Go to Post I love it when the robot's develop personality quirks. - Mark McLeod [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 12-01-2004, 22:31
K.Shaw's Avatar
K.Shaw K.Shaw is offline
The Zoomin' Human
AKA: Shaw 1, kevshaw, little shaw
FRC #0237 (Sie-H²O-Bots (See-Ho-Bots), FLL #3954 (Swift Eagles))
K.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant future
Send a message via ICQ to K.Shaw Send a message via AIM to K.Shaw Send a message via MSN to K.Shaw Send a message via Yahoo to K.Shaw
Scroll Bar Color
How do you change the color of the scroll bar on your website? because it is really coool!!!
2005 Bash @ the Beach Winners -Thanks Team 1511 and Team 181
2005 NJ Regional Finalist -Thanks again to 56 and 303
2005 Radioshack Innovative Control Award-NJ
2005 FLR Semi-Finalists
2005 Radioshack Innovative Control Award-FLR
2004 Archimedes Divisional Semifinalists
2004 NJ Regional Winners. -Thanks Team 56 and Team 303!
2004 NJ G.M. Industrial Design Award Winner
2004 UTC Motorola Quality Award Winner
Unread 12-01-2004, 22:35
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Re: Scroll Bar Color
Add this in your CSS:
BODY {
scrollbar-face-color: #000000;
scrollbar-arrow-color: #000000;
scrollbar-track-color: #000000;
scrollbar-shadow-color: #000000;
scrollbar-highlight-color: #000000;
scrollbar-3dlight-color: #000000;
scrollbar-darkshadow-Color: #000000;
Works only for IE browsers.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 12-01-2004, 22:37
Umm Errr...
here is a tutorial: http://www.websitetips.com/info/css/scrollbars.html
BTW: Although many browsers understand it, scrollbar styling is not w3c supported, however it is fairly safe to use because if a browser doesn't support it, then o well.. the scrollbar won't show up styled.
1139 Alumni
Unread 12-01-2004, 22:41
K.Shaw's Avatar
The Zoomin' Human
Thanks alot!! i posted like less than 5 minutes ago and got two answers....chief delphi forums and you guys are great! lol
Unread 13-01-2004, 07:28
iBob's Avatar
iBob iBob is offline
Extreme Mac Geek
AKA: Christopher Jones
#0240 (Mach Vee)
Team Role: Webmaster
iBob is an unknown quantity at this point
Send a message via AIM to iBob Send a message via Yahoo to iBob
Correction, only Windows IE browsers...
Visit Team 240's Homepage
Unread 13-01-2004, 20:54
pedro's Avatar
pedro pedro is offline
FIRST Alumni
#0492 (Titan Robotics Club)
pedro is an unknown quantity at this point
Send a message via MSN to pedro
Something else that works great is
body { scrollbar-base-color: #009900; }
If you just want some sort of green and allow the browser to figure out how to make it look nice.
Unread 13-01-2004, 21:05
K.Shaw's Avatar
The Zoomin' Human
thanks for the code but im not quite sure how to add it? someone please explain thanks
Unread 13-01-2004, 21:08
Yan Wang's Avatar
Ithaca is Gorges
AKA: John Wayne
Well, you could create a file called style.css to for the central css of your site. In it you could paste what I posted... and add other stuff as needed to define various things like table styles, links styles, etc.
In each html file or php file that you want to access the style.css file with, you need this in the html's <head> tag, linking to the css file as you would an image, etc. with its directory and file name:
<head>
<link href="style.css" type="text/css" rel="stylesheet">
</head>
Unread 13-01-2004, 21:09
Yan Wang's Avatar
Ithaca is Gorges
AKA: John Wayne
Since you seem new at html/css, you should check out some of the tutorials at www.htmlgoodies.com
Nicely written for the aspiring webmaster
Unread 13-01-2004, 21:41
pedro's Avatar
FIRST Alumni
The other way is by using the following in the <head> tags:
<style type="text/css">
body { .... }
</style>
This isn't as efficient because if you ever want to change it you will need to edit every document (while you only have to edit a single linked style sheet in the other method).
Unread 15-01-2004, 00:56
K.Shaw's Avatar
The Zoomin' Human
ok thanks i got it to work you guys are awsome!
Falling off the bar... :\ Swampmonkey General Forum 47 14-03-2004 12:47
Raising the bar...or lowering it? Ben Mitchell General Forum 29 13-01-2004 03:30
Make the bar lower to get on? tkwetzel Rules/Strategy 28 12-01-2004 05:57
Vertical bar interaction Madison Rules/Strategy 5 10-01-2004 16:22
Grab bar on bottom of goals archiver 2001 0 24-06-2002 00:49
