Go to Post Once I see that it is black with aluminum ends, I only care about the inside. Sort of like Oreo's. - Al Skierkiewicz [more]
Unread 12-01-2004, 22:55
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Blocking the ball deposits
My team noticed that positioning the mobile goals in front of the opposing teams ball deposits held them up from getting and balls until they would have to divertsome of their robot time to clearing them out of the way. We thought that maybe blocking the oppositions ball deposits with mobile goals or the robot itself could provide a good defensive strategy. Keep in mind you dont need a high scoring game in the finals and that just winning is the first step in getting a high seed.
Unread 12-01-2004, 23:04
Atman's Avatar
Atman Atman is offline
"Bring the HAMMER" Go 364
AKA: Team Godfather
#0364 (Team Fusion)
Team Role: Driver
Atman has a spectacular aura aboutAtman has a spectacular aura about
Send a message via AIM to Atman
Re: Blocking the ball deposits
My teammates had the exact same idea. The only debate was is it more of a waste of your time or an effective defensive strategy. That would have to be a driver decision. You have to ask yourself does the other team have a mechanism specifically designed to pull the goal, if so, are you helping the other team more than your harming them?
Unread 12-01-2004, 23:06
Jedi Padawan's Avatar
Jedi Padawan Jedi Padawan is offline
Electrical Expert Student
AKA: Dan Howell
Jedi Padawan is on a distinguished road
Send a message via AIM to Jedi Padawan
When FIRST mentioned the spirit of the competition and all those speaches about "Gracious Proffessionalism" at least my team took the hint. This is not meant to be a defensive I'm going to bash you into the ground type game, KISS it for goodness sake!! do all that you can don't worry about your opponent unless it's blocking them from the "bar" or knocking out the 2X. Plus it's advantagous to allow your opponent to have some points unless you want to be at the bottom of your tier and fight your way up?? but thats just me.
A side note for our team at least we developed a "code of ethics" for this competition what we are willing to do and what we aren't, these would include highly mean spirited and pointless things like netting over the goals or blocking ball deposits with a goal etc.. not to say we wouldn't be competitive just that there are some things that instead of being "gracious" turn into sorts of evil type things kinda like turning to the dark sides of designing stuff...
It's all fun and games till the bosh motor breaks.....
Unread 13-01-2004, 00:37
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Whoa Jedi,
FIRST has not ruled on the issue in the Q&A yet, but I believe they will allow it. Here are the reasons why.
First off, blocking one ball chute will not prevent the opponent from scoring. There are two ball chutes and the human players can share balls. Blocking both chutes with one robot would be a feat of engineering. We are talking about 24 feet. And blocking with goal will happen no matter if it happens naturally or intentionally. And when it does happen the opposing team has a fair chance to move the goal and continue scoring.
Unread 13-01-2004, 00:46
AKA: Dan Howell
I know they probably will I'm just saying your using up alot of your time to do something that unless your ally does it as well you don't stand to gain from it (all that much) and you end up losing points that way as well. Plus why would you want to other than to directly try and take points away when you could just be adding more points to yours than they are to thiers unless your worried you won't be able to design something that good. oh well I'm not saying to burn the idea I'm just saying keep it in context of each individual match if an opponent wants to fight fire with fire (in this case block your chute) I have no qualms about blocking them and playing defensively but for the most part it seems this year FIRST tryed to somewhat tone down the defensive aspects of the game and want you to concentrate on the offensive.
Unread 13-01-2004, 00:57
if you drag your opponents goal infront of their corral opening, they will say THANK YOU! - it will be very easy to drop balls into it there
and if you drag your goal to their side, it will be impossible for your team to score any points with it.
Unread 13-01-2004, 01:20
CharlieWilken CharlieWilken is offline
#0634 (Robowolves)
CharlieWilken is an unknown quantity at this point
if two hanging robots delay the ball fall and then block the ball holes for 30 seconds they could then leave and hang themselves on the horizontal pole. 100 points would be hard to make in the 45 remaining seconds
Unread 13-01-2004, 04:36
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
Originally Posted by ngreen
Whoa Jedi,
Just checked FIRST's Q&A section, it said:
Q: During a match, are the human players allowed to use both ball chutes or only one?
A: Human Players must stay inside their own Team Zone so they could only get balls from one chute. They can pass them to the other HP in the alliance as long as the HP stays within their own Team Zone.
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
Unread 13-01-2004, 09:41
robolemur1236's Avatar
robolemur1236 robolemur1236 is offline
robolemur1236 can only hope to improve
ur forgetting that for the seeding, the losers score is used, so u really only want to win by the lowest possible margin. If you trounce them, then you get a low score too...
being requiring of an interesting team name/mascot/motto that is appropriately geeky and at the same time pleasing to the ear.
Unread 13-01-2004, 10:05
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
No, seeding is determined by Wins, Losses, and Ties... THEN the tie-breaker is the losers score. Here is an example:
Rank Team Wins Losses Ties Losers points
1. 333 8 0 0 543
2. 222 8 0 0 210
3. 111 7 0 1 777
4. 99 7 1 0 834
5. 88 7 1 0 456
It's really simple. Qualification rankings are determined on W-L-T. If two teams have the same W-L-T record, THEN the tie-breaker to determine which one seeds higher is the Losers points.
Hopefully, this is clear.
Andy B.
Unread 13-01-2004, 10:51
Rick's Avatar
Rick Rick is offline
Ready to STRIKE!
AKA: Rick Blight
FRC #0078 (AIR STRIKE)
Rick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond repute
Sorry to nitpick Andy, but im afraid your wrong.
7.3.3 Match Qualification Points and Ranking Points
At the completion of each Qualification Match, each team will receive a win, loss or tie depending on the final score. Each team on the winning Alliance will receive two Qualifying Points. Each team on the losing Alliance will receive zero Qualifying Points.
In the event of a tie Match Score, all four teams will receive one Qualifying Point.
All four teams will receive a number of Ranking Points equal to the Match Score of the losing alliance or their alliance score in the case of a tie. A Surrogate team will receive zero qualifying Points and will not
receive any Ranking Points.
So the ranking should look like this:
Rank Team Qp's Rp's
1 A 16 1000
2 B 16 800
3 C 13 1200
4 D 12 2000
5 E 12 1200
The reason why W-L-T can't work is because we have all seen how the number of matches each team gets is usually not equal. Each team ranked first by Qp's and then by Rp's. I'm growing to like the idea.
Like Aquidneck Island Robotics on Facebook!
Unread 13-01-2004, 11:06
AKA: Nelson Green
Jedi,
I'm talking about another question asked.
If we can block the chutes, not if HP can pass the balls to each other?
Unread 13-01-2004, 11:10
risksta - why did you tell andy he is wrong, then give an example that agrees with what he said
you ARE ranked first by the number of matches you have won (your qualifying points) and within each of those tiers you are subranked by your ranking points (loser match points)
__________________________________________________ _____
7.3.7 Qualification Ranking
All teams in attendance will be ranked during the Qualification Rounds. If the number of teams in attendance
is 'n', they will be ranked '1' through 'n', with '1' being the highest ranked team and 'n' being the lowest ranked
team.
The Scoring System will use the following Ranking Method:
• Teams will be broken into Tiers based on their Qualifying Score. (this is W/D/L)
• Within each Tier, teams will be sorted by their Ranking Score. (this is match loser scores)
• If any teams within a Tier have the same Ranking Score, they will be sorted by their Highest Match (this is teams highest match WINNERS score)
Score.
• If any teams within a Tier have the same Ranking Score and the same Highest Match Score, then
the Scoring System will sort those teams based on a Random Electronic Coin Toss.
if the number of teams at a regional is not divisible by 4, they will assign random surrogate teams to even out the number of seeding matches played. All teams will play the same number of seeding matchs - if surroate teams are needed for the last match, the match reasult will not affect their ranking in any way.
Unread 13-01-2004, 11:25
mtangolics mtangolics is offline
AKA: Mike Tangolics
#1403 (Cougar Robotics)
mtangolics is an unknown quantity at this point
Send a message via AIM to mtangolics
Seems to me that most of the "gracious professionalism" stuff had to do with assisting fellow teams. Blocking the goals also seems to be in the spirit of the game, because otherwise they would have put something in the rules about it.
Just my thoughts...
Unread 13-01-2004, 14:38
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
They are right, wins do weigh more than the games score. And blocking both deposits wouldn't be as hard as you think. If you remember the Zone Zeal game from 2 years ago, several teams used teathered "runners" to score in multiple zones. A similar strategy could be used here, with a runner deploying in front of one deposit and another one going to the other. Since I havnt found entanglement rules yet, and niether has my team, you could do other things while the runners sit there. Also blocking it with a goal doesnt guarantee an easy shot, keep in mind there is a 7 foot high player station wall in the way.
2004 Game BBFIRSTCHICK General Forum 112 19-04-2003 17:12
blocking the ramp Jacqui Sutton General Forum 3 07-01-2003 09:02
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
30" ball sits up there real pretty archiver 2001 18 23-06-2002 22:49
ksc - ball bots ohm my katie86 Regional Competitions 8 10-03-2002 22:52
