#31
Re: Horizontal Bar: Vertical Velocity
I see this whole thing on, how are they really going to know if somethings going too fast if the object isn't going 20 ft (sarcastically) way up in the air and hitting someone in the head. I think the judges will be very lenient on this role and cut alot of slack within safety reasoning.
#32
Just curious, I know that the vmax=10ft/sec, but does that apply to non-projectiles aswell? for intance, if we were to use a tube-in-tube to raise a hook up to grapple the bar, but the hook was (on the first trip) attached to the hard tubing, which was in turn attached to the roboti, would it be considered a projectile? if so, we were be running it with a motor and therefore still running at a constant 10ft/sec, so it would need to take 1 sec to get up there. if not, could we raise it as fast as possible?
#33
I don't think that would be considered a projectile by any means but that's just me.
#34
The rule states that all mechanisms must not exceed 10 f/s. That would include any telscoping arms, projectiles, or anything else.
#35
I used Andy's method of applying the equation "V^2=Vo^2+2aX" and derived the same formula.. Hmmmmm. |
#36
to :Mike Betts
from: Team #0177 (Bobcat Robotics) You do have a fair point about it being dangerous and all but than in the simulations they did 'live' from new hamhire or whereever it was; the person that hung on to the bar actualy threw the strap he than secured toh is little bike and hung on the bar by it.... and i think that was woody that said "I think mike there didnt go over 10 ft/s when he threw it" so i'm pretty sure its going to be alowed one way or another, we just have to watch fo more safety rules and stuff like that to observe when we're building it |
#37
Remember, in physics, there are often many ways to find the same answer. Your way is right also, but harder (to me). |
#38
Conservation of energy vs. kinematics. This are just two different ways to solve the same problem. We are both correct except I am more right because I used the metric system. Just kidding, seriously though, the metric system is so much easier to use then the imperial system. There is nothing easier then multiplying/dividing powers of ten then fractions (shudder). Useless info: -Americans are better at fractions then Europeans because Americans have to be fluent with fractions because of their/our measurement system. Interesting -Our robot will probably be in inches because of the availability of metric vs. imperial fasteners, drive componants, extruded aluminum, 80/20 etc. Good luck this year! -Andy |
#39
![]() Last edited by Yan Wang : 13-01-2004 at 22:33. Reason: "culture change", not "culture" |
#41
first convert feet/sec to meters/sec then do the equations then convert back, you get about 15 feet high if i'm right. you have to do this because v is squared (if i'm right) but i'm probably wrong. |
#42
Vmax = 10ft/s g = 9.8m/s^2 = 32.15ft/s^2 You get 1.55 ft (100/63.3) Last edited by Yan Wang : 13-01-2004 at 22:45. Reason: spelling error... just not good with english tonight |
#43
oh, right, that was dumb, i didn't notice that it'd been corrected originally
| Vertical bar interaction | Madison | Rules/Strategy | 5 | 10-01-2004 16:22 |
| Team 68's REAL ROBOT!!! | Alexander McGee | Robot Showcase | 137 | 25-02-2003 09:42 |
| Grab bar on bottom of goals | archiver | 2001 | 0 | 24-06-2002 00:49 |
| dimensions of horizontal bar | archiver | 2001 | 7 | 23-06-2002 23:32 |
| How many robots on the bar in one match? | archiver | 2000 | 14 | 23-06-2002 22:39 |
