team 49) also used the 2 van door motors to lift our bot in 2000.
We were under the impression that worm drives cannot be backdriven so we were a little disapointed to see that when we turned the power off after lifting, our robot slowly settled back to the ramp. We ended up having to make a possitive clamping mechanism. MattB |
So, if you are using the van door motor to lift your bot, you may want to design a locking mechanism. That is exactly what we did at 2000 when we used them to power a big arm that lift the robot body off the ground. Otherwise it will slip back down. |
Fisher Price motors, I believe, can handle the task.
what we've got in the works for this year is a 2" bore pneumatic tube on a double solenoid. of course, its not neccisarily a motor, but it's what we're counting on.
| Balancing | archiver | 2001 | 15 | 23-06-2002 23:51 |
