Just the sight of you makes my vision system go haywire.
Go Back   Chief Delphi > Other > Math and Science
Unread 13-01-2004, 10:02
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Re: Egg Drop Contest
A really cool looking and easy way to do this is with either normal printer paper or with straws.
Roll the paper or use straws to make the edges for an open 8x8x8 cube.
Secure corners with masking tape.
Make a smaller cube with rolled paper or straws to hold the egg.
Wrap egg in tissue paper to make it fit better into the small cube.
From the corners of each cube, place an S Shaped paperclip ("open" the paper clip to an S shape)
From each clip then place a small rubber band. Band should be small enough to be pulled tight at the distance, but not near breaking.
all in all, it should look vaugly something like this:
 _______
| \___/ |
| |EGG| |
| /ŻŻŻ\ |
 ŻŻŻŻŻŻŻ
The rubber bands create a pretty good quality suspension sytem, preventing th egg from ever feeling the full force of the impact with the ground.
Works great if part of the challange is speed of drop. (Parachutes = Slower)
Unread 25-01-2004, 18:42
R2K2D2 R2K2D2 is offline
AKA: Raj
R2K2D2 has a spectacular aura aboutR2K2D2 has a spectacular aura about
Send a message via AIM to R2K2D2
This is one way that I have done this in the past. Take some long durable straws. Put rubber bands around your egg and then place the straws all around your egg and either tie them together or use rubberbands to constrain them. So basically, you will have this spikey ball (made from the straws jutting out in different directions, with the ball in the center. I have dropped this from a very high staircase and it worked perfectly. The straws will take all the impact and crumple, if needed, and the egg will be safe. The straws allow the structure to bounce and be impact resistant.
Unread 26-01-2004, 21:06
c-squared_2006 c-squared_2006 is offline
Student Leader / Scout
None #1015 (Pi Hi Samurai)
c-squared_2006 will become famous soon enough
Wink Re: Egg Drop Contest
Well, please let us know how you did!
Unread 26-01-2004, 21:25
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
Wrap lots of bubble wrap and duct tape on it....thats what they pack things with for shipping...must work..
-Pat
Unread 26-01-2004, 21:51
Duke 13370's Avatar
Duke 13370 Duke 13370 is offline
C is for cookie...
#0862 (Team Lightning)
Team Role: Webmaster
Duke 13370 will become famous soon enough
Send a message via AIM to Duke 13370
When i did this i used a less dense padding around the egg, then a slightly more stiff layer then another layer, and so on for like 3 more layers. It fit in a box about the size you needed, after dropping it 30 feet easily, we played a quick game of football with it until someone drop kicked the box. it got messy then.
it might have been bigger. meh! whatever
---Lightning Robotics!---
Unread 26-01-2004, 22:24
Gabriel Gabriel is offline
#1409 (Fightin' Llamas)
Gabriel is just really niceGabriel is just really niceGabriel is just really niceGabriel is just really nice
Send a message via AIM to Gabriel
I had to do this once. I was thinking about designing a parachute and some airbags, but after thinking a long time I found the PERFECT mechanism. Here are the step-by-step instructions
1. Go to your school's mailroom and get a box for an empty ream of copier paper.
2. Go around to all the laser printers and collect as much standard 8 1/2 x 11 paper as you can. Reams of paper where the pages are attached work the best.
3. Put half a ream of paper in the bottom of the box. Put egg on top, put the other half ream on top of that.
4. If you have any extra room fill it with bricks. Your whole school building is probably made of bricks and chances are they can spare a few.
5. Obtain a sharpie or other permanent marker.
6. Using letters several inches high name your creation "THE PHOENIX"
Unread 27-01-2004, 06:41
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
#1257 (Parallel Universe)
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
I know for a fact that there are archived threads about this exact topic. Do a search and see if you get any good ideas.
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
Unread 27-01-2004, 08:49
Matt_Kaplan1902's Avatar
Matt_Kaplan1902 Matt_Kaplan1902 is offline
#DecadeofDelicious
FRC #1902 (Exploding Bacon)
Matt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond repute
Send a message via AIM to Matt_Kaplan1902
Thanks for all your suggestions. I used a slightly modified version of Greg Needel's idea.
If you were wondering my egg did survive and got 3rd place in my class. Thanks again for all your help.
Team 1902: 2007-??, Mentor
Team 108: 2002-2005, Student
Unread 27-01-2004, 20:36
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
I had to do this, and I just taped 2 sponges together... worked fine, but it was a bit too bouncy.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 01-02-2004, 23:58
pryoplasm's Avatar
pryoplasm pryoplasm is offline
Pit Crew/Electrical
AKA: Russ
#0069
pryoplasm can only hope to improve
XD XD XD
Cut these eyes, but I will see,
Kiss these lying lips for me,
Stroke this skin, and I will kneel,
Brutalize me, I will heal...
-KMFDM
Unread 02-02-2004, 12:59
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
lol @ Gabriel
it's more fun when you have to do a naked egg drop - that is, build a catcher instead of a container. catchers ranked by highest drop successfully caught first, height of the catcher itself second. (have a set number of drop heights so someone doesn't build a yard-tall catcher and simply out-drop everyone - a big emphasis here is on making a short catcher). I did this one year and caught an egg from eight meters with a 10cm tall catcher. that was fun
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 02-02-2004, 13:15
Dave Vivecian Dave Vivecian is offline
Dave Vivecian is an unknown quantity at this point
I thought naked egg drop was something you did off the diving board skinny dipping at night in the neighbors pool...
lol
the best "naked egg drop" though is when your only allowed paper, tape, and straws
We did this in about 5th grade and i made a box that sortof resembled this years goals, and put shreded paper filling the inside except on the inside of the pungie pit type thing
______
|.egg.|
then with paper on the outside of that ring and inside of the box
also tape rolls on the inside edge of the ring so when it fell in it wouldnt bounce out
then i used gabriel's method and it was kewl but i named mine "Back to Hates"
hehe
Dave
Unread 02-02-2004, 14:45
Computer Guy
AKA: Dav
what height did you get from it?
NEW 2004 Repeat contest - Pioneer HS, AA MI wishes to Host kmcclary Off-Season Events 0 23-09-2003 13:34
NYC Web Contest Problems & A Letter to FIRST... AugustF Website Design/Showcase 31 04-05-2003 11:36
writing contest Ken Leung General Forum 10 15-12-2002 16:15
Egg drop help Please..:-) archiver 2000 9 23-06-2002 22:49
Rookie Team needs to borrow a FIRST goal for CDI contest kmcclary General Forum 7 17-10-2001 19:49
