Re: How to make gears mesh properly.
Good question. Keeping tight tolerances on center-distance spacing when designing gearboxes is a good thing to do. In your case, it is OK to specify 1.500" distance if the fabricator keeps a tolerance of +/- 0.001".
Another way to dimension it would be to call out 4 places, at 1.5000". Traditionally, the tolerance for this dimension would be +/- 0.0005". I know that there are other engineers who say to add 0.002-0.003" to the center distance. That will work also, as it is a more conservative way to design. It will add a bit of backlash (not sure how much). It really depends on the level of quality and tolerance your fabricator can handle. If they are very good, go with a four-place tolerance. If they are just OK, then add a few thousanths for backlash. Good luck, Andy B. |
| What type of steel are gears commonly made from? | Matt Adams | Technical Discussion | 5 | 02-01-2004 23:19 |
| Best source for gears? Smallparts? drivetrain advice wanted! | Frank(Aflak) | Technical Discussion | 11 | 10-01-2003 17:22 |
| Please help make the Nationals in Houston AWESOME ... You be the Tournament Director | Natchez | General Forum | 42 | 13-12-2002 18:50 |
| Time for new rules! | archiver | 2001 | 11 | 24-06-2002 02:01 |
| How do i make gears in inventor? | mnkysp6353 | Inventor | 1 | 16-01-2002 02:31 |
