Go to Post The answer doesn't lie with an all student run team, or an Engineer-fest team... But somewhere in the middle. Moderation is key. - Cody Carey [more]
Unread 12-01-2004, 16:28
Suneet Suneet is offline
Physicist-In-Training
None #0599 (RoboDox)
Suneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to behold
Send a message via ICQ to Suneet Send a message via AIM to Suneet
2004 FLASH Game Simulator
Here we have a drag-drop Game Simulator / Scoring program. Very interactive, cool looking! You have to try this! Courtesy of RodoDox Team #599.
All 3 types of balls can be drag-dropped, but goals have a purple ball spinner to add/remove them quickly. Goals are movable.
*Minimum* suggested screen resolution is 1024x764. It won't look good with less, and look great at high resolutions.
The files are now in the whitepapers! Go there to download.
Whitepapers
The .EXE version supports Full Screen, so I reccomend it over the html.
(2X Ball drag bug is fixed)
These will be in the White Papers soon enough (Thanks Brandon!), and for now, this is fine.
Questions? Comments? Bug reports? I'll update if needed, ASAP+.
Enjoy!
-Suneet Upadhyay
thrawn@uclink.berkeley.edu
Here's the contents of the readme file (also found in the .zip files below):
Purple Balls(5pt):
Can be dragged directly in to goals, or the # of purples in a goal can be increased or decreased using the arrows near
the purple floater which is found by all four goals with the label "x5". The arrows are the fast way to add purple
balls to the goal.
Yellow Balls(10pt):
Can only be added to goals by dragging the ball directly into the goal. A Yellow floater appears with the label "x10"
and a downwards pointing arrow. Click that arrow to remove a 10pt ball and have it return to field starting position.
2X Balls:
2 of these start stuck to the movable goals. When a 2X is stuck to a goal, the goal has a yellow floater that says
"2X". Clicking the yellow arrow next to this floater will free the 2X gall from the goal. Drag into the vicinity of a
goal to attach to the goal.
Hanging:
When a robot is near the chin-up bar, a blue floater appears with the words "chin Up" and an up-arrow. Click that to
attach that robot to the bar. Click the down arrow in the floater of an attached robot to detach it.
Field Control Buttons:
-reset Field: Resets the field to 0pts, competition specs.
-gather Purple Balls: Puts stray purple balls (balls on the field but not in a goal) in to the nearest
release chute.
-release Balls: Scatters all balls in the player station on to the field.
Last edited by Suneet : 13-01-2004 at 14:11. Reason: Whitepapers (sorry 'bout the tons of edits)
Unread 12-01-2004, 16:34
Ragin_Kage's Avatar
Ragin_Kage Ragin_Kage is offline
fhqwhgads
AKA: Kyle
#0869 (Power Cord)
Ragin_Kage is on a distinguished road
Send a message via AIM to Ragin_Kage
Re: 2004 FLASH Game Simulator
Thanks a lot, this looks pretty cool
"I've got a fever, and the only prescription is more cowbell!"
www.powercord869.com
Unread 12-01-2004, 16:44
GregTheGreat's Avatar
GregTheGreat GregTheGreat is offline
GregTheGreat has a spectacular aura aboutGregTheGreat has a spectacular aura aboutGregTheGreat has a spectacular aura about
This will definitrly help in explaining the game to fellow team members.
-Greg The Great
Unread 12-01-2004, 17:14
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Very slick RoboDox
Unread 12-01-2004, 17:18
D.J. Fluck
Posts: n/a
Again, you go off and make an awesome FLASH simulator....kudos to you and Nice Job!
-D.J.
Unread 12-01-2004, 18:31
I just fixed a minor isuue with the 2X balls not observing the field boundry.
Sorry 'bout that!
Unread 12-01-2004, 18:53
Jeremy's Avatar
Jeremy Jeremy is offline
AKA: Jeremy Medendorp
FRC #0968 (RAWC Robotics Alliance of West Covina)
Jeremy is on a distinguished road
Send a message via AIM to Jeremy Send a message via MSN to Jeremy
Thanks it really helps out a lot with explaining the game and it can also be used to stradagize
Jeremy Medendorp
College Mentor
______________________________
2003- Arizona Regional Winners
2003- Southern California Regional Finalist
2004- Southern California Regional Semi-Finalist
2004- National Quarter-Finalist Newton Division
2005- Southern California Regional Finalist
Unread 12-01-2004, 18:55
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Do you have it somewhere else because your tripod account has gone over limit.
Unread 12-01-2004, 18:59
Tim Hawes's Avatar
Tim Hawes Tim Hawes is offline
Team Webmaster
FRC #0529 (The Hornets)
Team Role: Webmaster
Tim Hawes is an unknown quantity at this point
Send a message via AIM to Tim Hawes
If you don't have it somewhere else sanddrag, email me at timhawes@girderboot.com and i can host it for you
Tim Hawes
me@thawes.com
www.thawes.com
Unread 12-01-2004, 19:20
Now I've posted direct links to the MSN mirror, hopefully that will stay up...
Tim, if you want, you could download the files and then post them, and we could put up links to that too.
Thanks!
Unread 12-01-2004, 19:30
Tim Hawes's Avatar
Team Webmaster
Thanks!
It wants me to login in order to download, and even if I do, it doesn't work...
Tim Hawes
me@thawes.com
www.thawes.com
Unread 12-01-2004, 23:38
Pierson's Avatar
Pierson Pierson is offline
Pierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of light
Send a message via AIM to Pierson
This is wonderful! Thank you very very very much for creating this!
Pierson
Former Captain & Fundraiser of Team 360
Join in on these fun threads:
Three Worded Story
Word Association
Unread 12-01-2004, 23:49
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
i keep getting the tripod homepage. apparently somethings not clicking right
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 13-01-2004, 00:50
There's 3 tripod mirros now, I'm thinking that one of them has got to work.
Unread 13-01-2004, 01:21
indieFan indieFan is offline
RoboDox and LVHS - Missing you!
FRC #5941
indieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond repute
The zipped files have now been placed within Team 599's webpage system. You can access these files at the following:
http://www.csun.edu/~robodox/ff.zip
and
http://www.csun.edu/~robodox/ffEXE.zip
There are currently no links directly from the webpage as it is being overhauled as we speak.
indieFan
2002 game prediction contest!!! Ken Leung Rumor Mill 41 31-12-2007 18:18
2004 Game Demo Animation MrB General Forum 13 14-01-2004 15:57
pic: 2004 Game Revealed! CD47-Bot Extra Discussion 28 12-09-2003 12:08
Ok, so YOU design the 2003 game... dlavery General Forum 157 07-01-2003 23:55
Visual Game Simulator techknights General Forum 8 22-01-2002 19:43
