Go to Post FRANK, YOU'RE THE MAN. - Libby K [more]
Unread 18-02-2002, 16:08
jnossen jnossen is offline
jnossen is an unknown quantity at this point
What do these variables mean?
delta_t
packet_num
res01
What are they for, and are they necessary?
Also, to save room can I take out all of the default code that I'm not using or does first have some weird thing about keeping it in?
Unread 18-02-2002, 21:03
Already answered elsewhere; I paraphrase:
packet_num = serial number put on this packet by the OI.
delta_t = number of packets not received correctly before this one (essentially current packet number minus that of the last correct packet, minus one).
res01 = reserved variable to do with version number of system; not usually used in competition.
Unread 19-02-2002, 13:50
JHBurch JHBurch is offline
#0045 (TechnoKats)
JHBurch is an unknown quantity at this point
You do not need to use any of these three variables. If you decide not to use them, comment out (or delete) the declaration for them in the '===declared variables=== section. Also, you need to change their Initialization constants to zero. For example, change "c_delta_t CON 1" to "c_delta_t CON 0". This will keep the master controller from sending this to you in the serin command. Finally, you need to remove these variables from the serin command. Be VERY careful about getting the variables in the serin command in the correct order! Read the comments in the default code!
You can also delete almost any of the default code you want. In fact if you're not using it you probably should delete it just to keep things clean. Obviously you must run your light, and I would keep the code for the feedback LED's (modify it if you like though). I would not delete the comments, they don't take up anything but screen space and they can be very helpful.
Jeff Burch
TechnoKats #45
Run command... frightening archiver 2001 1 24-06-2002 03:37
Ahh! Program trick confusing! archiver 2001 9 24-06-2002 02:26
Out of RAM Space on Custom Program archiver 2000 4 23-06-2002 23:07
Pbasic I/O with the OI BinaryBob0001 Programming 3 17-02-2002 00:19
VB Program to monitor robot variables DanL Programming 7 15-02-2002 22:35
