Go to Post In theory, this should work... Oops. - Eldarion [more]
Unread 11-01-2004, 17:06
Anthony Kesich's Avatar
Anthony Kesich Anthony Kesich is offline
Programmer Turned Engineer
AKA: SonKenshin
#1097 (Site 3 Engineernig)
Anthony Kesich has a spectacular aura aboutAnthony Kesich has a spectacular aura about
Send a message via AIM to Anthony Kesich
Re: IR Sensors- will they attack hot Chiaphuas?
ahh, good point. I'm used to constant signals, but who knows? I think some experimenting is in order. Maybe some interrupts to collect the strength for 2 ms... hrmmmm
-Kesich
C is screwing up my English--I'm ending all my sentences in semi-colons;
Horray for most things! -George Carlin
"Sure, I'll play rugby. Besides, I have a lot of experience running from really big guys who want to cream me." -Me, Freshman year
Unread 11-01-2004, 17:42
Curtis Williams Curtis Williams is offline
#0588 (Team 588)
Curtis Williams is on a distinguished road
Send a message via ICQ to Curtis Williams Send a message via AIM to Curtis Williams Send a message via MSN to Curtis Williams Send a message via Yahoo to Curtis Williams
Wouldn't these things be as realiable as the sensors from last year we used to detect the reflective tape? I think they worked the same way.
Unread 11-01-2004, 17:54
AKA: SonKenshin
Didnt those use the visible light spectrum? And the light sensors projected, whereas the IR sensors just pickup, so there really isnt the chance of seeing reflection when there isn't one. I went straight dead reckoning, though. Getting to the top of the ramp and hitting boxes in 5 flat seemed better to me. Anyways, in the line vs IR arguement, i'd say IR because you can see the IR from anywhere. The line, on the other hand, can get smugged up, lost, and once you are done with it, the sensors are useless. Ir can triangulate though.... hehehe
-Kesich
Unread 11-01-2004, 17:57
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
The signal from the beacons and receivers probably resemble the signals from a television remote. I have never encountered any interfernce from body heat on those things.
Unread 11-01-2004, 18:00
AKA: SonKenshin
Wouldn't that be funny. Walk by the TV with a candle and the tv turns on, mutes, unmutes, cranks the volume, then hacks the cable box and gets you free PPV for life. Heheheh :-D
-Kesich
Unread 11-01-2004, 18:09
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
Originally Posted by Rich Kressly
Don't you every year Wayne?
Get some sleep, you are getting goofy already
Have that 9 ft arm built yet?
20 ft.....
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 11-01-2004, 18:27
#0588 (Team 588)
What I meant about last year's sensors is that they sent a specific pulse pattern to prevent picking up sources other than itself. Although my team didn't use them, I played with the sensors and found them pretty reliable. I dont think we have to worry about someone accidentally confusing the robots with a camera or furby.
Unread 12-01-2004, 09:12
Witte1 Witte1 is offline
Ray Witte
FRC #0116 (Epsilon Delta)
Team Role: Parent
Witte1 is an unknown quantity at this point
Originally Posted by Peciv
I had a similar question: What about all of the other IR interference that comes from the cameras and camcorders in the stands. What about the Media who bring cameras and video cameras into the area right around the outside of the field? What about the cameras that feed the big screen?
For those of you who don't know, the auto-focus on your camera relies on an IR signal being bounced from the camera to the object and back. This tells the camera the focal point.
Will we see robots attempting to leave the field to attack the media? Or, has FIRST put the IR on a different frequency or spectrum (I don't know if this is possible)?
The IR Sensor is set to only detect the frequency emitted from the beacon. Similar to way your TV remote works, you won't get out side interference.
Unread 12-01-2004, 10:29
OK,
Before you guys get too crazy, the IR emitters generate energy in the same area as heat but have one distinct difference. The emission will occur as 40kHz pulses for varying lengths of time. That is, bursts of 40kHz modulated IR energy. The night illuminators on cameras are just that, steady state, non modulated sources the same as hot bodies. The IR camera range finders and remote controls use modulated IR emitters at different frequencies so there should be no real problems if you keep in mind that you are looking for a 40kHz modulated source. The bandwidth of the IR is not 40kHz but likely is much wider than that since the bandwidth you are measuring is near visible light.
Unread 12-01-2004, 12:26
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Originally Posted by Al Skierkiewicz
OK, Before you guys get too crazy...
Too late .
Yes, as Al correctly (again) points out, the Vishay TSOP4840 sensors that are included in the kit and also used for the kick-off demo specifically discriminate against these type of energy sources. They also discriminate against non-modulated 40KHz sources. I've put a link to the data sheet here: http://kevin.org/frc. The modulation scheme is discussed in this thread.
-Kevin
Kevin Watson
http://kevin.org
Unread 12-01-2004, 13:35
Joe Beynon's Avatar
Joe Beynon Joe Beynon is offline
i dont post much
AKA: Shyywkiwk
#0190 (Gompei and the Herd)
Joe Beynon is an unknown quantity at this point
Send a message via AIM to Joe Beynon
this is something that i asked about at the main kickoff because of the fll problem. the guy told me that he tested the ir sensors with 5 cameras that were said to have problems with the fll bots and none of them caused interference. he also mentioned that these ir sensors are the type used in high-end stereo equipment and the only thing to possibly worry about would be a flickering flourescent bulb.
Unread 12-01-2004, 13:54
Kevin,
Thanks for the pdf, I am forwarding it to our electrical guys right now. Good info in the data sheet, too!
Unread 12-01-2004, 20:38
briholton's Avatar
briholton briholton is offline
AKA: brian holton
#0752 (Gods of Fury)
briholton is on a distinguished road
Originally Posted by Anthony Kesich
40khz is the wavelength at which the beacons will be transmitting (I'll find the quote in the manual later). If I ma not completely mistaken, that is on the high end of the infared spectrum, just below the visible spectrum, so for someting to emit infared light from being hot, it would need to be REALLY hot, and i think most CIMs will die before getting that hot.
yikes! 40 khz is not a wavelength - it's a frequency - and I don't think it is the frequency of the electromagnetic radiation coming from the source either. If that were the frequency, the wavelength would be about 10,000 meters. That's a real long radio wave, not infrared. So, yes, you ARE completely mistaken. Perhaps the infrared source is being pulsed at 40khz, but that's a whole difference animal.
Unread 12-01-2004, 22:17
Gary Bonner Gary Bonner is offline
FRC #3974
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
How many pulses must the sensor receive in order confirm which beacon it is seeing, and therefore, how fast can the sensors sweep the field and still detect the beacons?
And a less important issue, will the beacons appear as bright lights on videos of the matches since many camcorders are sensitive to IR light?
Unread 12-01-2004, 22:27
Umm Errr...
You don't really have to worry about how many pulses they need to see. at 40khz, this will not even be an issue. You can basically assume the response is instantaneous.
yes. Some cameras more than others. It will show up as bluish white. Point a TV remote into your camera to get an idea of what i mean. You can prolly find IR filters if things are really bad.
1139 Alumni
what type of sensors are good and convenient magical hands Programming 7 04-01-2004 23:04
optical sensors acting strangely rosebud Electrical 10 03-02-2003 00:29
HURRY......Registration for FIRST ATTACK AT MERRIMACK is ope archiver 2000 2 23-06-2002 23:20
How do people get hot motors? archiver 2001 11 23-06-2002 22:24
HOT dishes up Animation Class archiver 2000 0 23-06-2002 22:00
