Go to Post if your robot weighs 1-1/2 tons, you have bigger problems then the legality of that jack... - ekapalka [more]
Unread 12-01-2004, 14:17
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Official Beacon Tracking Code Posted
I've posted the official IR beacon and IR beacon tracking and navigation code that was used at the kick-off here: http://kevin.org/frc. The folks at IFI will also be posting the code on their website. If you have questions about the code, please leave 'em here and I'll try to keep up .
-Kevin
Kevin Watson
http://kevin.org
Unread 12-01-2004, 15:54
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Re: Official Beacon Tracking Code Posted
Thanks Kevin,
Do we run this in the EduBot RC as a separate system?
Is anyone able to convert this to Pbasic so I can run it on a Parallax BOE?
Andy Brockway
Team 716, The Who'sCTEKS
Unread 12-01-2004, 16:01
Beacon.zip and navigate.zip are on Innovation First's website now.
FRC #2429
Originally Posted by Andy Brockway
Thanks Kevin,
Yes, it was designed this way on purpose so that teams would be able to generate the beacon on their own fields. The field for this years game will use a EDU-RC to generate the beacon waveforms.
-Kevin
Kevin Watson
http://kevin.org
Unread 12-01-2004, 18:43
galewind's Avatar
galewind galewind is offline
... more like a temperate breeze
AKA: Chris Gregory
FRC #1089 (Team Mercury)
galewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond repute
Send a message via AIM to galewind
-Kevin
hmmm.. that will be problematic if I don't go and get a 2nd 7.2v battery.
Chris G
Advisor, Team Mercury (1089), Hightstown High School
Unread 12-01-2004, 21:53
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
Just get a 7.2V generic AC adaptor and add the necessary connector to make it connect to the EduRC.
Unread 12-01-2004, 22:13
galewind's Avatar
AKA: Chris Gregory
I haven't read up yet on this, but where can we find what materials we will need to actually emit the waveforms?
Chris G
Unread 12-01-2004, 22:43
Umm Errr...
Can you please describe the beacon waveform?
1139 Alumni
Unread 12-01-2004, 23:04
FRC #2429
I'm working on additional documentation for the beacon and beacon tracking software. I'll post it as I complete it. Meanwhile have a look at this thread for a description.
-Kevin
Kevin Watson
http://kevin.org
Unread 12-01-2004, 23:19
Umm Errr...
-Kevin
Thanks. That scheme is relatively simple. Maybie if i find some time(not likley) i will post an alernative circuit, for those who do not wnat to use the edubot. This setup is easy to replicate using a handful of resistors, capacitors, and 555 timers.
Hmmm... I might have to look into the whole triangulation thing.
1139 Alumni
Unread 13-01-2004, 13:01
FRC #2429
I've done an Illustration showing the beacon waveforms and the infrared sensors response. It's here: http://kevin.org/frc.
-Kevin
Kevin Watson
http://kevin.org
Unread 17-01-2004, 01:16
Phil Roth Phil Roth is offline
#0011 (BASF)
Phil Roth is an unknown quantity at this point
Send a message via AIM to Phil Roth Send a message via Yahoo to Phil Roth
-Kevin
Kevin,
Thanks for the link explaining that the system uses BOTH beacons instead of ONE. I guess it finally clicked. I had trouble understanding how to manuever both directions ( left and right )using using a single "line of sight" source. My trig skills havn't been used in 20 years so I hope the students can help us out with triangulation.
I am still a little confused why 4 receiving LEDS are used and not 2, 1 for each beacon. ??
-Phil
Unread 17-01-2004, 11:47
#0011 (BASF)
I'm trying to fully understand the code and working with the External ISRs first. It seems their sole purpose is to measure the amount of time of the active low pulse, categorize it as beacon 1 or 2, and then update Sensor_Stats[0].Beacon_Count[n] accordingly. Beacon 0 pulses every 1 MS and Beacon 2 pulses every 2 MS.
SO:
SENSOR #1
Sensor_Stats[0].Beacon_Count[0] increments a running count of pulses from beacon 1
Sensor_Stats[0].Beacon_Count[1] increments a running count of pulses from beacon 2
SENSOR #2
Sensor_Stats[1].Beacon_Count[0] increments a running count of pulses from beacon 1
Sensor_Stats[1].Beacon_Count[1] increments a running count of pulses from beacon 2
SENSOR #3
Sensor_Stats[2].Beacon_Count[0] increments a running count of pulses from beacon 1
Sensor_Stats[2].Beacon_Count[1] increments a running count of pulses from beacon 2
SENSOR #4
Sensor_Stats[3].Beacon_Count[0] increments a running count of pulses from beacon 1
Sensor_Stats[3].Beacon_Count[1] increments a running count of pulses from beacon 2
Ideally counts for beacon #1 should be incremented 26 times for beacon 1 and 13 times for beacon 2 when the Timer_1_Int_handler runs
Every 26.2MS, Timer_1_int_handler subtracts the "last" running count of pulses from the "new" running count of pulses to determine the number of pulses that occured over the last 26.2MS perion.
SO:
Sensor_Stats[0].Beacon_Quality[0] = Number of pulses that sensor #1 received from beacon 1 that occurred during the last 26.2 MS
Sensor_Stats[0].Beacon_Quality[1] = Number of pulses that sensor #1 received from beacon 2 that occurred during the last 26.2 MS
Sensor_Stats[1].Beacon_Quality[0] = Number of pulses that sensor #2 received from beacon 1 that occurred during the last 26.2 MS
Sensor_Stats[1]Beacon_Quality[1] = Number of pulses that sensor #2 received from beacon 2 that occurred during the last 26.2 MS
Sensor_Stats[2].Beacon_Quality[0] = Number of pulses that sensor #3 received from beacon 1 that occurred during the last 26.2 MS
Sensor_Stats[2].Beacon_Quality[1] = Number of pulses that sensor #3 received from beacon 2 that occurred during the last 26.2 MS
Sensor_Stats[3].Beacon_Quality[0] = Number of pulses that sensor #4 received from beacon 1 that occurred during the last 26.2 MS
Sensor_Stats[3].Beacon_Quality[1] = Number of pulses that sensor #4 received from beacon 2 that occurred during the last 26.2 MS
End result is:
The values held in the element Beacon.Quality[n] are the number of pulses from each sensor that occurr every 26.2MS where n = beacon #1 or #2. These values are updated every 26.2MS
AND
There are 4 sensors index by Sensor_Stats[n]
where n = of of 4 sensors
Ideally Beacon.Quality[n] should be contain 26 for beacon #1 and 13 for beacon #2.
Is this basically what's happenning in receiver.c ??
Sorry to be so "anal" but I like to fully understand how the code works in order to understand the entire system and move on to understanding tracker.c and then navigate.c where the rubber meets the road. All this while trying to work out out an approach to manage current and software optomization of a 4 motor drive system. I guess my weekend is shot.
-Phil
Unread 17-01-2004, 12:52
Krash Krash is offline
AKA: Steve K
#0836 (RoboBee's)
Krash is an unknown quantity at this point
-Kevin
Kevin,
Is there a "Theory of Operation" or White paper available to explain how this all works? I am assuming that type-0 operates on one side of the field and type-1 operates on the other side. Is this correct?
Also, is the waveform chart on your website accurate? I assume that the pulse repetition interval's (PRI) are fixed as depicted on the chart.
Thanks,
Steve...
Unread 17-01-2004, 13:33
FRC #2429
Actually, the beacon 0 pulse width is 1ms, the beacon 1 pulse width is 2ms. The beacon flashes every 10ms for a beacon rate of 100Hz.
SO:
SENSOR #1
SENSOR #2
SENSOR #3
SENSOR #4
As the beacon rate is 100Hz (=10ms), the counts for both beacon types will increment by 2 or 3 everytime the timer_1_int_handler executes.
SO:
End result is:
Yes, this is correct except the beacons are #0 and #1
Yes, with index values of 0-3. How the individual sensors map to loacations on the tracker assembly is noted at the top of tracker.c
No, ...Beacon.Quality[n] should contain 2 or 3 when the beacon is in view. The algorithm in tracker.c assumes the beacon is in view of that particular sensors "quality" is greater than 0.
Yes, you have a very good grasp of how it works
No problem at all. This is a great discussion that other folks can hopefully learn from.
Have a look at Rich Petras' code in navigate.c for an example of motor stall detection using the new current sensors.
Sorry, dude, whether you know it or not, your next five weekends are shot .
-Kevin
Kevin Watson
http://kevin.org
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
InfraRed autonomous code ... mtrawls Programming 1 11-01-2004 00:25
Autonomous code PBoss Programming 7 14-01-2003 15:29
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
Patent source code? Kyle Fenton Chit-Chat 3 20-10-2001 17:53
