Go to Post FIRST robotics: Not just for nerds. - Koko Ed [more]
Unread 11-01-2004, 18:25
CyberWolf_22's Avatar
CyberWolf_22 CyberWolf_22 is offline
Programming and Electrical Mentor
AKA: Allen Gregory
FRC #2587 (Afrobots)
CyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really nice
Interrupts
I was looking at the robot controller reference guide and did not notice any information about interrupts, when looking at the default code it still has the interrupt handler but there are no references to external interrupts. So my question is, are there external interrupts on the new controller or just the internal timer ones?
Unread 11-01-2004, 23:19
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
Re: Interrupts
Yup.
INT0 and INT1 are being used by FIRST.
INT2 = Dig I/O pin 1
INT3 = Dig I/O pin 2
RB4 = Dig I/O pin 3
RB5 = Dig I/O pin 4
RB6 = Dig I/O pin 5
RB7 = Dig I/O pin 6
Unread 12-01-2004, 21:04
AKA: Allen Gregory
Re: Interrupts
Can you please tell me were you obtained this info.
Unread 12-01-2004, 21:46
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Re: Interrupts
It was discussed in this thread. You can also have a look at ifi_aliases.h to see that the port b interrupts are mapped to the digital I/Os mentioned above.
-Kevin
Kevin Watson
http://kevin.org
EDU Demo Code: Encoder Interfacing Using Interrupts Kevin Watson Programming 4 08-01-2004 23:14
Interrupts Questions mightywombat Programming 0 03-01-2004 14:50
Problem with interrupts on the PIC Mike Betts Programming 7 16-12-2003 21:26
Interrupts on the EDU-RC? Andrew Programming 3 13-11-2003 23:16
New Controller Specs Posted Jnadke Programming 58 05-10-2003 08:18
