Go to Post Keep arrogant, belittling and misspelled bragging off these boards. - Mike [more]
Unread 12-01-2004, 14:04
trc_13 trc_13 is offline
trc_13 is an unknown quantity at this point
Re: stairs
Originally Posted by edomus
Has anyone thought about how to climb onto the 6 inch platform yet. We have a few ideas, but I need some help brainstorming.
How about using spokes to push the robot up to the stair
Unread 12-01-2004, 15:08
M. Hicken's Avatar
M. Hicken M. Hicken is offline
Where am I?
AKA: I AM PACO
#0219 (Team Impact)
Team Role: Driver
M. Hicken is a jewel in the roughM. Hicken is a jewel in the roughM. Hicken is a jewel in the rough
Send a message via AIM to M. Hicken
Re: stairs
just thought
-rather than a caster, which will get caught on the stair, go to a semi sphere or similar delrin or teflon material, make it so it wont get cought on the angle of the stair
we're still working on a drive system for the stairs, but think about having 4wd in the rear or front, and a delrin piece in the back,make the front or back wheel in the 4wd pivot so it can "climb" the stair
this is going to be an amusing attempt, but i have no pics and cant post them even if it did
pcture this on both sides
| wheel |
| | make the system pivot on one wheel on both sides
| wheel |
edit: ok it looks good in the reply page, but on the thread the spaces are all messed up
If duct tape isnt the answer you're looking for, you're asking the wrong question
There is no such thing as a stupid question, there are just a lot of inquisitive idiots
Personal rookie year: 2002
Team Impact 219: 1998
Unread 12-01-2004, 15:22
Ragin_Kage's Avatar
Ragin_Kage Ragin_Kage is offline
fhqwhgads
AKA: Kyle
#0869 (Power Cord)
Ragin_Kage is on a distinguished road
Send a message via AIM to Ragin_Kage
Re: stairs
Spokes? you mean like something to grab the edge of the stair and pull it up...what if your, lets say, wheels where big enough and had sort of a toothed tread and it could easily grab and hold an edge and work its way up...giving you had clearence, and everything else needed...multiple wheels, 4 wheel drive...
"I've got a fever, and the only prescription is more cowbell!"
www.powercord869.com
Unread 12-01-2004, 15:35
M. Hicken's Avatar
Where am I?
AKA: I AM PACO
#0219 (Team Impact)
Team Role: Driver
Re: stairs
the spoke would work but look at robot specs R13, you'd have to be really careful about the technicalities of that one
Unread 12-01-2004, 19:29
Jake177's Avatar
Jake177 Jake177 is offline
AKA: JT, Jake Troiano
FRC #0177 (Bobcat Robotics)
Jake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to behold
Re: stairs
If anyone remembers our 2001 bot, it had an arm with a range of motion close to 180 degrees and a rotating wrist at the end of it. Meaning that, when positioned the right way, the arm could lift the front two wheels off of the ground. I wish I had a picture of us doing this, but if you look in the CD galleries you should be able to get an idea of what I'm talking about. Although it hasn't been tested, I'm sure that it would be able to lift the front wheels enough to get up the step. Then it could rotate the arm 180 degrees to lift the back wheels up enough to get up the step. This would only be possible with a bot with 4 wheel drive though.
Once a Bobcat, always a Bobcat
2001-2004: Student
(I'm told the team had a couple good years in between here)
2012 - Present: Mentor
Unread 12-01-2004, 20:24
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: stairs
This is also what Team 60 did with their arm in 2001 to cross the midfield barrier.
2001-2004: Team 100
2006-Present: Team 254
Unread 12-01-2004, 21:15
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Re: stairs
threads and wheels are good idea.... how about think a little outside the box.. why not add a mechanism which will help you to get on the platform...
Unread 13-01-2004, 00:17
Jedi Padawan's Avatar
Jedi Padawan Jedi Padawan is offline
Electrical Expert Student
AKA: Dan Howell
Jedi Padawan is on a distinguished road
Send a message via AIM to Jedi Padawan
Re: stairs
the easy way would be to just to litterally fly. but barring gas fuel or nuclear fusion I'm thinking that might be a little advanced for most teams.... otherwise I think my team figured it our you'll need almost a 16-18 inch wheel to get over the "bump" and that's provided you end up with something like 10 inch casters or you can stick to the tried and true methods of tank drive and offset wheels (one higher and the rest normal.) your real worry should be about flipping (cringes at thought of Icarus last year)
It's all fun and games till the bosh motor breaks.....
Unread 14-01-2004, 00:14
_GP_'s Avatar
_GP_ _GP_ is offline
AKA: Geoff P
#1277 (Crusaders)
Team Role: Student
_GP_ will become famous soon enough
Re: stairs
did you consider that you might not have to get up on the plaform, or that you may not want to.
I assume you are trying to go for the chin up, so consider this:
The edge of the platform is only 2 feet from the bar. so as you approach the bar, whatever you are going to use to hoist yourself up is going to have to go starit up. If it is a lifting arm or some sort, you can basically add 6" to 1' onto the arm and reach the bar without getting onto the platform
well thats my idea at least
Unread 14-01-2004, 00:30
edomus's Avatar
edomus edomus is offline
AKA: Evan
FLL #1218 (CHAbots)
Team Role: Driver
edomus is on a distinguished road
Send a message via AIM to edomus
Re: stairs
interesting. you think that an arm or something that long could fit within the starting dimentions? If it has many pivots for folding I fear that it wont be strong enough to life a 130 pound bot
2004 National Finalists with 469 and 868
2004 Gallileo champions and #1 seed
  • Delphi "Driving tommarows technology" -philly 2004
  • 8th seed philly 2004
  • 58/58 at annapolis 2004 (like the improvement?)
  • Philadelphia Alliance Regional Winner!-2003
  • 7th seed Philly 2003
  • Rookie all star philly 2003
  • semi finalist Pitt 2003
  • picked 3rd in pitt 2003
  • Seeded 17(curie) at nats 2003
Unread 14-01-2004, 15:40
Jake177's Avatar
Re: stairs
In 2001 we built a 14ft. teloscoping arm on our machine so that we could put a big ball on a goal while it was balanced on the bridge. But that was our only mechanism besides the drive system because we designed it so that it could also manipulate the goals. So I wouldn't advise devoting so much weight to such a long arm if all that you are going to do with it is hang.
2001-2004: Student
Unread 14-01-2004, 16:15
_GP_'s Avatar
AKA: Geoff P
#1277 (Crusaders)
Team Role: Student
Re: stairs
you could easily use that arm to get a 2x ball... and plowing the balls to the coral doesnt really take any special parts (if you dont mind doing it inefficiently)
Unread 14-01-2004, 23:41
MConte05's Avatar
MConte05 MConte05 is offline
"Operation FIRST"
AKA: Matt Conte
#1098 (G.I.'s)
Team Role: Driver
MConte05 is on a distinguished road
Send a message via AIM to MConte05
Re: stairs
Yea, that is how our team seems to be leaning as far as how to get the balls, hang, and pick em up....Another thing with the arm, if the center of gravity is rather low, you could use the arm to push down on the step, causing the bot to lift, and roll yourself onto it....I think.....dunno...
Unread 14-01-2004, 23:47
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
Re: stairs
Well currently, my team is tweaking our design to get up onto the platform. Basically we figured you just need to have enough ground clearance and the wheels spaced rightly, and with enough momentum you should have no problem getting up. Our only problem now is our frame is getting caught up on the platform, which should be fixed by tommorow hopefully. I'd really hate to be a rookie this year
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
2002 game prediction contest!!! Ken Leung Rumor Mill 41 31-12-2007 18:18
What's the dumbest thing you've ever done, related to FIRST? Anton Abaya Chit-Chat 99 23-03-2004 11:57
Low Cost Field BOM Andy Brockway General Forum 161 11-01-2004 08:34
**IMPORTANT FIRST EMAIL BLAST**/Game Tip and 2004 Competition Manual Information!! Travis Hoffman FIRST E-Mail Blast Archive 85 09-01-2004 11:13
2004 Game BBFIRSTCHICK General Forum 112 19-04-2003 17:12
