Go to Post Robotics is about people. It always was, it always will be. What more guidelines do we need? - Ken Leung [more]
Unread 13-01-2004, 08:38
Tim Skloss's Avatar
Tim Skloss Tim Skloss is offline
Dr. Skloss
FRC #0930
Team Role: Parent
Tim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the rough
Save time? Use aluminum extrusion kits!
Can I share a secret?
We have used the ITEM brand aluminum extrusion for the past two years and have had awesome results. ITEM's is stronger than other brands of the same size (Bosch, and others)--we had a 200 lb student stand and bounce on our box frame (frame stood on long end) and it only flexed a bit. It didn't break or permanently deform. See the attached pictures!
This year, the ITEM company is selling kits of extrusion and fasteners at drastically reduced prices for FIRST teams. Go to: www.itemamerica.com and click on the FIRST link at the bottom of the home page.
All you need to use this structural material is a standard wood chop saw (miter saw preferred) with a carbide blade and a few allen wrenches. It cuts and machines easily for modification and is a breeze to assemble. Be sure to use cutting fluid on the blade.
The best part is that you can change the dimensions of your drive train or chassis in MINUTES, not DAYS when machining stock aluminum or welding.
We have already ordered kits for 2 of our rookie teams because it really does save time!
ID:	1698  Click image for larger version
FIRST Mentor and Team Leader
C.O.R.E 2062 a NASA, GE Volunteers and Rockwell Automation FRC Team
Actual execution time measurement Dan Technical Discussion 5 24-03-2003 11:36
Solution to Timing Loops Steven Carmain Programming 39 10-02-2003 13:33
How long should production time be??? archiver 1999 4 23-06-2002 23:16
Definition of aluminum extrusion...? kangarue23 Technical Discussion 4 25-01-2002 16:53
precision grade aluminum extrusion - item MB Kit Loren 930 Technical Discussion 2 11-01-2002 21:42
