Go to Post Why do things the easy way when you can do it with a robot? - MissInformation [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 12-01-2004, 21:06
Matt_Kaplan1902's Avatar
Matt_Kaplan1902 Matt_Kaplan1902 is offline
#DecadeofDelicious
FRC #1902 (Exploding Bacon)
Matt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond repute
Send a message via AIM to Matt_Kaplan1902
Egg Drop Contest
For my physics class I need to design a way to have a raw egg fall 30 ft without cracking. For full points, it needs to be under 4 inches in lenght and width. Any ideas would be greatly appriciated.
Thanks in Advance.
Team 1902: 2007-??, Mentor
Team 108: 2002-2005, Student
Unread 12-01-2004, 21:12
Re: Egg Drop Contest
google it up
Unread 12-01-2004, 21:17
Umm Errr...
Thanks in Advance.
This is where you turn to: http://www.uline.com
I would try bubble wrap in a very rigid shell(metal), wrapped in yet more padding. A freind of mine did this once b4. If i can remember, i will ask him what he did. Can it deploy? If so, a parachute might be a very good way to go. You can cut a rather effective once out of garbage bag material.
1139 Alumni
Unread 12-01-2004, 21:28
generalbrando's Avatar
generalbrando generalbrando is offline
Build, Break, Repeat
AKA: Brandon Mensing
FRC #0246 (Overclocked)
generalbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to behold
Send a message via AIM to generalbrando
I've done exactly that before and I know how you can do it. Great Stuff. There's this expanding insullation in a can called Great Stuff. It's hard to use (don't get it on skin!) but if you dip an egg in vasoline and then surround it with this stuff (use a little box or something) then you can cut into it and take the egg in and out. Then just use a couple tight rubber bands to hold it together (if you cut in squigles or something, it's less likely to come apart!).
Hope this helps.
Lead Mentor of Team #246, Boston University Academy and Boston University, Overclocked
www.burobotics.org
Unread 12-01-2004, 21:31
Aaron Lussier's Avatar
Aaron Lussier Aaron Lussier is offline
Volunteer for hire
Aaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to behold
Are you allowed to use anything you want? Or do you have a set list of materials? Any rules given to you will also help.
Team 151 Student/Mentor 2001-2004
US Navy 2005 -2009
Volunteer 2010 - ???
Field Reset Extraordinaire
Unread 12-01-2004, 21:33
I heard once the absolute best packing material for an egg drop contest is grass trimmings from cutting your lawn. I didnt check where you are, it might be a problem for some of us to get the lawn mower out tomorrow.
Its been so cold here in rochester NY that I called Microsoft to see if I could get StormWindows for my PC.
Everytime I open a window the giraffe is unbearable!
Unread 12-01-2004, 21:34
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Thanks in Advance.
Inflatable airbags!! Do it the NASA way!
I would use this memory foam stuff that NASA created way back whenever. Also if you could get your hands on a goose down pillow that would probaby work really well. A parachute would be really cool, but if you can't attach anything to the egg then it's not possible.
Purdue Alumni
Cummins, Inc.
Unread 12-01-2004, 21:35
oooooooooh.. your in florida! they dont have real grass there, do they?
they have that nasty stuff that slices your feet open!
Unread 12-01-2004, 21:38
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Parachute could work, or you could do what my friend did, he wrapped it up in gardening foam. I think it could of gone another 10 feet up.
I heard my physics teacher would give your apparatus a starting velocity if you were a trouble maker. I've also heard he tosses another egg at the same time as tossing your apparatus to make it look like it fell out, lol.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 12-01-2004, 21:51
a parachute quickly reaches its 'terminal velocity' - which means, if you design one large enough to achieve a suffienctly slow downward velocity, then it doesnt matter what height you drop it from - it will decend at the same steady rate (assuming you dont start out in the vacuum of space :c)
Unread 12-01-2004, 22:05
mightywombat's Avatar
mightywombat mightywombat is offline
bins? stacking?? NOOOOO!
AKA: Bill Rosemurgy
#0857 (Superior Roboworks)
mightywombat is on a distinguished road
haha. I did this in a class once. One kid encased his egg in many pounds of Jell-O and placed it all in many plastic shopping bags... what a splat. We were graded on the mass of the aparatus and whether the egg survived. My instructor used a chunk of insulation (like the pink stuff but not in sheets), cut a hole in it and stuck the egg in and it lived. I used the stuff that is used to stuff pillows with to pad my egg. A big thing is to make sure it doesn't bounce... all that impulse force and whatnot (I don't quite remember all of it) but I remember that when something bounces more force is applied to the object and hence the egg. Have fun!
Bill Rosemurgy - Aspiring Programmer and Human Player (stack of 8 in <10 seconds...oh yeah... but I can't shoot for crap.)
www.team857.com
Unread 12-01-2004, 22:11
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
One way, which may not be feasible because of the 4" constraint, is to tie a knot in a stocking, insert the egg, then knot the stocking on the other side of the egg. Now stretch the "hammock" between both ends of a rigid box. As long as the egg can't touch the sides of the box, it should withstand the fall. This worked for us in our HS physics class (shoe box, third floor). Good luck!
Unread 13-01-2004, 01:14
a parachute could easily be folded up so its under 4" when released.
Unread 13-01-2004, 01:21
REVving up for a new season
FRC #2848 (All-sparks)
i won my schools in the 7th grade and promise that this will work everytime.
take a milk carton (one of those small ones from the cafateria)
get some pipe inslation (the black stuff by your water heater) availble at home dept
put a 1.5 x 1.5 peice on the bottom of the carton ( enough to cover the bottom)
then wrap 1 layer arround the egg
put wrapped egg in milk carton
put another piece of inslation on top and then close the carton
secure with rubber bands and you will win
we shot mine out of a slingshot prob 300 feet and no breaks. it will also be super light weight and in your size constraints
Unread 13-01-2004, 02:20
Ragin_Kage's Avatar
Ragin_Kage Ragin_Kage is offline
fhqwhgads
AKA: Kyle
#0869 (Power Cord)
Ragin_Kage is on a distinguished road
Send a message via AIM to Ragin_Kage
I rembering doing this in 7th grade too,... those grass clippings would work, i used flour and corn starch, just in a little ziplock bad, dropped it off our school roof 3 stories up, and it was fine, worked perfectly....i also tried using shedded egg carton and corn flakes cereal, but i wouldnt recomend those haha, they didnt work too good
"I've got a fever, and the only prescription is more cowbell!"
www.powercord869.com
NEW 2004 Repeat contest - Pioneer HS, AA MI wishes to Host kmcclary Off-Season Events 0 23-09-2003 13:34
NYC Web Contest Problems & A Letter to FIRST... AugustF Website Design/Showcase 31 04-05-2003 11:36
writing contest Ken Leung General Forum 10 15-12-2002 16:15
Egg drop help Please..:-) archiver 2000 9 23-06-2002 22:49
Rookie Team needs to borrow a FIRST goal for CDI contest kmcclary General Forum 7 17-10-2001 19:49
