Go to Post Stand scouting allows you to get to know the robot. Pit scouting allows you to get to know the team. - Taylor [more]
Unread 12-01-2004, 19:36
Todd Derbyshire's Avatar
Todd Derbyshire Todd Derbyshire is offline
Alumni
Todd Derbyshire will become famous soon enoughTodd Derbyshire will become famous soon enough
Robots Hanging from the Floor
Anybody hanging their bots but from the floor instead of the platform???
119=190 right?????
Unread 12-01-2004, 19:58
generalbrando's Avatar
generalbrando generalbrando is offline
Build, Break, Repeat
AKA: Brandon Mensing
FRC #0246 (Overclocked)
generalbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to behold
Send a message via AIM to generalbrando
Re: Robots Hanging from the Floor
We thought about it. We're concentrating on drive right now, so no conclusions.
I have an intersting question to add on. If you grab the bar and lift yourself and you're off the carpet and the object supporting you is the bar... (according to the rule that says something like "if you would fall if it was removed, it is supporting you), Would it then be ok if you were still on the side of the platform? (If you're confused by what I mean, imagine the bot on the side of the platform. it grabs the bar and pulls up 1 inch. It's now pressing on the side of the platform pretty well) I could see a lot of teams bypassing the problem of getting up there and fighting the traffic.
Lead Mentor of Team #246, Boston University Academy and Boston University, Overclocked
www.burobotics.org
Unread 12-01-2004, 20:11
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
If I understand you correctly, I think that would still be considered as you being on the floor.
I think that's another question to throw on the Q&A forums...
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 12-01-2004, 20:33
I guess I could edit my last post, but...
I watched the animation again and you'll notice that a robot grabs the bar from the floor and lifts up. It doesn't drag on the side or anything, so I'm still not sure if that's a problem, however you are allowed to be hanging over the carpet (as long as the animation wasn't wrong!).
BTW - can someone put this question up on the FIRST board? I can't get into it since I don't have the password for our team. Thanks
www.burobotics.org
Unread 12-01-2004, 22:37
Upon re-reading the rules, it appears that on page 2 of "The Game" it states that my little idea wouldn't work. However, I think the intention of the rule was not to limit the hanging in this specific case, so I would still like a clarification.
www.burobotics.org
Unread 12-01-2004, 22:46
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
To my knowledge, there is no rule that prevents being on the floor (the carpet), reaching the horizontal bar and lifting your robot from this position to qualify for HANGING.
Please quote the rule you think disallows this and explain if your case if it is not obvious from the rule you quote.
As I read the rules, I don't see that it is illegal.
Joe J.
Unread 13-01-2004, 10:53
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Joe J.
I think the question could be rephrased as "if I lift from the floor but not so high I clear the platform, am I still hanging?" Obviously a robot in that position is placing a substantial force on the platform, but it is all side load. The vertical force to support the robot would all come from the bar.
I didn't see anything in the rules against it. You can't grab the vertical pole but I didn't see anything saying you can't touch it. I didn't see anything about not touching the side of the platform either. But then again I tend not to see stuff I'm not looking for, and that was not one of the things I looked for. (I hadn't thoght of it yet) So I'm willing to be corrected on this.
If it IS acceptable, then it opens up more real estate on the bar and you could concievably get all four robots on. It also relieves a lot of my concerns about lifting from the floor, because then I don't have my robot trying to imitate a wrecking ball.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 13-01-2004, 11:04
Mr. Van Mr. Van is offline
#0599 (Robo-Dox)
Mr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond repute
The HANGING definition (4.3.1) is that the robot must not be touching the platforms and SUPPORTED by the horizontal bar. I would interpret "touching" to be "in contact with any part of" so that include the side, top or bottom of the platform. I believe the SPIRIT of the whole hanging thing is to see robots that can swing freely from the horizontal bar - not touching anything else (except incidental contact with the side poles).
-Mr. Van
Coach, 599
RoboDox
Unread 13-01-2004, 11:06
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
4.3 The Game
4.3.1 Definitions...
HANGING - A Robot is considered HANGING from the Pull-Up bar if it is directly SUPPORTED by the horizontal bar and is not touching the carpet, platforms, or goal.
Any questions?
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 13-01-2004, 11:19
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Lookn at the definition of hanging. It says that you must be clear of platform, so if you are touching the side of the platform you are then touching the platform which is against the rules
Unread 13-01-2004, 12:11
Yes, but I think the intention was not to limit this case where you are off the carpet but touching the side of the platform (not being supported by it). I would still like a clarification just to be sure they won't allow it!
::edit::
To clarify: I think the intention was to say that you must up in the air, not on the platform surface. This is what I mean by this thought of varried intention. Note that I am not arguing this to be true - I am questioning it.
www.burobotics.org
Unread 13-01-2004, 12:46
AKA: Dr. Joe
FRC #0088 (TJ2)
Again with the allow vs. dis-allow! IT IS ALLOWED <-- as far as I can see there is NO RULE AGAINST IT which is the same thing.
Will you be considered HANGING? Words mean what words mean. If you are touching the platform (its sides, its top, or even its BOTTOM I suppose), the you are NOT HANGING.
I hate raising my voice, but sometimes folks need to be SHOUTED AT.
Joe J.
P.S. On a lighter note:
Q: What if you snagged a thread of the carpet on your robot and it stuck to you as you lifted, would your be HANGING?
A: Yes but you would be disqualified for damage to the field and you may also get gigged for being an entanglement threat ;-)
Unread 13-01-2004, 12:47
ttedrow's Avatar
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
generalbrando,
Where did you get the "intention part of this rule"? I think NOT TOUCHING THE PLANTFORM is self explanatory.
Please see this post for more information
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
Yes, Chute Door!!!
Unread 13-01-2004, 13:27
I don't want to continue to argue the rule, however I would just like to say that I'm not trying to be sneaky, backward, and/or annoying. I understand what you are saying, and I stated my opinion and I would still ask the question on the FIRST board. Please do not get yourself worked up because of this and please be professional when you post. Things like this have snow-balled in the past and good discussions have been closed due to behavior. I know my idea is obviously backward and my logic may only make sense to me, but there's no need for you to stress yourself about my insanity! I'll leave this one alone now. (That means no one needs to post to tell me I'm wrong - I'm out, so continue on with the original question!)
Please also see the edit in my post above.
www.burobotics.org
Unread 12-01-2004, 22:49
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
although the bot in the animation did in fact hang from the bar directly from the floor, you will also notice that it rebelled a lot against the laws of physics. In reality, in order to do it you would need a longer arm that was capable of attaching itself to the bar at different angles (as you would never be directly in line).
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
hanging off off other robots that are hanging off the horiz bar Andrew Dahl Rules/Strategy 15 12-01-2004 19:14
Starting position and hanging clarification Don Wright Rules/Strategy 2 10-01-2004 14:21
floor protection Ken Leung Off-Season Events 15 17-05-2003 07:42
FYI: FIRST Robots at the NYC Hall of Science Rich Wong General Forum 9 11-07-2002 10:52
how effective do you think robots going under the bar archiver 2001 4 24-06-2002 00:36
