Re: Save time? Use aluminum extrusion kits!
We got the Pro kit... Since most of the cost (90%+) is in the extrusion, you could divide the cost by the total number of feet in the kit. The pro kit comes with 60 METERS of extrusion, that comes to about $10 per meter... pretty cheap in the long run!
I'll try to get a sheet from ITEM that specifies the cost per part and post it here. Tim Quote:
Whoops, my mistake:
not 60 METERS, 16x3= 48 METERS... Still works out to under $15 per meter. Tim Quote:
We've been using the same stuff since we started. It durable and easy to build with. But stay away from those Zinc T-nuts They crack, stick the the brass. We had about a dozen cracked t-nuts by the end of Annapolis.
On another note we built our cart out of aluminium profile as well. And it rocks. |
| Actual execution time measurement | Dan | Technical Discussion | 5 | 24-03-2003 11:36 |
| Solution to Timing Loops | Steven Carmain | Programming | 39 | 10-02-2003 13:33 |
| How long should production time be??? | archiver | 1999 | 4 | 23-06-2002 23:16 |
| Definition of aluminum extrusion...? | kangarue23 | Technical Discussion | 4 | 25-01-2002 16:53 |
| precision grade aluminum extrusion - item MB Kit | Loren 930 | Technical Discussion | 2 | 11-01-2002 21:42 |
