Go to Post I'm pretty sure Andrew Baker and Andy Baker are the same person. Then again, Andy may just be holding out on us. - Amanda Morrison [more]
Unread 12-01-2004, 22:19
353Pobots 353Pobots is offline
#0353 (Pobots)
353Pobots is on a distinguished road
Leaning against vertical bar
Are you allowed to lean against the vetical bars while hanging off of the horizontal bar? I know the manual says you are not allowed to attach yourself to the bar, but says nothing about leaning or touching it.
Unread 12-01-2004, 22:22
generalbrando's Avatar
generalbrando generalbrando is offline
Build, Break, Repeat
AKA: Brandon Mensing
FRC #0246 (Overclocked)
generalbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to behold
Send a message via AIM to generalbrando
Re: Leaning against vertical bar
I would say as long as you aren't supporting yourself on the bar they won't have a problem with it. It's not that the side bars are sacred. They just aren't meant to handle large side loads (notice how it's not really supported for this kind of load). So I would say go for it, but you should probably ask them on the Q+A section of the FIRST site to find out for sure.
Lead Mentor of Team #246, Boston University Academy and Boston University, Overclocked
www.burobotics.org
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
You can't use the bar for any support, including leaning against it.
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 12-01-2004, 22:25
KyleGilbert45's Avatar
KyleGilbert45 KyleGilbert45 is offline
KyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant future
Exclamation Re: Leaning against vertical bar
Under Definitions:
HANGING – A ROBOT is considered HANGING from the Pull-Up Bar if it is directly SUPPORTED by the horizontal bar and is not touching the carpet, platforms, or goals.
It says directly supported by the horizontal bar. Since FIRST said to use some common sense I would say leaning against the vertical bars would fall under the category "is not touching the carpet, platforms, or goals." But hey thats just what I think.
Unread 12-01-2004, 22:28
Agreed.
Unread 12-01-2004, 22:35
I disagree. Supported is defined and it reads that you're supported if you would not be hanging if the supporting object were removed. Remove the side bars and you're still hanging (cough...assuming the bar would stay there. I'm thinking they were trying to clarify the fact that supporting means that the object carries the load, not something else). Anyway, I'd like to see this posted and clarified.
www.burobotics.org
Unread 12-01-2004, 22:38
Brando you might want to post it on the official FIRST forums to get a clarification. If you get one, we'd love to hear it!
Unread 12-01-2004, 22:40
Jedi Padawan's Avatar
Jedi Padawan Jedi Padawan is offline
Electrical Expert Student
AKA: Dan Howell
Jedi Padawan is on a distinguished road
Send a message via AIM to Jedi Padawan
So let me get this right you basically cannot "touch the sidebar?" so if a team say had a mechanism to climb the sidebar and attatch a hook so they could use a climbing mechanism they couldn't??
It's all fun and games till the bosh motor breaks.....
Unread 12-01-2004, 22:42
According to what we have determined, they would be able to so long as the "climbing mechanism" didn't remain on the side bar at the end of the match.
Unread 12-01-2004, 22:45
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
i would say that you would be allowed to lean against the side bars. First most likely made the rule saying that you cannot be directly hanging on the side bars because those bars were not designed to handle the kind of side loads and strains that would happen if you were to hang from it. Also, they do not want robots to be able to cheat directly attach to the vertical poles low to the ground, picking themselves up without going to the trouble of reaching 10 feet in the air.
Basically, if you are clearly attached to the horizontal bar in some way, and the horizontal bar is bearing all of the load of your robot, you will be fine. as dean said, we are not lawyers here. although the wording is a little vague, the reasoning behind the rule is more readily apparent, and as long as you don't hurt the bar or gain an unneccessary advantage from touching the vertical poles i doubt that the refs will care.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 13-01-2004, 00:39
I would, but I can't! I don't have the password. If someone else can - please do ask this. We can debate all we want, but what they say goes.
www.burobotics.org
Unread 13-01-2004, 13:15
Ken Loyd Ken Loyd is offline
Who is John Galt?
FRC #0039 (The 39th Aerosquadron)
Ken Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to behold
Let us suppose that robots A and B are hanging from the bar. At the last moment robot C attaches itself to the bar and rises off the floor pushing robots A and B against the pole. Common sense dictates that since robots A and B are hanging, they would each earn 50 points eventhough they are touching the poles. They did not use the poles in any way to achieve "hanging". If on the other hand robot D climbs up the pole (which I consider wrong), attaches itself to the bar but still stays in contact with the pole, I feel they schould not receive the points.
Ken Loyd
Team 64
Unread 13-01-2004, 13:28
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
imagine the field in this fasion:
'-^x^--------'
[ROBOT]
______________
  PLATFORM
if the bars along the side were to be removed (in picture, hanging from the cieling) would your bot stay up?
in the case of the bot pushing the others against the bar:
'--^x^^x^----'
 .\/[ROBOT]
______________
  PLATFORM
Without the bar, the pushed bot could still stay up.
Since we must try to understand the intention of the rules.. when finding all of these loopholes... determine the intention of your question.
Intention of chin-up bar rule:
To have robots hanging from horizontal bar. (when doing chin-ups do you do one hand on the chin-up and one on it's support?).
Intention of grabbing the side:
To avoid having to be hanging just from the horizontal bar.
Now.. what do you think your answer should be?
You don't need to go to Law school to be an Engineer.
Unread 13-01-2004, 16:54
#0353 (Pobots)
The rules do say attach, im not talking about climbing, im talking about reaching the horizontal bar from the floor(on the side of it) lifting up and just leaning against the bar. If you remove the vertical bar we would still be hanging, but if we can't swing around and are leaning on the outside with our robot hanging still, does that count? That's what i was trying to ask before.
Unread 13-01-2004, 19:45
psycho7 psycho7 is offline
pyscho
AKA: (ex-freshman)
FRC #1831 (Screaming Eagles)
Team Role: Scout
psycho7 is on a distinguished road
Send a message via AIM to psycho7
As long as the robot is only using the vertical bar to keep its self from swinging and is not attached then it should be okay. But you never know when you may get a really annoying ref. (you know what I mean here)
Definitions of Nerd and Geek: Geek-the people who go to dances, try and dance,and get beaten up. Nerd- those who stay home during the dances and study.
by week two of FIRST robotics, everything needed to be done as of last week.
think outside the box.
what is 1+1=?
answers:
window;11;2;mace
Falling off the bar... :\ Swampmonkey General Forum 47 14-03-2004 12:47
Raising the bar...or lowering it? Ben Mitchell General Forum 29 13-01-2004 03:30
Make the bar lower to get on? tkwetzel Rules/Strategy 28 12-01-2004 05:57
Vertical bar interaction Madison Rules/Strategy 5 10-01-2004 16:22
Grab bar on bottom of goals archiver 2001 0 24-06-2002 00:49
