Go to Post Being consistently enthusiastic with a consistent message is not easy to do without sounding like a cult. We could use a reasonably large collection of things to say that restate the mission and vision of FIRST but don't appear to be stock phrases. - Alan Anderson [more]
Unread 12-01-2004, 20:05
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
Re: How Does a Winch Work?
Originally Posted by MBF
Do you have any more pictures or diagrams? My team is trying something similar this year, and any information would be helpful. Some of the doubters are still not quite seeing how the arm would work, and any concrete evidence would be useful.
go to http://www.valleytech.k12.ma.us/robo...photos2000.htm
there more there.
Unread 12-01-2004, 20:11
generalbrando's Avatar
generalbrando generalbrando is offline
Build, Break, Repeat
AKA: Brandon Mensing
FRC #0246 (Overclocked)
generalbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to behold
Send a message via AIM to generalbrando
Originally Posted by Raul
The van door motor can be back driven unless the bearing screw (at the end of the worm gear) is tightened quite a bit. The problems with doing this are:
1) You lose power output by tightening it
2) It wears out and you have to keep tightening it to keep it from backdriving
Plus it might still back drive if it sees excessive force.
Also, if you're worried about keeping a motor from slipping (such as when the power gets cut at the end!) you could use a little pneumatic piston to lock something in place. If you were pulling in a cable on spindle like thing (i'm bad at the right names, forgive me) then on the side of that you could have ridges (think raised spokes) and then all you have to do is fire the piston into the side of the thing to lock the spindle in place. As long as you set up the pneumatics right, it won't move when the power gets cut.
Lead Mentor of Team #246, Boston University Academy and Boston University, Overclocked
www.burobotics.org
Unread 13-01-2004, 00:04
MBF MBF is offline
#0992 (Oakwood Robotics)
MBF is an unknown quantity at this point
Send a message via AIM to MBF
Originally Posted by Mike Norton
Thank you.
Unread 13-01-2004, 08:26
Jeff D.'s Avatar
Jeff D. Jeff D. is offline
Jeff D. is an unknown quantity at this point
Send a message via AIM to Jeff D.
Back on the subject of winches:
Planetary Gears are what gear down most winches for automotive purposes. (Warn Winches, etc.)
I'm working on getting some write-ups from some fellow Jeepers.
Stay Tuned.
Jeff
Unread 13-01-2004, 12:07
Adam Krajewski's Avatar
Adam Krajewski Adam Krajewski is offline
AKA: Jewski
None #0857 (Superior Roboworks) / Team #0068 (Truck Town Thunder)
Adam Krajewski is on a distinguished road
And when it wears out, no amount of tightening will do you any good.
During the summer of 2000, I did a study on the brakes. What they are exactly is a set screw (did someone inhale?) with a spring mounted 'brake pad' on the end. When you tighten it, you force the 'brake pad' onto the side of a plastic (final drive?) gear in the motor. This pad will eventually wear down and break. At that point, tightening it will do no good, as it is just a tapered end of a set screw with a hole in the middle against hard plastic. I have pictures somewhere of various van door motor brakes, but I can't seem to find them right now.
However, the bottom line is the brake should really only be used to get rid of very minor problems with backdrive. In '99, we used a van door as a winch motor to raise the lift carrying floppies over 8 feet and friction plus the brake kept the lift in the air without a hitch. In 2000 we tried to do the same thing, burning up brakes in the process on the motor that drove the shoulder of our arm. The final solution I came up with was to use a PD control system for the arm, so that 'sag' during a match didn't matter because the motor always ran to keep it in the right position, something it could do easily for 2+ minutes.
I would suggest something along the lines of what generalbrando said, and using a pin to stop the drum from rotating or perhaps some type of one-way action with a release like what rachet straps and come-alongs use.
"My favorite programming language is solder."
- R A Pease
Unread 15-01-2004, 22:09
BillBartell BillBartell is offline
no team (Team Impact)
BillBartell has a little shameless behaviour in the past
There are many types of gears that drive different types of motors but the most popular for high torque winches is called a planetary gear. This type of gear is used on the bosch drill motor gear box. It allows for nearly a 500:1 reduction which surpaces any other type of gear box drastically. As far as Telescoping arms go...i dont want to give away of any of my teams secrets but think power car antenna.
Unread 20-01-2004, 19:48
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
correct me if I'm wrong, but arent all these spring loaded or pre tensioned systems that are released during the match illegal because that is considered another source of energy (not compressed air tank or battery)?
Unread 20-01-2004, 21:10
spring loading or pre-tensioned is ok this year (the rules for how much energy can be stored in your bot at the start have been backed off this year)
but if your arm is going to be used to go after the chinup bar, its tip cannot extend faster than 10 feet per second - so you cant just have some big piece of springy material that you release and it snaps out - you would have to dampen the rate at which its released somehow.
Unread 20-01-2004, 21:14
BTW - the telescoping stuff is off topic for this thread, but I have a really cool idea, so I will try to find an appropriate thread and post my incredible idea for it there. :c)
Problems of the mind... effecting work Gadget470 Chit-Chat 20 18-11-2003 11:56
Edit doesn't work on original title posts??? Elgin Clock CD Forum Support 6 12-03-2003 17:30
Who knows how the motors [I]really[/I] work? Wetzel Chit-Chat 5 13-02-2002 21:50
Back up your work! Maddie N Chairman's Award 3 13-02-2002 06:16
Does anyone on this board work at home depot? mnkysp6353 General Forum 2 30-12-2001 13:27
